King Cobra - JeepForum.com
post #1 of 4 Old 02-17-2016, 04:46 PM Thread Starter
CLR2222000
King Cobra
Hey this is Cory i am 15 so this build will be a very slow work in progress I have recently got a 2000 TJ and it is a big project a short list of what's wrong with it is the motor is blown and its a conversion from a 4 cylinder so the first issue is finding a motor also the u joints in the front axle shafts are bad the heater is bad rust issues on the frame and fenders and that's just a little bit of what's wrong with it
IMG_20160129_180535_414.jpg   IMG_20160129_180524_685.jpg   IMG_20160119_182512_594.jpg   IMG_20160119_182451_254.jpg
CLR2222000 is offline
post #2 of 4 Old 02-17-2016, 07:26 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
It's a jeep!
Welcome to the club.
***Chris***
chris87xj is online now
post #3 of 4 Old 02-21-2016, 07:47 PM Thread Starter
CLR2222000
Well we figured what motor was in it and got a 1999 Cherokee motor with the ac compressor to be used as motor driven onboard air and an acdelco alternator cause the one that was on my jeep was frozen and we got a new clutch to get out of the way while we have everything else apart and both front u joints were bad so we replaced them and the driver side went in perfectly but the top calipar bolt was missing cause the hole is striped out and the passenger u joint took two trys before we realized the yoke was bad so we ground it down and it worked but two u joints had been broke before the problem was fixed
IMG_20160220_223653_717.jpg   IMG_20160220_223625_755.jpg   IMG_20160216_132902_157.jpg   IMG_20160216_132851_679.jpg   IMG_20160216_132549_291.jpg
post #4 of 4 Old 03-30-2017, 01:37 PM Thread Starter
CLR2222000
Okay so it's been a while since I have posted on this thread I forgot I had it honestly but I have made a fair amount of progress on my Jeep I modified the suspension off of a 2013 JKU 10th Anniversary Rubicon and put it on my Jeep it got me 4 inches of lift in the rear and 2 inches of lift up front so I put a 1 inch puck to try and level it out a little more I also fozzy locked the rear diff the picture shows kind of what I did for the fozzy and the flex picture is about 32 inches with the front sway bar connected so I'm not sure what I am getting completely out if it but it works and rides great
IMG_20160918_162123221_1490901520757.jpg   IMG_20160918_194415461_1490901559612.jpg   IMG_20160911_202522107_1490901597847.jpg   IMG_20160922_082007504_1490901619975.jpg   IMG_20170321_180054529_HDR_1490901812268.jpg
IMG_20160922_150047438_1490901938331.jpg   IMG_20160922_082016183_1490901973137.jpg
