Lil Green Bean - Page 7 - JeepForum.com
post #91 of 178 Old 01-06-2012, 08:27 AM
JJeeper09
Very good documentation, I like this Jeep a lot! Glad to see a thread
JJeeper09 is offline
post #92 of 178 Old 01-07-2012, 08:01 AM Thread Starter
Red_Smoke
Originally Posted by DaFuzz View Post
Dude, everything turned out sooo nice. The two-tone was a bit of a shocker, but it works.
Shocker!?! That's just because you never see two-tone TJ's
Thanks!
2007 WK CRD: DD @ 27mpg, tuned by Keith at GDE
1997 100" TJ: Cummins/NSG370/TeraNomore/37's and leaf springs - Gone!
2008 Rubi Unlimited: Gone!
Smashin' Punkin - 06 Rubi LJ, Cummins QSB3.3, work in progress
IndyORV
Red_Smoke is offline
post #93 of 178 Old 01-07-2012, 08:47 AM
mcannon111
just curious, what were the leaf spring learning curves?
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #94 of 178 Old 01-07-2012, 09:17 AM
Sgt.Fuzz
Thanks!
Mine used to be two-tone........silver/black.
My build:
Sgt.Fuzz is offline
post #95 of 178 Old 01-10-2012, 07:44 PM
mcannon111
smoke have you bent any of your leafs wheeling? and when you're coming off rocks are you worried that you're leafs will bend when hitting it?
post #96 of 178 Old 01-10-2012, 08:19 PM
gribbles
Huh. I need to get on here more often. Lookin good as usual smoke!
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #97 of 178 Old 01-10-2012, 08:29 PM
gribbles
Just thought of this - did you ever do the u bolt flip?
2007 WK CRD
gribbles is offline
post #98 of 178 Old 01-10-2012, 08:30 PM
mcannon111
x2
post #99 of 178 Old 01-11-2012, 02:57 PM Thread Starter
Red_Smoke
Much the same as Imped or Hendrix goes thru with coil+spacer, different coil etc. Being one of the first, as far as I know, to do a spring under TJ leaf conversion, it took some trying of different combinations of spring packs to get the proper height, flex, and resistance to axle wrap whilst still having a durable product.
Bent 'em... oh yeah. Hit rocks on the departure, you bet. Bent from rocks contact... nope. I ran a combo of RE 3.5" XJ springs with stock mains for a couple months and came off a hard vertical climb backwards which bent the main leaf between the axle and the spring hanger. After that it was much more prone to the same failure mode until I went with the OME/stock packs I run today.
Yep, vast improvement. Depending on how much of the extra u-bolt you cut off, it's akin to driving around with an uncut 14 bolt in the rear. With the u-bolt flip, it doesn't get hung up if a rear tire slips off a rock.
IndyORV
post #100 of 178 Old 01-11-2012, 03:47 PM
rkates
1995 XJ Cherokee
Your falling to the dark side, you did a jf build thread
Robert
black xj
IndyORV™
rkates is offline
post #101 of 178 Old 01-11-2012, 10:41 PM
gspup
I thought I saw your jeep in Jp magazine few months ago, so I dug up the magazine and I was wrong. But the color scheme was close. I like your paint job much better...
http://www.jpmagazine.com/featuredve...rks/index.html
gspup is offline
post #102 of 178 Old 01-12-2012, 07:13 AM
gribbles
mine are pretty close but they still hang lower than the diff. What kit did you use?
2007 WK CRD
gribbles is offline
post #103 of 178 Old 01-12-2012, 08:08 PM
nardharv
Build thread turned classified?
nardharv is offline
post #104 of 178 Old 01-17-2012, 06:37 PM Thread Starter
Red_Smoke
Thanks!
It was a RuffStuff swap kit. I trimmed the ubolt extra length but like the flip kit much better.
Ah ya never know. Depends if I want to commit another 6 months of my life to a cold garage floor.
IndyORV
post #105 of 178 Old 01-17-2012, 09:17 PM
kyle_craig
...Depends if I want to commit another 6 months of my life to a cold garage floor.
What's next??
kyle_craig is offline
b3.3 , cummins , custom , diesel , diesel swap , engine swap , indyorv , leaf springs on a tj , two tone
Jeep Metalic Green vs Rescue Green trekkindave Jeep Picture Requests 13 12-08-2011 04:06 PM
1999 Green xj "Green Machine" usafxjer Jeep Builds 8 12-05-2011 05:59 PM
Green TJ with green top or black top Broncbuster Jeep Picture Requests 0 09-19-2010 01:22 PM
Any Hunter Green or dark Green YJs or CJs? jeepjunk Jeep Picture Requests 2 05-28-2009 02:32 AM
Show your drab green, willys, and green Saharas beyondink Jeep Picture Requests 5 01-06-2006 04:26 PM
