Kyle's Kurb Hopper - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Kyle's Kurb Hopper
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 09-12-2010, 06:57 PM   #76
kyle_craig
I made a topless road trip down to the Vail area today to pick up a full size spare tire and wheel. It's a Pro Comp Mud Terrain with decent tread and it's already mounted on a wheel that matches mine. I'm happy with it...should suit my needs if I ever have to use it.
First picture is the 30" that it replaced.
Second is the new tire/wheel.
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 09-12-2010, 06:58 PM   #77
kyle_craig
Mounted up!
Unread 09-12-2010, 07:23 PM   #78
ibjeepin95
Nice Jeep! Gives me more inspiration to run 35's on that setup...
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 09-12-2010, 07:26 PM   #79
kyle_craig
I'm on 33s with 2" extended bumpstops in the rear and none in the front. I rub just a little. With bump-stops in the front, I could too!
Unread 09-14-2010, 12:37 AM   #80
RanTJWJ
ta da
Yes two comments commin your way.
1 I am jealous of the moab pics. I was there two times this summer and both times the jeep was on the lift for the latest build. We had fun with the utv rental but you had more fun driving your jeep.
2 looking at where you are in your build, If i had to do all mine over, i would have done the tube fenders/or hyline fenders first then the axles, LA, and such. and your small body lift will prove very useful for maintenance with a high-clearance or aftermarket belly pan.
Looking clean lookin forward to seeing your next mods.
BUILD THREAD
http://www.jeepforum.com/forum/f22/rantjwj-build-form-meets-function-1027219/
5.3 TJ
RanTJWJ is offline   Reply With Quote Quick reply to this message
Unread 09-18-2010, 11:07 PM   #81
kyle_craig
So I think I've come around to deciding a possible "master build plan". I've been doing some serious...SERIOUS drooling browsing the Rokmen site...I might consider moving up to 35s eventually and running the same or slightly less lift than I am right now. I think 4.88 gears, some 35s and tube fenders or hilines might have to be in my future. Right now I've got 33s and 4.10s and to be completely honest, I'm relatively content. Anyone with a 2.5l go from 33s/4.10s to 35s/4.88s? Is it comparable? I'm thinking out loud....But how could I resist after drooling at this thing?
Unread 09-19-2010, 12:49 PM   #82
MattGATRTJ
Kyle, I have 4.88 and 35s. It is comparable to when I had 4.10s & 32s. The 2.5l will always be under powered. But it is plenty of engine for that combination. I would definitely go with 4.88 and nothing less if your running 35s with the 2.5.
MattGATRTJ is offline   Reply With Quote Quick reply to this message
Unread 09-19-2010, 01:06 PM   #83
kyle_craig
I appreciate the opinion! I ultimately want 35s but don't quite have the nohow for a waggy 44 front and rear swap or anything like that.
Unread 09-19-2010, 01:14 PM   #84
Hendrix
TJOTY 2013
Hendrix's Avatar
I have friend running 4.88 for about 8 years now on his YJHP30/D35 locked. You can easily run a HPd30 of LPd30 with 4.88. I would check into a 8.8 or D44 rear. Alot of the things you read online will just steer you way over budget and most people will never really need anything bigger than that. Look around if you have not already. Idaho runs a Lp30/D44,Sean has been wheeling a hp30/d44 for 7 years. Nothing failing but a unit bearing after 70k. Just saying.
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 09-19-2010, 03:11 PM   #85
kyle_craig
I appreciate the input. I probably wont be rushing into anything, but what I need to decide is whether or not It will be locked in the rear. I think the future plans are between a c clip eliminated open rear, an S35 rear, or an 8.8. I'm leaning more toward keeping the 35...but I have plenty of time to decide. Either way the Jeep will eventually be geared to 4.88.
Unread 09-30-2010, 04:12 PM   #86
Cotton
Nice Spare Looks way better than the old little one!
Cotton is offline   Reply With Quote Quick reply to this message
Unread 09-30-2010, 05:01 PM   #87
kyle_craig
Thanks for the spare man! It fits nicely. You get a full size spare for your new MT/Rs?
Unread 10-04-2010, 04:02 PM   #88
Cotton
No problem! Nope still looking for a 35 for a spare...I have a 37 spare on there right now...but it is a little too big.
Unread 10-04-2010, 06:55 PM   #89
kyle_craig
I would imagine! Any plans to regear?
Unread 10-08-2010, 10:04 AM   #90
Cotton
I have some HP D30 4.56 gears in the garage. Just have to save up for lockers, HP housing and Rear gears.
locked , stock appearance , stretched , tj on leaf springs
