-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   Little bit of tinkering aka Tinkertoy (http://www.jeepforum.com/forum/f22/little-bit-tinkering-aka-tinkertoy-1194198/)
aw12345 04-10-2011 12:00 AM
Two years ago after our second visit to the Hammers and running Clawhammer, Sledge Hammer and Big Johnson a friend and me both decided that to keep our daily driver Jeeps in one piece something a bit more carried away was needed to have fun and keep our Jeeps from looking better than something that sits in a junk yard. So after some horse trading and side work I got my hands on a 2004 TJ that had been rolled. I ended up with the Jeep minus axles, transfercase and suspension.
Here she is after I knocked the tub back in shape, sitting next to my little Jeep.
http://i131.photobucket.com/albums/p...erbuilt001.jpg
Once that was done the axle hunt was on ended up with a 14 bolt for the rear and a Dana60 HP out of a 79 Ford F350
Once I got some more side work done I really got going on it last May
I wanted everything underneath flat so no control arm brackets, skid plates or anything beneath the frame
http://i131.photobucket.com/albums/p...gyeller043.jpg
Since I was waiting for some parts started to think how the transfercase was going to go under there
http://i131.photobucket.com/albums/p...gyeller056.jpg
Whole bunch of sheetmetal had to go to make that fit
aw12345 04-10-2011 12:16 AM
Started to get a handle on the front suspension
http://i131.photobucket.com/albums/p...gyeller063.jpg
Had to modify the frame a bit to get some clearance for the axle and some room for the steering
http://i131.photobucket.com/albums/p...gyeller066.jpg
Cut the front of the frame off and replaced it with some rectangular tubing, this way the steering box can come forward to accommodate the front wheel base Stretch. Front axle moved about 6 inches forward
http://i131.photobucket.com/albums/p...gyeller083.jpg
http://i131.photobucket.com/albums/p...gyeller078.jpg
[IMG]http://i131.photobucket.com/albums/p289/aartw12345/tinkertoy/
bigyeller099.jpg[/IMG]
aw12345 04-10-2011 12:41 AM
Then picked up the coil overs and look ma the front sits on it's own weight.
http://i131.photobucket.com/albums/p...eller106-2.jpg
From there I moved on to making some crossmembers and came up with a lo pro mount for the trans
http://i131.photobucket.com/albums/p...gyeller121.jpg
Once that was tackled, I sacrificed a week vacation and used that time to make a start on a rear suspension
http://i131.photobucket.com/albums/p...gyeller131.jpg
http://i131.photobucket.com/albums/p...gyeller134.jpg
http://i131.photobucket.com/albums/p...gyeller125.jpg
Then the next day it stuck it's nose out of the garage for the first time
http://i131.photobucket.com/albums/p...gyeller140.jpg
http://i131.photobucket.com/albums/p...gyeller138.jpg
http://i131.photobucket.com/albums/p...gyeller139.jpg
That put me towards the end of August of last year.
Then I started to make the mounts for the rear coil overs
http://i131.photobucket.com/albums/p...gyeller150.jpg
http://i131.photobucket.com/albums/p...gyeller147.jpg
Got some nice beadlocks for it also
http://i131.photobucket.com/albums/p...gyeller146.jpg
Week or so later rolled it outside to see how well it would flex and check for clearances
http://i131.photobucket.com/albums/p...gyeller163.jpg
http://i131.photobucket.com/albums/p...gyeller164.jpg
http://i131.photobucket.com/albums/p...gyeller167.jpg
motorsports3 04-10-2011 12:47 AM
Sick build!
