kingcat's yj build - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > kingcat's yj build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 05-20-2012, 07:02 PM   #31
kingcat400
got the other fender done
mounted my corner lights front and rear
then took it outside and blew it off.
than rolled it in the booth
this is how it is now.
planing on paint tomorrow hopefully.
kingcat400 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2012, 07:53 PM   #32
BMPP
I was thinking the same thing about the garage. Front axle looks great.
BMPP is offline   Reply With Quote Quick reply to this message
Unread 05-21-2012, 06:29 AM   #33
Hghgrad
Looking good. Going to stick with black?
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline   Reply With Quote Quick reply to this message
Unread 05-21-2012, 09:28 AM   #34
kingcat400
ya black. we were going to go silver but just don't have the time. so we are just spraying it with PPG DBC base clear black. it is just a quick paint job so how it comes out of the the booth is what it gets. no flow coat, no rubbing.
Unread 05-22-2012, 09:45 PM   #35
kingcat400
well its black. damn i love black when its clean.
dad spraying first coat of sealer
sealer done
got the base down
and clear
all untaped
close up of the drivers fender. (remember this was just a quick paint job so its not perfect)
Unread 05-24-2012, 05:29 PM   #36
Hghgrad
Looks good for a quick paint job. Looks like you did a really good job with the prep.
Unread 05-26-2012, 05:02 PM   #37
kingcat400
Got it done in time.
Sent from my DROID X2 using JeepForum
Unread 05-28-2012, 03:22 PM   #38
kingcat400
went and did some wheelin this weekend and took it for the shakedown run. i also played in some gravel pits but never stoped to shoot some pics
Unread 05-28-2012, 08:19 PM   #39
Louie4
Powah Injanir
Louie4's Avatar
Looking great! Pretty good flex for the brand new lift springs. I bet it will get better after the next few trips.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2012, 08:18 AM   #40
kingcat400
OK. so now that i do not have the jeep here to work on progress will slow as i have to bring parts home to work on them. I brought the bumper home to finish it and have started to work on the led lightbar.
This is just the prototype to see how the housing will dissipate the heat created by the leds. I may just finish this one and use it as a reverse light. The tape is temporary as i have not made the front lens holder yet. In theory it should be as bright as a dually with half the amount of leds.
Unread 06-25-2012, 06:16 AM   #41
kingcat400
OK so the plan this weekend was to go upnorth put on the rear tube flairs, safari top, new steering shaft and go wheeling.
Well we had an issue got there Saturday morning and went to start the jeep. and NO. narrowed it down to the fuel pump, so we drove a half hour away to get a pump. when we went to install the sending unit in the tank. it would not fit. it so happens that the whole bottom of the tank is bent up. not the skid just the poly tank. we figure it is from the ethanol in the gas causing the tank to get soft and move out of shape.
So it looks like i am going to look for a new tank.
The good of the weekend. got the smittybuilt rear xrc tj flairs on, new bestop safari top on and put in the new steering shaft in. so the weekend was not all bad. i will post some pictures of the jeep in summer mode when i get home.
Unread 07-14-2012, 09:17 AM   #42
kingcat400
sorry it took so long. i am going tonight to pick up the new tank.
new tj tube flairs and safari along with some stickers
i also picked up a tj sound bar. now i just need to decide on a amp and new headunit. this one sucks.
Unread 07-14-2012, 11:11 AM   #43
sdotcarter
Dude, awesome work man, love the Fab skills. Beautiful Jeep.
sdotcarter is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 08:55 AM   #44
kingcat400
got upnorth this weekend and installed the new tank and sending unit and still no fuel. turns out i got the dreaded computer issue. so i am going to pull the computer out an take it home and put it on the surgery time.
aside from that issue we still got to drive it. met up with our friends who just bought a 91 2.5 and went to some sand hills late last night. the jeep took the hills and deep sand good. the 10.5 km2's gripped the send good. as for our friends who had 12.5 sst's they had some trouble. but it was fun. i took some pictures but they all turned out black as it was pitch black out.
Unread 07-22-2012, 08:57 AM   #45
kingcat400
