Lil Green Bean - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Lil Green Bean
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 11-18-2011, 02:56 PM   #1
Red_Smoke
Lil Green Bean
Having received so many PM's about my setup, I figured it is time to put some documentation out there. I'll continue to add to this as I have time.
FAQ section:
#1 Where did you get the B3.3 engine?
Ebay! I bought two from an equipment salvage place in NC. They come in a variety of industrial equipment, including skid steers, excavators, power units, water pumps, gensets, etc.
#2 What kind of mileage?
Highest I've calculated is 27mpg on 37" mud terrains at 70mph. Typical is 20-25mpg depending on setup.
#3 What's the horsepower/torque?
My engine was rated at 85hp/220 ft-lb stock. I've since added a different turbo, injector and pump work. 300ftlb is not difficult to achieve.
More to be added at a later date.
Here's how it all started...
This is actually my 5th Jeep build, and going into it I knew what I wanted: LCG, 37's, street friendly, and fuel efficient.
Here's the final specs:
1997 Wrangler 2.5L/AX5 base vehicle
Cummins B3.3T 4cyl diesel
NSG370 6spd
NV241OR Tcase
Ford 8.8 Rear/Detroit/4.10
Rubi 44 front/tube seals/TEN shafts
Rear BTF leaf spring kit with OME Medium XJ springs + one
Front radius arm setup - RE arms, Poly bracketry
Bilstein 5125 12" 255/70 all four corners
Genright armor... everywhere
37" KM2 on WE locks
Poison Spyder Comp cage
Sniper Fab front bumper
BTF rear bumper
Warn 9.5Ti
Custom rear swing-away, body mounted
And so it began... and the pile of parts started to grow:
2007 WK CRD: DD @ 27mpg, tuned by Keith at GDE
1997 100" TJ: Cummins/NSG370/TeraNomore/37's and leaf springs - Gone!
Lil Green Bean build thread
2008 Rubi Unlimited: Gone!
Smashin' Punkin - 06 Rubi LJ, Cummins QSB3.3, work in progress
IndyORV
Red_Smoke is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 02:58 PM   #2
Red_Smoke
IndyORV
Unread 11-18-2011, 03:01 PM   #3
Red_Smoke
Enough of the bolt-on crap. On to the fabrication! For the rear suspension I'm using a Blue Torch rear crossmember with RuffStuff 8.8 swap kit components. The leaf spring swap accomplishes a couple things:
1.) Adjustable 6-9" WB stretch
2.) Easy ride height and spring rate adjustments (add a leaf, lose a leaf)
3.) Side hill stability
And no, I'm not going to argue with anyone about leaf vs. 4-link vs. tri-link vs. your grandma's best buddie's trailing arm setup. This works for me and I like it....
IndyORV
Unread 11-18-2011, 03:05 PM   #4
Billy
very nice. subscribed.
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 03:05 PM   #5
Red_Smoke
For the shackle angle, I ended up targeting 45. Steeper angles cause a rough ride (spring rate increases) and lesser angles cause a mushy feeling in the corners due to the associated decrease in spring rate.
IndyORV
Unread 11-18-2011, 03:06 PM   #6
Red_Smoke
So you get antsy on your diesel project and tear the freakin thing apart with a full tank of gas?
IndyORV
Unread 11-18-2011, 03:08 PM   #7
Red_Smoke
A quick trip to the junkyard yielded the perfect intercooler for the diesel swap. This is a Volvo 740i station wagon IC. Dimension-wise it's near perfect for the stack up in the TJ grill.
Yep, those are the new HD Genright shackles
yeah, she's gonna have a little grocery getter in her
IndyORV
Unread 11-18-2011, 03:11 PM   #8
Red_Smoke
Just had to bolt the new meat on and look at the stance. Remember the tubes will actually be 3" higher than the lower hood line, but to get a level stance I used 3" AEV springs in the front.
IndyORV
Unread 11-18-2011, 05:09 PM   #9
homeboy1991
Subscribed! Looking good!
homeboy1991 is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 05:44 PM   #10
Mazdarx
This should be a awesome Jeep when done, I like where this is going.
www.team1hobbies.com -My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 05:47 PM   #11
Bennettj13
About time smoke.
::[B]SELLING HALF OF MY JEEP[/B]::
[url]http://www.jeepforum.com/forum/f33/?uid=152304[/url]
Bennettj13 is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 06:13 PM   #12
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by Bennettj13 View Post
About time smoke.
X2 One of my Favorite builds of all time.
Now I am just going to creep your build.
Edit: Ok Buddy
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 07:08 PM   #13
LilSteve97TJ
Glad i could be the straw that broke the camels back Interested to see you finish the content. I'm sure it will answer some of my questions about that smoker you got.
www.offroadsc.com
97 TJ
98 Taco
LilSteve97TJ is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 07:58 PM   #14
Sgt.Fuzz
Leafs. Right on.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 08:55 PM   #15
Red_Smoke
About time smoke.
You punks can read this anytime on the club site. Keep your useless banter outta my build
IndyORV
b3.3 , cummins , custom , diesel , diesel swap , engine swap , indyorv , leaf springs on a tj , two tone
