Lifting my 95 YJ - Page 3 - JeepForum.com
post #31 of 245 Old 04-14-2012, 09:15 PM
lutzke21
I have the "hack n' tap" style SYE from RE, I've had no problems with it in the last ~10 years. Cheaper than some methods. Got the CV DS from RE as well.
-Scott
'94 YJ on 35s
Sept '14 YJOTM
July '13 YJOTM
M C L M M
lutzke21 is offline
post #32 of 245 Old 04-14-2012, 11:10 PM Thread Starter
ziloh22
Another thing I want to add is that when I go to take off from 0mph. I get a little shimmy vibration as well. When j bought the jeep the rear track bar mount was cut off. Seems like they put a new exhaust on it and removed the track bar for that reason. Maybe this could also be causing some vibration issues if the rear sways a bit. I was going try and get a new one and mock up some new brackets.
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #33 of 245 Old 04-14-2012, 11:22 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The rear track bar doesn't locate the rear axle, the leaf springs do. Track bars on yj's are useless in stock form and can actually cause problems when you change suspension components like a lift.
Have you checked your ujoints?
I had a bit of a shimmy too until I switched to a cv shaft and SYE. Then it went away. You might be too tall for a TC drop.
Luck Favours The Prepared
Anticanman is offline
post #34 of 245 Old 04-14-2012, 11:35 PM Thread Starter
ziloh22
I did hear rumors of that as well, But yes I think the sye is my smartest option. I'll run it a bit then get the parts I need and eventually do it. The tc has been leaking way more than normal so it's def an issue
ziloh22 is offline
post #35 of 245 Old 04-14-2012, 11:44 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
With vibrations at hand, the "sooner" option doesn't cause more problems later. Ask me how I know.
post #36 of 245 Old 04-14-2012, 11:49 PM Thread Starter
ziloh22
Def agree w you there. Tell me how....
ziloh22 is offline
post #37 of 245 Old 04-14-2012, 11:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Vibration started in the driveshaft because my angles were so far off and it eventually ate my pinion bearing and ate up the seal on the transfer case output shaft. I suspect it had something to do with weakening the transmission torque arm because that broke last week and threw my now cv shaft out off alignment and blew the cv joint in between the ujoints. It's come full circle.
post #38 of 245 Old 04-15-2012, 07:58 PM
DirtRider1357
Did you get the TJ flares yet?
87 YJ, 4.0L, 5speed......sold, 05 LJ Rubicon
"It'll buff out"
"If it moves and shouldn't, use Duct Tape & Zip Ties. If it doesn't move and should, use WD-40 & A hammer"
DirtRider1357 is offline
post #39 of 245 Old 04-15-2012, 08:59 PM Thread Starter
ziloh22
Yea I have em just didn't get to them yet
ziloh22 is offline
post #40 of 245 Old 04-15-2012, 09:03 PM Thread Starter
ziloh22
Took a ride to the beach today. Nothing fell off or apart yet so were good lol.
ziloh22 is offline
post #41 of 245 Old 05-13-2012, 08:15 PM Thread Starter
ziloh22
Added another set of Hellas to the jeep. Mounted on the windshield. Gotta put on my tj flares I got soon too. Coming along. Just bought a house so things are slowing down a bit haha
ziloh22 is offline
post #42 of 245 Old 05-13-2012, 09:10 PM
straightsixjeep
Jeep looks great, cant wait to get a job so I can ditch the 3in BL a add a 4in suspension lift. keep up the good work
straightsixjeep is offline
post #43 of 245 Old 06-13-2012, 11:46 PM
Pru-J
Originally Posted by RockWoRM
THIS is why most of try to tell/warn guys that there is more to lifting a YJ than just the lift. An SYE/CV is the correct way to go, but there is another possible cheaper route you can take. Since you've already done the TC drop, 2 other things you can do.
1. check to make sure your shims (assuming RC included shims) are giving proper pinion angles. standard dline output/pinions need to be in parallel.
2. instal a 1" mm lift. this will tilt the TC output down a little and help the angle and 'might' let the slip move in a little. (but I doubt it would be much if any at all)
Aside from the above, you'll likely be going thru ujoints on a regular basis. Not to mention you now have an increased chance of dropping your dline if you over flex.
This is why an SYE is a better solution.
btw... the SRS has nothing to do with your dline problems. and I'm also not sure why you want to get rid of it. now that you're almost done, drive it a bit and see how it works out. if you have no bump steer and it steers ok, then why change it? it looks to be one of the kits quadtech used to sell... or still may sell. not completely sure. but they got good reviews IIRC.
WRM
What is a sye again??
JEEP: its not what you buy, its what you build.
Pru-J is offline
post #44 of 245 Old 06-13-2012, 11:51 PM
Pru-J
Some progress. 33x12.5 duratracs. Love the way they ride. They're not loud and they ride smooth.
Explain a reversal shackle?? I've never heard of that.. An did you have to change anything up by adding the shackles? I have a 4 in. On mine currently. Thinking about doing a 1in. Shackle lift to clear the tires when flexing.. I'll post pics below. Your looks like it sits up noticeably higher then mine
Pru-J is offline
post #45 of 245 Old 06-14-2012, 10:54 AM
ldso
Have you put new u-joints in the rear driveshaft? They are probably 17 years old and might solve your problem.
My RC 4" lift settled almost 2" after a year of DD and wheeling, and then the driveline angle with the TC drop was pretty much back to stock.
Wish mine was a Sahara, nice YJ bud
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
Lifting 101? bottlerocket91 TJ Wrangler Technical Forum 5 10-07-2010 05:30 AM
Lifting a tj blueyj TJ Wrangler Technical Forum 0 08-15-2010 02:53 PM
Lifting this TJ ???? kooter1 TJ Wrangler Technical Forum 2 06-16-2010 03:26 PM
Lifting Yoink YJ Wrangler Technical Forum 3 02-02-2005 07:37 PM
lifting a YJ racinghoss YJ Wrangler Technical Forum 27 01-27-2005 11:06 AM
