kingcat's yj build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > kingcat's yj build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 04-21-2012, 09:23 PM   #16
kingcat400
todays update is
i will post pics tomarrow of the huge progress
kingcat400 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 07:56 PM   #17
kingcat400
well i had a good weekend
got it back on the ground and rolling with the tub bolted on with the new poly mounts
then wheeled it outside
a look at the rust. the floor is only bad in the drivers side
had to pull the column to change the bearing on the end
got the patch in the floor and started in the side with fixing the brace
Unread 04-24-2012, 06:47 AM   #18
kingcat400
i finished getting the patch in the side. with a little more grinding it will be ready for filler and blocking. i also got the 8.8 stripped and ready to get set in so i can get some measurements to send to tom woods for a custom shaft and sye. i plan on setting the axle 1" to the rear to get some stretch.
patch in.
the axle took some persuading
but got it done. once the perches are welded on i am sending it to get blasted.
Unread 04-24-2012, 08:37 PM   #19
kingcat400
well i got the 8.8 set and tacked in. it is within 1/32" in all directions. i set the pinion also and am ready to measure for the cv shaft.
i also milled the spring plates to accept the stretch
ready
its in and tacked
remember i said the yj would have some led fun
this is just a teaser of whats to come. it will have 6 circles not 2
think 5000 lumens!!!! with only 6 leds.
Unread 04-26-2012, 08:35 AM   #20
kingcat400
well i took a step backwards. i decided to take the shims out if the leaf packs. so i had to cut the tacks on the perches and redo them.
got the shock mounts tacked also.
i flexed it out to make sure the shocks would clear.
a little better than last time.
this is what i am using to weld the 8.8 up.
Unread 05-04-2012, 09:21 PM   #21
kingcat400
got some work done in the last week i also got some cool stuff for the heep.
got the bodywork done in the drivers side.
then pulled the 8.8 to finish weld it
i also got the front done. broke my pitman arm puller
painted the box
got it installed
this made the job much easier.
but i broke the ps tank so i ordered another from summit.
got some good stuff in the mail also.
tom woods custom shaft an aa sye kit.
then up to today i got the passenger side started. i also got the rearend painted.
Unread 05-05-2012, 07:08 AM   #22
Hghgrad
Looks like its coming along. Doing a nice job on the body work.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline   Reply With Quote Quick reply to this message
Unread 05-12-2012, 09:14 PM   #23
kingcat400
it is coming together good.
got the rearend in and mounted
made a cover for the abs hole
installed the sye. all went good.
got it installed.
than painted and installed all the calipers
made the harness to still have the 4x4 light work with the disco eliminated
installed the new ps tank
installed new speakers. kicker ds460 in front an pioneers in the rear.
Unread 05-12-2012, 09:25 PM   #24
kingcat400
made some swaybar discos out of the new links.
turned up a new shift knob
started to design a bumper
steel came in. for tube fenders, tube doors and bumpers.
plan to draw the bumper in cad and take it to my pld highschool and cut it on there plasmacam cnc plasma cutter
i lat the jeep set for a fer days and this is the outcome #*$#($*#.
and the inside is mostly empty so that is not the issue. calling quadratech monday.
Unread 05-12-2012, 10:15 PM   #25
Hghgrad
Mine sits 1/2" lower on the drivers side also.
Ive gotta run over to parts galore and look for a 8.8 one of these days. Shooting for 35's by the end of the summer and I dont think the d35 will like that much at all.
Unread 05-13-2012, 06:52 AM   #26
kingcat400
there is a guy in trenton that has racks of them in his garage. some are resealed and gone trough for like $350.
Unread 05-15-2012, 07:05 PM   #27
kingcat400
today ordered 4 33-10.5-15 and 4 m/t 15x8 classic locks. also got started on the tubefenders.
Unread 05-15-2012, 07:56 PM   #28
karlo
Great build, man. Can't wait to see the outcome.
karlo is offline   Reply With Quote Quick reply to this message
Unread 05-16-2012, 10:03 AM   #29
Hghgrad
Can't wait to see how the tube fenders turn out. Thinking about adding that to the list of "to do" before winter.
Unread 05-17-2012, 08:19 PM   #30
kingcat400
on Monday i got a tire to test fit for clearance. damn cant wait for my tires to come in.
these are not what i am getting. i am getting km2's and m/t classic locks
also got some work done on the fenders. had the tube bent by a local chassis builder
brushed dp90 on all the welds to seal them up.
hope to get the jeep in prime tomorrow and painted this weekend. i am also going to my old high school tomorrow to cut the bumper plate and the rear booms.
