Link to Gus' modest 99 TJ build - Page 4 - JeepForum.com
post #46 of 62 Old 09-04-2012, 08:04 PM
reichard117
2014 JK Wrangler
I don't know if a plasma cutter is what you want unless you cut smaller then grind it out to the right size.. I know I have seen a few people cut their corners for led's I just dont remember how....
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Follow me on Instagram - @thereich
reichard117 is offline
post #47 of 62 Old 09-05-2012, 06:36 AM
janesy86
Pretty sure you can also have whatever company do it, most offer the LED hole as an option.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #48 of 62 Old 09-05-2012, 08:11 AM Thread Starter
gus54
Talked to Jeff. Rokmen's full corners come with the 4.5" tail light holes already cut. They have optional plugs if you have stock tails. So I'm set! Here's a montage video from this weekend of my jeeps first outing.
Just Another Brick in the Wall
Link to my build thread:
gus54 is offline
post #49 of 62 Old 09-05-2012, 03:24 PM Thread Starter
gus54
This is part of the Colorado trail
gus54 is offline
post #50 of 62 Old 09-05-2012, 03:52 PM
reichard117
2014 JK Wrangler
i love the just goose it style.. what are the plans now?
post #51 of 62 Old 09-05-2012, 04:04 PM Thread Starter
gus54
Got the ORFab cage ordered. Then give Rokmen another call for the front upper and lower CAs and full corners. Then MCE fenders and Currie Antirock. That should do.it for a while haha.
gus54 is offline
post #52 of 62 Old 09-09-2012, 11:49 AM Thread Starter
gus54
Finally some action shots from last weekend.
gus54 is offline
post #53 of 62 Old 09-12-2012, 04:42 PM Thread Starter
gus54
Problem: As the weather gets cooler I am going to want to wheel with doors on, but the stock mirrors are imovable. Stuck in the outward position even a pipe wrench couldn't get them to turn in. As huge as these mirrors are it is inevitable that they would get ripped off on the first tree to get in the way, likely doing considerable damage to my half doors as well.
Solution: Utilize my Harley mirrors somehow and remove for wheeling. Except with the doors on I lose the hinge mounting points. So I went to Lowes and bought some 1/2" round steel tube, same diameter as the door hinge. Cut two pieces 1 1/4" long and bevel ground the edges.
I removed the stock mirrors, only breaking one t25 in the process. The tube pieces will be welded on in the area where the stock mirrors were by a guy in our club. Once done a shot of OD green and Voila! Easy removable Harley mirrors all year long with or without doors!
gus54 is offline
post #54 of 62 Old 09-13-2012, 04:32 AM
janesy86
Great idea! I should do that as well.
janesy86 is offline
post #55 of 62 Old 09-13-2012, 08:58 AM Thread Starter
gus54
If you wanted to be able to put your stock mirrors back on as an option you could weld the tube to a small pice of flat stock and drill a hole in the flat piece and bolt it on to the existing bracket using one of the torx bolts. Then remove the entire homemade bracket and reinstall the stock mirrors.
gus54 is offline
post #56 of 62 Old 09-16-2012, 11:40 AM Thread Starter
gus54
Installed the ORFab cage. Nice.
gus54 is offline
post #57 of 62 Old 09-16-2012, 11:43 AM Thread Starter
gus54
gus54 is offline
post #58 of 62 Old 09-16-2012, 11:49 AM Thread Starter
gus54
Had to trim a little plastic off the door surrounds so they would clear the grab handles. Its no weld in full cage but with the behind the dash steel backing plate and cage down plate sandwiching the dash and the floor tie in bolting to the underside of the Rokmen rocker guards i feel pretty confident this cage would hold up well in a roll over. Hope i never have to test it. Also painted the rear of the cage flat black to go with the nice black powder coat ORF puts on.
gus54 is offline
post #59 of 62 Old 09-17-2012, 03:00 PM Thread Starter
gus54
Got the JK lights in the grill. Just waiting on the fenders.
gus54 is offline
post #60 of 62 Old 09-18-2012, 07:52 AM Thread Starter
gus54
Guy in our club welded on some home made tubes to hold my Harley mirrors with doors on.
gus54 is offline
Link for new off road trailer build Gunner017 Jeep Builds 0 11-14-2011 08:39 PM
99 XJ Slow & Modest Build Widerstand Jeep Builds 58 09-30-2011 08:52 PM
HuLuD's 2000 TJ Build Thread (link to OO) hulud44 Jeep Builds 0 01-15-2011 11:02 PM
'93 XJ, some modest mods Keef-Burtons Jeep Builds 2 03-08-2010 06:01 PM
cj build...direct link on the forum tonsoffun_77 Jeep Builds 0 12-03-2009 06:27 PM
