Lil Green Bean - Page 4 - JeepForum.com
post #46 of 178 Old 12-05-2011, 08:08 PM
mcannon111
do those shackles come with the rubber bushings, or do you have to buy that separately? i'm guessing they do and that you can just slap them in the btf crossmember hanger?
edit: and are those 1 inch yj lift shackles or stock length? it doesn't say but it falls under the lift category... and have you set up a track bar for the rear?
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #47 of 178 Old 12-05-2011, 08:50 PM
04limegreen
This jeep is amazing no other way to put it!!!!
04 lime green rubicon 35 BFG KM2s, RE LA 4.5", 4.88s, Riddler diff guards, full cage, Corbeau Baja RS seats
Electric Lime Green Jeep Owners #3
04limegreen is offline
post #48 of 178 Old 12-06-2011, 07:08 AM Thread Starter
Red_Smoke
Yep, they come with rubber bushings which you'll use on the BTF crossmember. They are also 1" yj lift shackles which IMO is the longest shackle I would recommend on this swap.
On the track bar, just curious why you would want to do this? Track bars locate laterally, which is rarely used with leaf suspensions since the springs do this. If you're referring to a "traction bar" or "ladder bar".... these are very necessary when doing a "spring over" setup (leafs on top of axle) to prevent spring wrap and pinion angle change. However, I didn't want the lift height of spring over and went spring under axle, which isn't nearly as susceptible to axle wrap. So short answer, no, I don't run any traction bar / track bar links in the rear.
2007 WK CRD: DD @ 27mpg, tuned by Keith at GDE
1997 100" TJ: Cummins/NSG370/TeraNomore/37's and leaf springs - Gone!
2008 Rubi Unlimited: Gone!
Smashin' Punkin - 06 Rubi LJ, Cummins QSB3.3, work in progress
IndyORV
Red_Smoke is offline
post #49 of 178 Old 12-06-2011, 07:09 AM Thread Starter
Red_Smoke
Thanks Lime! It's been my favorite build out of all of them I've done
IndyORV
post #50 of 178 Old 12-06-2011, 10:50 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
What did you do to address the fuel gelling in cold temps?
Your Jeep still gives me a mild chub...
Sent from planet X.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #51 of 178 Old 12-06-2011, 02:05 PM
mcannon111
yeah sorry man i meant a traction/ladder bar, idk why i wrote track haha... but do you get any axle wrap with out it??
thanks for answering all these questions man
post #52 of 178 Old 12-06-2011, 02:14 PM
kyle_craig
It's cool to see a build thread Smoke....Your build has been an inspiration to me
kyle_craig is offline
post #53 of 178 Old 12-06-2011, 05:24 PM Thread Starter
Red_Smoke
Sent from planet X.
Not too much of a concern in the midwest anymore, especially when they change over to 'winter blend' which is a combo No. 1/No. 2 diesel. There are some old timers that still swear you have to run additives.
btw, your Jeep ain't too chabby either
With the stock XJ springs, I did get some level of axle wrap but not enough that I ever broke anything. Now with the OME springs it doesn't wrap at all. You could also get a set of springs with military wrap 2nd leaves to prevent it.
Thanks Kyle. Already pointed a couple guys your way that are looking for something other than the 'way back' spring hangers.
IndyORV
post #54 of 178 Old 12-07-2011, 12:58 AM
2000GrayTJ
Love it, just seems that a small-ish diesel in a Jeep just makes sense . How do you like the 4.10's with 37s? I assume it keeps the rpms fairly low/efficient, I forget where I was reading a 4BT swap where the OP was trying to maintain around 1500 rpms on the highway..gotta love the torque of a diesel
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline
post #55 of 178 Old 12-07-2011, 01:10 AM
justanotherjpr
Awesome build! I love how you build stuff that would take the rest of us days/weeks like it's nothing - "built cage." "Built long arms".
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #56 of 178 Old 12-07-2011, 08:16 AM
04ovrland
sorry if this has already been asked but what did you use for a transmission? are there adapter plates to this motor?
2004 Overland WJ 4.7ho/545rfe/247/d44a
04ovrland is offline
post #57 of 178 Old 12-07-2011, 10:57 AM
mcannon111
so these are the springs you ended up with i'm guessing?? http://www.quadratec.com/products/16090_5054.htm
post #58 of 178 Old 12-07-2011, 02:50 PM Thread Starter
Red_Smoke
The 4.10 and 37's are actually a bit high for this engine at 70mph. Ideally I would run a 3.73 with this trans/tcase combo. As it currently is, I rarely launch in first, and a 4:1 ratio in the tcase makes gears 1-2 unusable offroad. However, the NSG370 has a great ratio spread. It'd be different with an AX15.
In all fairness, I'm just moving this build thread from our private IndyORV board to JF. This build took exactly 6 months from start to finish, and that was working every night and 12 hour days on the weekend. I'm no better than most of you
NSG370. I use an adapter that a friend drew up and machined on CNC. Still debating on whether to offer a kit to the public.
That's correct, those are springs that I use today, with the exception of an extra main leaf. If you're ordering new ones, I would recommend the heavy load ones which may prevent the necessity of the extra leaf. Of course, all depends if your Jeep is set up similiarly to mine (armor, wheelbase, accessories).
IndyORV
post #59 of 178 Old 12-07-2011, 05:54 PM
IAmAmerican
Are you going to tow with it? Why did u choose to put leafs in the rear? (sorry if this question has already been asked)
Nice jeep man!
IAmAmerican is offline
post #60 of 178 Old 12-07-2011, 06:17 PM
91BoD
Wow...
Read the stuff he posts don't just look at the pictures. He's using leafs for the simple fact that he likes them.
Edit:
Originally Posted by First page
The leaf spring swap accomplishes a couple things:
1.) Adjustable 6-9" WB stretch
2.) Easy ride height and spring rate adjustments (add a leaf, lose a leaf)
3.) Side hill stability
And no, I'm not going to argue with anyone about leaf vs. 4-link vs. tri-link vs. your grandma's best buddie's trailing arm setup. This works for me and I like it....
91BoD is offline
b3.3 , cummins , custom , diesel , diesel swap , engine swap , indyorv , leaf springs on a tj , two tone
Jeep Metalic Green vs Rescue Green trekkindave Jeep Picture Requests 13 12-08-2011 04:06 PM
1999 Green xj "Green Machine" usafxjer Jeep Builds 8 12-05-2011 05:59 PM
Green TJ with green top or black top Broncbuster Jeep Picture Requests 0 09-19-2010 01:22 PM
Any Hunter Green or dark Green YJs or CJs? jeepjunk Jeep Picture Requests 2 05-28-2009 02:32 AM
Show your drab green, willys, and green Saharas beyondink Jeep Picture Requests 5 01-06-2006 04:26 PM
