Little bit of tinkering aka Tinkertoy - JeepForum.com
post #1 of 3079 Old 04-10-2011, 12:00 AM Thread Starter
aw12345
Two years ago after our second visit to the Hammers and running Clawhammer, Sledge Hammer and Big Johnson a friend and me both decided that to keep our daily driver Jeeps in one piece something a bit more carried away was needed to have fun and keep our Jeeps from looking better than something that sits in a junk yard. So after some horse trading and side work I got my hands on a 2004 TJ that had been rolled. I ended up with the Jeep minus axles, transfercase and suspension.
Here she is after I knocked the tub back in shape, sitting next to my little Jeep.
Once that was done the axle hunt was on ended up with a 14 bolt for the rear and a Dana60 HP out of a 79 Ford F350
Once I got some more side work done I really got going on it last May
I wanted everything underneath flat so no control arm brackets, skid plates or anything beneath the frame
Since I was waiting for some parts started to think how the transfercase was going to go under there
Whole bunch of sheetmetal had to go to make that fit
aw12345 is offline
post #2 of 3079 Old 04-10-2011, 12:16 AM Thread Starter
aw12345
Started to get a handle on the front suspension
Had to modify the frame a bit to get some clearance for the axle and some room for the steering
Cut the front of the frame off and replaced it with some rectangular tubing, this way the steering box can come forward to accommodate the front wheel base Stretch. Front axle moved about 6 inches forward
[IMG]http://i131.photobucket.com/albums/p289/aartw12345/tinkertoy/
bigyeller099.jpg[/IMG]
aw12345 is offline
post #3 of 3079 Old 04-10-2011, 12:41 AM Thread Starter
aw12345
Then picked up the coil overs and look ma the front sits on it's own weight.
From there I moved on to making some crossmembers and came up with a lo pro mount for the trans
Once that was tackled, I sacrificed a week vacation and used that time to make a start on a rear suspension
Then the next day it stuck it's nose out of the garage for the first time
That put me towards the end of August of last year.
Then I started to make the mounts for the rear coil overs
Got some nice beadlocks for it also
Week or so later rolled it outside to see how well it would flex and check for clearances
aw12345 is offline
post #4 of 3079 Old 04-10-2011, 12:47 AM
motorsports3
1997 XJ Cherokee
Sick build!
motorsports3 is offline
post #5 of 3079 Old 04-10-2011, 12:56 AM Thread Starter
aw12345
Then started making a bracket for the York compressor for the onboard air
Then borrowed a tube bender and started on a roll cage
Then stuck the rear driveshaft in and drove it for the first time down the street
aw12345 is offline
post #6 of 3079 Old 04-10-2011, 01:16 AM Thread Starter
aw12345
Then on to hi lining the hood and making some tube fenders
Time for a poser shot lol
Time to get the gearing changed and install the lockers
Once that was successfully concluded I started on the onboard air system
So I made a manifold and got this tank from harbor freight
Once that was all plumbed it was on to some rock sliders
aw12345 is offline
post #7 of 3079 Old 04-10-2011, 01:20 AM Thread Starter
aw12345
Became time to tackle the steering box and PCS ram
So took the steering box back out and drilled and tapped it
From there found a place for the reservoir
Mounted the ram
aw12345 is offline
post #8 of 3079 Old 04-10-2011, 01:46 AM Thread Starter
aw12345
Getting closer to the finish
Cleaned up wiring etc under the hood
Time to mess with the center console, the stock stuff had to go to make enough clearance for the shifters and I wanted it gone period
Plenty of room for more switches and idiot lights
On to trying the lockers out
Also in betwixed and between made a rear bumper with some shackle mounts
The finished product
Time for it's first road trip and shake down
Finally got a trailer to drag it to the trail.
The fenders on the trailer did not clear so out came the plasma and of the came. They are now easily removable
This week's chores were to install a rear anti rock and make an engine and trans skidplate
Well that took eleven months of all my free time and vacation time
So that's all folks I need a break and I am going wheelin
aw12345 is offline
post #9 of 3079 Old 04-10-2011, 11:45 AM
kelso1337
Good lord.
That thing is amazing, i love all the custom fab work.
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
kelso1337 is offline
post #10 of 3079 Old 04-10-2011, 07:15 PM
MO2500
Looks great Art It's nice to see it all consolidated together in one thread. I'v been following the build up on "what did you do to your TJ today" thread and the other site you linked too.
Any future plans after wheeling? Looks like a beast as is but there is always something more lol
Instagram: @omsmike
MO2500 is offline
post #11 of 3079 Old 04-10-2011, 08:22 PM Thread Starter
aw12345
For now it's pretty good, will fudge with the rear suspension a little, good thing I drilled extra holes in the brackets I made. On climbing some ledges it wheel hops a bit. We did Clawhammer, Jackhammer including the gatekeeper thing which is pretty darn cool, We could not run Lower Sledgehammer since it was blocked by a broken down Jeep. After finishing Jackhammer we walked down Sledge to see if these folks needed any help. Once we got back to the Jeeps we ran upper Sledge which was way cool might get some pics of that in a bit. Carnage for the day my tiedown straps got cut and the front diff cover peeked back a bit and leaked a little other than that She took her beating without complaints. So overall I am very happy with how the Jeep wheels.
Big Jeeps ride so much nicer on tough trails. Really didn't have any real trouble following my buddy that has his Jeep on 42's
aw12345 is offline
post #12 of 3079 Old 04-10-2011, 08:24 PM Thread Starter
aw12345
Originally Posted by kelso1337 View Post
Good lord.
Pretty much everything is hand made by me, I bought 2 brackets, the rest I made my self. Very little store bought stuff on my toy nor did anybody else do any work on it
aw12345 is offline
post #13 of 3079 Old 04-10-2011, 08:30 PM
rogerhill
I'm in love
rogerhill is offline
post #14 of 3079 Old 04-10-2011, 08:38 PM Thread Starter
aw12345
Originally Posted by rogerhill View Post
I'm in love
I am not sharing lol
aw12345 is offline
post #15 of 3079 Old 04-10-2011, 09:00 PM
MO2500
It shows that you've put a ton of work into it. I'm done buying stuff that I can make. I like the fact that I can be creative and build what I want instead of keeping within the limits of a bolt on product. I certainly respect the amount of fab work that you put into this rig!
Glad to hear it's performing as good as it looks
Instagram: @omsmike
MO2500 is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 05:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 02:20 PM
