-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   Lil Green Bean (http://www.jeepforum.com/forum/f22/lil-green-bean-1290765/)
Red_Smoke 11-18-2011 01:56 PM
Lil Green Bean
Having received so many PM's about my setup, I figured it is time to put some documentation out there. I'll continue to add to this as I have time.
FAQ section:
#1 Where did you get the B3.3 engine?
Ebay! I bought two from an equipment salvage place in NC. They come in a variety of industrial equipment, including skid steers, excavators, power units, water pumps, gensets, etc.
#2 What kind of mileage?
Highest I've calculated is 27mpg on 37" mud terrains at 70mph. Typical is 20-25mpg depending on setup.
#3 What's the horsepower/torque?
My engine was rated at 85hp/220 ft-lb stock. I've since added a different turbo, injector and pump work. 300ftlb is not difficult to achieve.
More to be added at a later date.
Here's how it all started...
http://i404.photobucket.com/albums/p...e/P4230213.jpg
This is actually my 5th Jeep build, and going into it I knew what I wanted: LCG, 37's, street friendly, and fuel efficient.
Here's the final specs:
1997 Wrangler 2.5L/AX5 base vehicle
Cummins B3.3T 4cyl diesel
NSG370 6spd
NV241OR Tcase
Ford 8.8 Rear/Detroit/4.10
Rubi 44 front/tube seals/TEN shafts
Rear BTF leaf spring kit with OME Medium XJ springs + one
Front radius arm setup - RE arms, Poly bracketry
Bilstein 5125 12" 255/70 all four corners
Genright armor... everywhere
37" KM2 on WE locks
Poison Spyder Comp cage
Sniper Fab front bumper
BTF rear bumper
Warn 9.5Ti
Custom rear swing-away, body mounted
And so it began... and the pile of parts started to grow:
http://i404.photobucket.com/albums/p...t/P5120231.jpg
http://i404.photobucket.com/albums/p...t/P5120232.jpg
http://i404.photobucket.com/albums/p...t/P5120228.jpg
http://i404.photobucket.com/albums/p...t/P5120230.jpg
http://i404.photobucket.com/albums/p...t/P5140237.jpg
Red_Smoke 11-18-2011 01:58 PM
http://i404.photobucket.com/albums/p...t/P5140236.jpg
http://i404.photobucket.com/albums/p...t/P5140238.jpg
http://i404.photobucket.com/albums/p...t/P5140239.jpg
http://i404.photobucket.com/albums/p...t/P5140248.jpg
http://i404.photobucket.com/albums/p...t/P5150251.jpg
http://i404.photobucket.com/albums/p...t/P5150253.jpg
http://i404.photobucket.com/albums/p...t/P5150258.jpg
http://i404.photobucket.com/albums/p...t/P5150261.jpg
Red_Smoke 11-18-2011 02:01 PM
Enough of the bolt-on crap. On to the fabrication! For the rear suspension I'm using a Blue Torch rear crossmember with RuffStuff 8.8 swap kit components. The leaf spring swap accomplishes a couple things:
1.) Adjustable 6-9" WB stretch
2.) Easy ride height and spring rate adjustments (add a leaf, lose a leaf)
3.) Side hill stability
And no, I'm not going to argue with anyone about leaf vs. 4-link vs. tri-link vs. your grandma's best buddie's trailing arm setup. This works for me and I like it....
http://i404.photobucket.com/albums/p...t/P5160274.jpg
http://i404.photobucket.com/albums/p...t/P5160275.jpg
http://i404.photobucket.com/albums/p...t/P5160279.jpg
http://i404.photobucket.com/albums/p...t/P5160281.jpg
http://i404.photobucket.com/albums/p...t/P5220283.jpg
http://i404.photobucket.com/albums/p...t/P5220287.jpg
http://i404.photobucket.com/albums/p...t/P5220289.jpg
http://i404.photobucket.com/albums/p...t/P5220294.jpg
Billy 11-18-2011 02:05 PM
very nice. subscribed. :)
Red_Smoke 11-18-2011 02:05 PM
http://i404.photobucket.com/albums/p...t/P5220295.jpg
http://i404.photobucket.com/albums/p...t/P5220296.jpg
http://i404.photobucket.com/albums/p...t/P5220297.jpg
For the shackle angle, I ended up targeting 45. Steeper angles cause a rough ride (spring rate increases) and lesser angles cause a mushy feeling in the corners due to the associated decrease in spring rate.
Red_Smoke 11-18-2011 02:06 PM
So you get antsy on your diesel project and tear the freakin thing apart with a full tank of gas?
http://i404.photobucket.com/albums/p...t/P5240224.jpg
http://i404.photobucket.com/albums/p...t/P5240226.jpg
Red_Smoke 11-18-2011 02:08 PM
A quick trip to the junkyard yielded the perfect intercooler for the diesel swap. This is a Volvo 740i station wagon IC. Dimension-wise it's near perfect for the stack up in the TJ grill.
http://i404.photobucket.com/albums/p...t/P5270227.jpg
http://i404.photobucket.com/albums/p...t/P5270228.jpg
http://i404.photobucket.com/albums/p...t/P5270230.jpg
http://i404.photobucket.com/albums/p...t/P5280234.jpg
Yep, those are the new HD Genright shackles
http://i404.photobucket.com/albums/p...t/P5280247.jpg
yeah, she's gonna have a little grocery getter in her
Red_Smoke 11-18-2011 02:11 PM
http://i404.photobucket.com/albums/p...t/P5280243.jpg
http://i404.photobucket.com/albums/p...t/P5280245.jpg
http://i404.photobucket.com/albums/p...t/P5280250.jpg
http://i404.photobucket.com/albums/p...t/P5280252.jpg
http://i404.photobucket.com/albums/p...t/P5280251.jpg
Just had to bolt the new meat on and look at the stance. Remember the tubes will actually be 3" higher than the lower hood line, but to get a level stance I used 3" AEV springs in the front.
homeboy1991 11-18-2011 04:09 PM
Subscribed! Looking good!
Mazdarx 11-18-2011 04:44 PM
This should be a awesome Jeep when done, I like where this is going.
Bennettj13 11-18-2011 04:47 PM
About time smoke.
Hendrix 11-18-2011 05:13 PM
Originally Posted by Bennettj13 (Post 12529230)
About time smoke.
X2 One of my Favorite builds of all time. :drool:
Now I am just going to creep your build.
Edit: Ok Buddy :kiss:
:creeper:
LilSteve97TJ 11-18-2011 06:08 PM
Glad i could be the straw that broke the camels back :D Interested to see you finish the content. I'm sure it will answer some of my questions about that smoker you got.
Sgt.Fuzz 11-18-2011 06:58 PM
569 Attachment(s)
Leafs. Right on.
Red_Smoke 11-18-2011 07:55 PM
About time smoke.
:creeper:
You punks can read this anytime on the club site. Keep your useless banter outta my build :kiss:
The time now is 07:55 AM.
