Kate's '05 Unlimited Rubi "learning process" - Page 52 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Kate's '05 Unlimited Rubi "learning process"
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 02-28-2013, 07:19 AM   #766
KateKGB
Originally Posted by janesy86 View Post
Novak shifter isn't for the trans, its for the transfer case. Supposedly is a huuuge improvement. I just ordered one yesterday, since I'll be doing a tummy tuck soon and will want to do it at that time.
Ohhh, ok. Well- just ordered $900 worth of A to Z swag... but next month I will just order the BL, MML, belly up skid and Novak. That should keep me plenty busy.... and plenty broke.
[COLOR="Teal"][SIZE="4"][URL="http://www.jeepforum.com/forum/f22/kates-05-unlimited-rubi-learning-process-1426763/"] Chicks are allowed build threads here, right? [/URL][/SIZE][/COLOR]
[COLOR="Sienna"]
[SIZE="4"]'05 Unlimited Rubicon - Sahara Edition #431[/SIZE][/COLOR]
[B]We are the diamonds that choose to stay coal
A generation born, to witness the end of the world[/B]
KateKGB is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 07:42 AM   #767
G Beasley
The Novak shifter is amazingly smooth. It should have been there from the factory.
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 07:44 AM   #768
redrelyt12
Pre killed monkeys available , pm me for details.
Gets me every time!
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 11:31 AM   #769
olysteve
The first gear issue is something seperate, but if you do the mml and body lift like I did and can eliminate the transfer case drop, then the issues with 2nd and reverse should be taken care of. BUT, beware of driveline vibration from too much angle. I was pleasantly surprised that I didn't have an issue.
The Novak shifter for the transfer case does make shifting in and out of 4 wheeel drive very smoooth. If you are headed towards a tummy tuck I think it's almost mandatory.
Also a sye is needed for a tummy tuck, along with a bunch of other things. So, yes that should keep you busy with projects for a while.
olysteve is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 11:32 AM   #770
tsstoudt
Web Crawler
tsstoudt's Avatar
I couldn't agree more. 👍
ΜΟΛΩΝ ΛΑΒΕ
tsstoudt is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 11:50 AM   #771
redrelyt12
It's a rubicon, so she doesn't need it. Rubicons have fixed flange rear outputs.
Unread 02-28-2013, 11:52 AM   #772
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Another one of those things that works just fine for me from the factory.... maybe it's just that I don't know what i'm missing!
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 12:05 PM   #773
KateKGB
That's what I had thought - thanks Tyler!
Mine works alright- sometimes I do have to give it a bit more of a tug than I would like. Since it would be something I will probably do down the line- I might as well do it while I am in there.
[COLOR="Sienna"]
Unread 02-28-2013, 12:34 PM   #774
gst95dsm
gst95dsm's Avatar
You just can't resist, can you???
Unread 02-28-2013, 03:48 PM   #775
KateKGB
No. I am not one bit ashamed to say I cant resist improving Alice wherever I can. And my profession dictates that I must do it efficiently.
[COLOR="Sienna"]
Unread 02-28-2013, 04:23 PM   #776
midnight_f150
How difficult of a conversion is it? I absolutely crave a drop down tailgate. One of the few things I miss about a truck.
It looks really easy to do. But I wont know till I do the swap. Here are some links to swap
http://www.jeepforum.com/forum/f9/cj...iteup-1256848/
I'm use these style of latches
http://www.jeepforum.com/forum/f9/lo...wners-1007833/
Sarah has a nice wirteup in her build and she use cam locks
http://www.jeepforum.com/forum/f22/m...-lady-1183495/
Which tummy tuck skid will you be going with?
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 06:03 PM   #777
gst95dsm
gst95dsm's Avatar
Haha, I was more referring to the innuendo "I" read into your sentence..... you're good even when you're not trying. Damn girl!
Unread 02-28-2013, 06:26 PM   #778
G Beasley
Gets me every time!
How many would you like to order ?
The linkage seems almost archaic once you install the cable setup .
See above
Unread 02-28-2013, 06:44 PM   #779
Sundowner
I have it on the best authority that the sudden demand in pre-killed monkeys far exceeds the current supply...
If it's worth doing, then it's worth [I]over[/I]doing.
The build, the gear, and the mileage: [URL="http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/"][B]The Wasteland Survival Guide[/B][/URL]
Sundowner is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 06:49 PM   #780
G Beasley
I suck at forecasting sales ...
2005 , currie , rubicon , sahara , unlimited
