Kate's '05 Unlimited Rubi "learning process" - Page 140 - JeepForum.com
post #2086 of 2831 Old 07-28-2013, 03:35 PM
midnight_f150
Originally Posted by KateKGB View Post
I'm hoping that with a nap I'll feel good enough to run to Lowes and/or sears to get a hole saw to get my slider on.
A hole saw? What do you need a hole saw for to install a set of sliders.
midnight_f150 is offline
post #2087 of 2831 Old 07-28-2013, 03:55 PM Thread Starter
KateKGB
The a to z wheel well to wheel well versions require you to drill an access hole to get the rearmost bolt on. I was thinking the extra protection would be worth it but now I'm thinking Tyler had the right idea.
'05 Unlimited Rubicon - Sahara Edition #431
We are the diamonds that choose to stay coal
A generation born, to witness the end of the world
KateKGB is offline
post #2088 of 2831 Old 07-28-2013, 04:43 PM
midnight_f150
Can you post some pictures when you do this mod? My Rokmen slider are WW2WW and I didn't need a hole saw. I can't picture why you would need to cut a hole with hole saw.
post #2089 of 2831 Old 07-28-2013, 04:57 PM Thread Starter
KateKGB
Absolutely. I actually plan to document this mod well since the instructions are a tad sparse. I plan to see of course, if I can do it without cutting into the body. Where is your rearmost fastening bolt located? How is the hardware secured?
KateKGB is offline
post #2090 of 2831 Old 07-28-2013, 06:39 PM
tdavid14
If I can jump in here, my ww2ww Genrights are nutserts at the blind areas.
Sent from my SPH-D710 using JeepForum
tdavid14 is offline
post #2091 of 2831 Old 07-30-2013, 05:04 AM Thread Starter
KateKGB
Meaning that you also had to cut into the tub to get access?
KateKGB is offline
post #2092 of 2831 Old 07-30-2013, 05:40 AM
janesy86
With nutserts you wouldn't need to cut an access hole. They are just like the ones that the stock rubi sliders use to attach, just a bit bigger.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #2093 of 2831 Old 07-30-2013, 06:01 AM Thread Starter
KateKGB
Oh, I see now. I wonder if I could find a proper sized nutsert and do it that way instead of cutting the tub.
KateKGB is offline
post #2094 of 2831 Old 07-30-2013, 10:09 AM
tdavid14
Genright sells them, but I'm sure you can local source.
tdavid14 is offline
post #2095 of 2831 Old 07-31-2013, 03:23 PM
AndyE
I'll just leave these right here...
Build Thread
AndyE is offline
post #2096 of 2831 Old 08-01-2013, 05:48 AM Thread Starter
KateKGB
Thanks Andy!
I like the "well... she made it through..." at the end.
Ill try to get the one that Mike took from the other side where you can see how high the water was in that deep spot.
KateKGB is offline
post #2097 of 2831 Old 08-01-2013, 11:20 AM
NuclearRedneck
Good to see you out enjoying your Jeep!
NuclearRedneck is offline
post #2098 of 2831 Old 08-01-2013, 02:01 PM Thread Starter
KateKGB
I enjoy my jeep everyday - even if its just on my way to work or the grocery store
KateKGB is offline
post #2099 of 2831 Old 08-01-2013, 11:33 PM
AndyE
Question Kate, when you reattached your rear view mirror did you use store bought epoxy, or did you use a home brew special recipe from work?
Build Thread
AndyE is offline
post #2100 of 2831 Old 08-02-2013, 05:04 AM Thread Starter
KateKGB
... I may have borrowed a UV cured plastic to glass bonder.
However- an epoxy should work just as well. Well - as well as you need it to for the application. I think I could put the jeep on the sun or hang an elephant from the mirror now and the windshield would be damaged first.
Also - my hopeful plan for when I get out of work is to get started on getting the sliders on. Fingers crossed.
KateKGB is offline
2005 , currie , rubicon , sahara , unlimited
