Lifting my 95 YJ - Page 4 - JeepForum.com
post #46 of 245 Old 06-14-2012, 11:58 AM
skyj
the Slight vibration shimmy you are experincing is most likely your torque arm bushing/tranny mount. If you have stock gearing and bigger tires it will most definately be exaggerated by those. I would replace those first and maybe your engine mounts too. It seemed to help with mine but didnt completely go away until I regeared to 4.56 gears. just my .02
build thread:
skyj is offline
post #47 of 245 Old 06-24-2012, 08:17 PM Thread Starter
ziloh22
Thanks man. Yea I'm going to look over the U joints and the tranny mount to make sure everything is good
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #48 of 245 Old 06-24-2012, 08:18 PM Thread Starter
ziloh22
Just some random pics from today
image-4108143438.jpg   image-700095005.jpg   image-2632919392.jpg   image-248728902.jpg
ziloh22 is offline
post #49 of 245 Old 06-24-2012, 09:58 PM
jeepyj13
your yj looks beastly man. btw whats your rocker panel height with the rc lift? I have a slight vibration upon takeoff too and mine is due because my trans mounts are loose and worn. At one point my tcase drop was useless and I ended up getting nasty driveline vibs even at hwy speeds to a point it blew a Ujoint.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #50 of 245 Old 07-04-2012, 11:45 AM Thread Starter
ziloh22
My rockers sit about 28.75 inches off the ground. I have shackles and the 4 inch suspension lift
ziloh22 is offline
post #51 of 245 Old 07-15-2012, 05:12 PM Thread Starter
ziloh22
Added. Magnaflow muffler today. Replaced the tranny mount. The bracket was loose that held the mount in place from the transfer case. But unfortunately I still get the vibration when driving an also the 4wd shifter shakes when I take off. Maybe still look into an sye. Anyway. Love how things are coming along. Still have my tj flares that I have to install when I have time.
ziloh22 is offline
post #52 of 245 Old 07-15-2012, 11:47 PM
tankinyj
Looks good. You might have sold me on 33's when I get my next lift. I was gunna go 4" with a 5/8" booms and try to stuff 35"s under it
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is offline
post #53 of 245 Old 07-16-2012, 07:12 AM
skyj
Did you replace to torque arm bushing also? Usually that's to culprit with the shaking shifter on take off's.
build thread:
skyj is offline
post #54 of 245 Old 08-12-2012, 06:27 PM Thread Starter
ziloh22
Had my top off the other day and it rained lol
ziloh22 is offline
post #55 of 245 Old 08-12-2012, 06:30 PM Thread Starter
ziloh22
So I decided to use the herculiner kit to toughen things up.
Let me tell you. If its done right. This stuff is legit. I prepped the **** out of the floor and did about 3 coats. Love it so far. Going to put the seats back in tmra.
image-868625813.jpg   image-1222454066.jpg   image-3662509455.jpg   image-1182423016.jpg   image-2839708084.jpg
ziloh22 is offline
post #56 of 245 Old 08-12-2012, 07:43 PM
JaShar1976
Did Your RC 4" lift come with all shims and relocation brackets to lower TC and Brake lines, etc. Your Jeep is looking awesome BTW. Keep the updates coming.
JaShar1976 is offline
post #57 of 245 Old 08-12-2012, 07:52 PM Thread Starter
ziloh22
Yes. Came with all that. Didn't use the brake line relocators. Just relocated the lines, and have plenty of room for travel
ziloh22 is offline
post #58 of 245 Old 08-12-2012, 08:01 PM
JaShar1976
Awesome I have been considering the RC lift and I am looking at your beast, and i am sure that is the route I am going to go. How long did it take you to install?
post #59 of 245 Old 08-12-2012, 08:25 PM Thread Starter
ziloh22
Def an great bang for the buck and serves its purpose. I heard the new setups were better than the old so I ran with it and so far I love it and have no complaints. Took me a day to do it only because I took my time, the hardest part was taken the old off. But it def gets my vote.
ziloh22 is offline
post #60 of 245 Old 08-12-2012, 08:54 PM
JaShar1976
sweet I am never in a rush when playing with my rides. I am learning big time with YJ I have always had xj or zj to play with and they are a bit different to build up... keep us updated as you do your jeep its looking sweet man
Lifting 101? bottlerocket91 TJ Wrangler Technical Forum 5 10-07-2010 05:30 AM
Lifting a tj blueyj TJ Wrangler Technical Forum 0 08-15-2010 02:53 PM
Lifting this TJ ???? kooter1 TJ Wrangler Technical Forum 2 06-16-2010 03:26 PM
Lifting Yoink YJ Wrangler Technical Forum 3 02-02-2005 07:37 PM
lifting a YJ racinghoss YJ Wrangler Technical Forum 27 01-27-2005 11:06 AM