aw12345 04-10-2011 12:56 AM
Then started making a bracket for the York compressor for the onboard air
http://i131.photobucket.com/albums/p...gyeller173.jpg
Then borrowed a tube bender and started on a roll cage
http://i131.photobucket.com/albums/p...gyeller179.jpg
http://i131.photobucket.com/albums/p...gyeller186.jpg
http://i131.photobucket.com/albums/p...gyeller193.jpg
Then stuck the rear driveshaft in and drove it for the first time down the street
http://i131.photobucket.com/albums/p...gyeller201.jpg
aw12345 04-10-2011 01:16 AM
Then on to hi lining the hood and making some tube fenders
http://i131.photobucket.com/albums/p...gyeller202.jpg
http://i131.photobucket.com/albums/p...yeller2021.jpg
http://i131.photobucket.com/albums/p...yeller2026.jpg
Time for a poser shot lol
http://i131.photobucket.com/albums/p...yeller2030.jpg
http://i131.photobucket.com/albums/p...yeller2032.jpg
Time to get the gearing changed and install the lockers
http://i131.photobucket.com/albums/p...yeller2049.jpg
Once that was successfully concluded I started on the onboard air system
So I made a manifold and got this tank from harbor freight
http://i131.photobucket.com/albums/p...yeller2055.jpg
Once that was all plumbed it was on to some rock sliders
http://i131.photobucket.com/albums/p...yeller2064.jpg
http://i131.photobucket.com/albums/p...yeller2074.jpg
http://i131.photobucket.com/albums/p...yeller2078.jpg
http://i131.photobucket.com/albums/p...yeller2086.jpg
aw12345 04-10-2011 01:20 AM
Became time to tackle the steering box and PCS ram
So took the steering box back out and drilled and tapped it
http://i131.photobucket.com/albums/p...yeller2121.jpg
From there found a place for the reservoir
http://i131.photobucket.com/albums/p...yeller2123.jpg
Mounted the ram
http://i131.photobucket.com/albums/p...ller2125-1.jpg
aw12345 04-10-2011 01:46 AM
Getting closer to the finish
http://i131.photobucket.com/albums/p...yeller2191.jpg
Cleaned up wiring etc under the hood
http://i131.photobucket.com/albums/p...yeller2205.jpg
Time to mess with the center console, the stock stuff had to go to make enough clearance for the shifters and I wanted it gone period
http://i131.photobucket.com/albums/p...yeller2216.jpg
Plenty of room for more switches and idiot lights
http://i131.photobucket.com/albums/p...yeller2222.jpg
On to trying the lockers out
http://i131.photobucket.com/albums/p...yeller2210.jpg
Also in betwixed and between made a rear bumper with some shackle mounts
http://i131.photobucket.com/albums/p...ller2198-1.jpg
The finished product
http://i131.photobucket.com/albums/p...yeller2212.jpg
Time for it's first road trip and shake down
http://i131.photobucket.com/albums/p..._beast_003.jpg
http://i131.photobucket.com/albums/p...yeller2229.jpg
Finally got a trailer to drag it to the trail.
http://i131.photobucket.com/albums/p...yeller2231.jpg
The fenders on the trailer did not clear so out came the plasma and of the came. They are now easily removable
This week's chores were to install a rear anti rock and make an engine and trans skidplate
http://i131.photobucket.com/albums/p...yeller2236.jpg
http://i131.photobucket.com/albums/p...yeller2239.jpg
Well that took eleven months of all my free time and vacation time
So that's all folks I need a break and I am going wheelin
http://i131.photobucket.com/albums/p...chmentaspx.png
http://i131.photobucket.com/albums/p.../DSC046932.jpg
kelso1337 04-10-2011 11:45 AM
Good lord.
That thing is amazing, i love all the custom fab work.
MO2500 04-10-2011 07:15 PM
Looks great Art :thumbsup: It's nice to see it all consolidated together in one thread. I'v been following the build up on "what did you do to your TJ today" thread and the other site you linked too.
Any future plans after wheeling? Looks like a beast as is but there is always something more lol
aw12345 04-10-2011 08:22 PM
For now it's pretty good, will fudge with the rear suspension a little, good thing I drilled extra holes in the brackets I made. On climbing some ledges it wheel hops a bit. We did Clawhammer, Jackhammer including the gatekeeper thing which is pretty darn cool, We could not run Lower Sledgehammer since it was blocked by a broken down Jeep. After finishing Jackhammer we walked down Sledge to see if these folks needed any help. Once we got back to the Jeeps we ran upper Sledge which was way cool might get some pics of that in a bit. Carnage for the day my tiedown straps got cut and the front diff cover peeked back a bit and leaked a little other than that She took her beating without complaints. So overall I am very happy with how the Jeep wheels.
Big Jeeps ride so much nicer on tough trails. Really didn't have any real trouble following my buddy that has his Jeep on 42's
aw12345 04-10-2011 08:24 PM
Originally Posted by kelso1337 (Post 11340932)
Good lord.
Pretty much everything is hand made by me, I bought 2 brackets, the rest I made my self. Very little store bought stuff on my toy nor did anybody else do any work on it
rogerhill 04-10-2011 08:30 PM
I'm in love
aw12345 04-10-2011 08:38 PM
Originally Posted by rogerhill (Post 11343910)
I'm in love
I am not sharing lol
MO2500 04-10-2011 09:00 PM
It shows that you've put a ton of work into it. I'm done buying stuff that I can make. I like the fact that I can be creative and build what I want instead of keeping within the limits of a bolt on product. I certainly respect the amount of fab work that you put into this rig!
Glad to hear it's performing as good as it looks :cheers2:
The time now is 04:41 AM.
