Kolten's 1997 ZJ - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Kolten's 1997 ZJ
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 09-30-2013, 04:03 PM   #61
Lincolnwelding
Originally Posted by CareyKimber View Post
Attachment 718705
All Installed
Kimber ZJ Build
Dang dude that thing is looking real mean now. You manage to get her back out into the trails yet?
Would love to see some pictures of it in the trails now
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline   Reply With Quote Quick reply to this message
Unread 09-30-2013, 11:58 PM   #62
CareyKimber
Havnt trailed it yet need some limiting straps so I dont use my shocks as such. Then ill post tons of pics this winter since I live in alaska.just keep an eye on my build thread shouldnt be long.
http://www.jeepforum.com/forum/f22/kimber-zj-build-1626817/
CareyKimber is offline   Reply With Quote Quick reply to this message
Unread 10-28-2013, 06:59 PM   #63
KoltenZJ
Sorry for the lack of updates. I haven't done much other than add the new Headlights and HIDs. Took 'er off road over the weekend and misjudged the depth of some water and ended up sucking in water through my intake and hydro locked my engine, ended up with a bent push rod. Gonna be fixing it up and should have it running by the end of the week. I'll post pics soon!
[CENTER][COLOR="Red"]*1997 Jeep Grand Cherokee Limited
[COLOR="Black"]3.5" Rough Counrty Lift, 265 75 r16 BF Goodrich All Terrain TA KO Tires[/COLOR]
[/COLOR][COLOR="Green"]Check out my build thread![/COLOR]
[url]http://www.jeepforum.com/forum/f22/koltens-1997-zj-1560500/[/url][/CENTER]
KoltenZJ is offline   Reply With Quote Quick reply to this message
Unread 11-03-2013, 10:30 AM   #64
KoltenZJ
I ordered sway bar disconnects as well as 2" Coil spacers to add on to my 3.5" suspension lift. Adding on shock boots today and gonna continue trying to get her running 100%
No bent rod. Unsure about the actual problem but she is running. Flushing the engine today and letting her sit with the oil pan open for a day or two to let everything run out, hopefully it's just the water in the oil causing the lifters to tick but it could also be a bent valve. Last resort would be a head rebuild.
Updates to come!
Unread 11-04-2013, 08:11 PM   #65
riot1987
Do you have adjustable control arms? You may run into pinion angle issues at 5.5" w/o adjustables. What about shocks? Track bars?
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2013, 08:24 PM   #66
KoltenZJ
No I don't. My buddy is running the same setup and he says it's all running the same as it did at 3.5"
Adj track bar soon to come.
Shocks should be ok.
Unread 11-05-2013, 10:47 PM   #67
zacko-zj
What engine is in it?
zacko-zj is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 10:49 PM   #68
KoltenZJ
Originally Posted by zacko-zj View Post
what engine is in it?
5.2
Unread 11-08-2013, 01:38 PM   #69
KoltenZJ
I'll also be doing a T-Case drop when I put on the spacers.
Unread 11-08-2013, 01:42 PM   #70
Lincolnwelding
Thats a bummer about the water in your engine man. Hopefully rebuilding your head isnt going to be meeded.
Post some pictures once you get your coil spacers on it!
WJC #292
Unread 11-08-2013, 01:48 PM   #71
KoltenZJ
Yeah got all the water out by flushing the engine multiple times hoping the ticking was just the water making my lifters stick but it's still ticking. Possibly a flat cam. Still working on diagnosing the dang thing. I'll probably buy a new head instead of rebuilding it if it did need it. I need to get it back on the road asap so a rebuild is incredibly inconvenient.
On the plus side I got my sway bar disconnects in the mail and can't wait to throw them on! Also gonna be getting a snorkel soon.
Updates to come!
Unread 11-08-2013, 05:36 PM   #72
riot1987
A tcase drop isnt needed on ZJ's. It kills your hard earned clearance. Plus the drive lines on these jeeps are long enough that they are not necessary. Get a set of adjustable arms and you will not need a drop.
Build thread^^
Unread 11-09-2013, 03:09 AM   #73
KoltenZJ
Awesome thanks!
Unread 11-09-2013, 08:43 AM   #74
zacko-zj
Don't bother trying to rebuild the heads they are almost always cracked even without taking on water. Plan on a little more than $300 each.
Unread 11-10-2013, 02:41 AM   #75
KoltenZJ
I'm more than likely gonna buy a new head if it needs to be rebuilt. Save time and money.
