Lifted Wranger X - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Lifted Wranger X
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 03-12-2006, 02:50 PM   #1
willydigger
Thanks for the Upgrade!
willydigger's Avatar
Lifted Wrangler X
Yesterday was an experience. I woke up early in the morning and headed to work for an ample supply of tools and the forklift. I got started around 8:00am. The goal for the day was a Rusty's 2" suspension lift paired with a BL and MML (also Rusty's).
I decided the suspension would be the easiest so that went last. First on the agenda was the BL. It took an hour to get the spacers in.
For the relocation bracket, I decided to go ahead and notch the top as described here http://www.4x4xplor.com/bl.html.
After the notch was in, I noticed the relocation bracket holes didn't align to the linkage bushing or the tub mount. I had to grind out the notch, and egg the four bolt holes so everything would fit. Once everything was ground down it went in without a problem.
Next came the MML. I had a feeling this would be the worst part and I was right. The mounts went in with little trouble but the T-case shifted forward so much that I could not shift. For 2nd, 4th, and R I could not move the shifter back far enough to catch the gear. I eventually added 6-7 washers under the T-case to get everything lined up.
Once the T-case fit right, I noticed the MML pulled the exhaust up to the upper control arm bracket and it would rattle LOUDLY. I eventually bought a dremmel and ground down the bracket. Now it will occasional hit for a moment, usually in 1st or R.
So then came the coil lift. Had a little forklift help.
I was right that the coil lift would be easy. Finally at 3:00pm everything was done.
Here are a few before and after shots.
I'm working on a tire carrier. Once that's done the spare will be swapped with a 33 too.
For the record the tires are 33x1250r15 BFG AT KO. The wheels are Cragar Soft 8 with 4 inch BS. The lift is a Rusty's 2 inch coil (gained 2.5 easy), and Rusty's BL & MML.
Thanks to 4x4xplor.com for the how-to's. Couldn't have done it without you.
Words of advice, do the alignment after the install. I didn't and s#@t myself when I got the death wobble. Invest in a rear trac bar relocation bracket. Even at 2 inches my rear shifted more than I'd like (1" - 1.5" passenger). Have a dremmel handy for when the MML throws everything out of whack.
Last edited by willydigger; 06-27-2009 at 10:36 AM.. Reason: Jesus, just realized 3 years later that I forgot the L in Wrangler!
willydigger is offline   Reply With Quote
Unread 03-12-2006, 04:29 PM   #2
BigPeters
looks great GJ
"...same **** , bigger pile"
[COLOR="RoyalBlue"]Gun Metal Blue Jeep Member #25[/COLOR]
BigPeters is offline   Reply With Quote
Unread 03-12-2006, 07:45 PM   #3
CBlakeNS
Nice work!
CBlakeNS is offline   Reply With Quote
Unread 03-12-2006, 07:57 PM   #4
NotoriousWithag
Nice!, looks alot like my buddy's TJ, only difference is he has 31's and a 5" llift( 2" suspension, 2" body, and 1" engine)
I love it!
..Dude, she won't uh let me suck 'em or touch em!
NotoriousWithag is offline   Reply With Quote
Unread 03-12-2006, 09:33 PM   #5
Rocky5
looks great!! I was gonna ask about the rear track bar....is it REALLY off THAT much? 1" to 1.5"!!!! DAMN!! Did you measure it or is that an estimate? I put a yard stick level on the side of the tire and measured the distance between the stick and the flare.
BTW Nice forklift!!! That's the coolest jack I've ever seen!!
oh and how long did it take you to do a MML and BL? easy?
2006 [COLOR=Yellow]Solar YELLOW[/COLOR] UNLIMITED-6-Speed
-Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines
-Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar.
Rocky5 is offline   Reply With Quote
Unread 03-12-2006, 09:39 PM   #6
WVBLACKJEEP
Looks great !
WVBLACKJEEP is offline   Reply With Quote
Unread 03-13-2006, 05:34 AM   #7
willydigger
The BL was on by 9:30 so about an hour and a half. Most of that was tweaking the relocation bracket.
The MML took me about 4 hours because of the exhaust and Tcase mod's.
Unread 03-13-2006, 12:49 PM   #8
gUanoTJ
For the mml how did you jack up the motor? Did you use a floor jack under the oil pan? I am planning on doing this myself in the next couple weeks and don't know the best way to lift the engine.
gUanoTJ is offline   Reply With Quote
Unread 03-13-2006, 02:10 PM   #9
willydigger
2x4 and oil pan with a regular floor jack. As you lift the motor the rest of the Jeep with go with it until it comes free. Lift slowly and watch for the motor to release. Once you have it in, take a look at your exhaust and the right upper control arm. When I lifted my motor to pulled the exhaust forward. I had to grind down the control arm and bracket. Follow the instructions on 4x4xplor.com and it will go pretty smooth. Do you have a manual? If so make sure your T-case doesn't shift too much forward or it will be impossible to go into all the back gears (2,4,R).
Unread 03-13-2006, 03:32 PM   #10
gUanoTJ
Thanks willydigger I was a little nervous about the oil pan/2x4 thing, but everyone seems to say that it works without issues so i'll be doing it that way too. The jeep looks great by the way. glad it all went on so easy fer ya.
Unread 03-13-2006, 09:39 PM   #11
Rocky5
what did you have to "tweak" with the bracket? Who's bracket did you use?
Unread 03-13-2006, 10:48 PM   #12
Bandit522
Bad a$$ red X
[B]Bandit[/B]
Bandit522 is offline   Reply With Quote
Unread 03-14-2006, 07:08 PM   #13
TXST8tj
didn't happen to do any discoed flexing after the lift and tires went on did you? i'm curious how those 33s are going to stuff.
looks awesome though!
Patrick
Too Tall TJ Build Thread
TXST8tj is offline   Reply With Quote
Unread 03-15-2006, 05:52 PM   #14
BlueJ
That looks damn good!!!! I sure wish I had a forklift to complete my install. Oh well, that is what beer is for to make you forget that it should only take that long (like you did). Damn I need some 33's!!!
Good job! It is so much more rewarding doing things yourself.
Just noticed: Get your wheel weights moved insde, much better looking and will work almost the exact same as outside.
Just noticed again: Remove one wheel at a time and paint where the center caps should be. I used Krylon fusion and it matches the wheels exatcly.
2000 TJ - Patriot Blue
Same stuff as most of ya got. =)
BlueJ is offline   Reply With Quote
Unread 03-15-2006, 06:18 PM   #15
YJ_
I've been looking for a jack like that for years, how much does a jack like that run ya
Jeep looks good man
How do you like those tires? I'm trying to save up for a set of those or some cheap muds, can't make up my mine
94 YJ_
"if ya can't duct it **** it"
[] IIIII []
YJ_ is offline   Reply With Quote
