Kate's '05 Unlimited Rubi "learning process" - Page 140 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Kate's '05 Unlimited Rubi "learning process"
BDS suspension IS AVAILABLE at Rockridge4wd!!!The ULTIMATE "Selectable" Locker System! BroughEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-28-2013, 04:35 PM   #2086
midnight_f150
Originally Posted by KateKGB View Post
I'm hoping that with a nap I'll feel good enough to run to Lowes and/or sears to get a hole saw to get my slider on.
A hole saw? What do you need a hole saw for to install a set of sliders.
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 07-28-2013, 04:55 PM   #2087
KateKGB
The a to z wheel well to wheel well versions require you to drill an access hole to get the rearmost bolt on. I was thinking the extra protection would be worth it but now I'm thinking Tyler had the right idea.
[COLOR="Teal"][SIZE="4"][URL="http://www.jeepforum.com/forum/f22/kates-05-unlimited-rubi-learning-process-1426763/"] Chicks are allowed build threads here, right? [/URL][/SIZE][/COLOR]
[COLOR="Sienna"]
[SIZE="4"]'05 Unlimited Rubicon - Sahara Edition #431[/SIZE][/COLOR]
[B]We are the diamonds that choose to stay coal
A generation born, to witness the end of the world[/B]
KateKGB is offline   Reply With Quote Quick reply to this message
Unread 07-28-2013, 05:43 PM   #2088
midnight_f150
Can you post some pictures when you do this mod? My Rokmen slider are WW2WW and I didn't need a hole saw. I can't picture why you would need to cut a hole with hole saw.
Unread 07-28-2013, 05:57 PM   #2089
KateKGB
Absolutely. I actually plan to document this mod well since the instructions are a tad sparse. I plan to see of course, if I can do it without cutting into the body. Where is your rearmost fastening bolt located? How is the hardware secured?
[COLOR="Sienna"]
Unread 07-28-2013, 07:39 PM   #2090
tdavid14
If I can jump in here, my ww2ww Genrights are nutserts at the blind areas.
Sent from my SPH-D710 using JeepForum
tdavid14 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2013, 06:04 AM   #2091
KateKGB
Meaning that you also had to cut into the tub to get access?
[COLOR="Sienna"]
Unread 07-30-2013, 06:40 AM   #2092
janesy86
With nutserts you wouldn't need to cut an access hole. They are just like the ones that the stock rubi sliders use to attach, just a bit bigger.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
[URL="http://www.jeepforum.com/forum/f22/janesys-03-rubicon-build-1358239"]Hylined '03 Rubi Build[/URL]
[URL="http://www.wm4x4.com/forums/"]Western MA 4x4[/URL]
janesy86 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2013, 07:01 AM   #2093
KateKGB
Oh, I see now. I wonder if I could find a proper sized nutsert and do it that way instead of cutting the tub.
[COLOR="Sienna"]
Unread 07-30-2013, 11:09 AM   #2094
tdavid14
Genright sells them, but I'm sure you can local source.
Unread 07-31-2013, 04:23 PM   #2095
AndyE
I'll just leave these right here...
Build Thread The Ballad of a TJ
JF Rubicon Trip 2014
AndyE is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 06:48 AM   #2096
KateKGB
Thanks Andy!
I like the "well... she made it through..." at the end.
Ill try to get the one that Mike took from the other side where you can see how high the water was in that deep spot.
[COLOR="Sienna"]
Unread 08-01-2013, 12:20 PM   #2097
NuclearRedneck
Junior Member
Good to see you out enjoying your Jeep!
NuclearRedneck is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 03:01 PM   #2098
KateKGB
I enjoy my jeep everyday - even if its just on my way to work or the grocery store
[COLOR="Sienna"]
Unread 08-02-2013, 12:33 AM   #2099
AndyE
Question Kate, when you reattached your rear view mirror did you use store bought epoxy, or did you use a home brew special recipe from work?
Unread 08-02-2013, 06:04 AM   #2100
KateKGB
... I may have borrowed a UV cured plastic to glass bonder.
However- an epoxy should work just as well. Well - as well as you need it to for the application. I think I could put the jeep on the sun or hang an elephant from the mirror now and the windshield would be damaged first.
Also - my hopeful plan for when I get out of work is to get started on getting the sliders on. Fingers crossed.
[COLOR="Sienna"]
2005 , currie , rubicon , sahara , unlimited
