kauaijeepclub's 1999 XJ build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > kauaijeepclub's 1999 XJ build
Bds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 12-20-2014, 08:35 PM   #1
KauaiJeepClub
Hi Everyone. Ill try and post my works as it happens. I am in college and so money is a bit tight. Coupled with the Jeep club I started, money is even tighter.
Anyway here is the XJ when I first got it in February. Went out the next weekend and got it muddy.
KauaiJeepClub is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 08:39 PM   #2
KauaiJeepClub
Added Light Bar
I added the light bar. Needed something to help with lighting up the camp site when I arrived at night to setup.
Unread 12-20-2014, 08:51 PM   #3
KauaiJeepClub
Bull bar and more light. Also rust
It still looked too boring for me.All of this work took place over 6 months.
I found this bull bar on Craigslist. Said it was for a Comanche. Turns out it wasn't. I ended up making brackets and having a friend do some welding for me. I also lifted it 4 inches (with full leaf springs, coils, and longer lower control arms), installed sway bar disconnect and put on some better tires. Also replaced the headliner and repaired the speaker wiring. All new kicker 6.5" speakers
Also added a sub in the rear and built an enclosure.
Found a small hole in the floorboard. Ended up replacing the whole pan. Then coated everything I could in POR-15.
Unread 05-10-2015, 05:39 PM   #4
KauaiJeepClub
Updates
Been a while since I posted. Heres what I have done since.
In order of Pics:
  1. Underhood Light from a Chevy. Its the little things, right?
  2. Added a CB and new Chro-mo track bar
  3. New Bumper and Winch
  4. New Bull Bar
  5. Removed the perpetually graying plastic trim
Unread 05-10-2015, 05:43 PM   #5
KauaiJeepClub
I forgot to take pictures, but I put in a new radiator, fan clutch, and added a trans cooler as well
