Justin's 95 Rio Grande - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Justin's 95 Rio Grande
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 08-10-2011, 01:18 PM   #1
jeepster1407
When i first pruchased my jeep at the age of 15 it was totaled
The PO mush of hit something really hard with the driver side front tire to break the leaf spring, push the front axle back, bend the driveshaft, bust the t-case, ect
I fixed all that, took it to get inspected and by the time i was 16 had a dependable DD YJ!
I quickly began Wheelin' with some buddies and knew mods were coming. First was a 3.5" superlift and some 33"s to go along with the 2" body lift the jeep had on it when i purchased it.
I wheeled like this for a while till i found a smokin deal on a set of used axles (currently under the jeep)
(RIP Tellico)
Next i Got a call from someone with some brand new 37" Irok's that just were to "small" for his liking so i quickly purchased those along with a Sye kit and longer shackles for some much needed lift.
Then somewhere after this i got a winch different tops, doors tj flares... yadda yadda. that puts me where im at today 6 years later.
A couple months ago i purchased a 79' F-250 HP44 set up with 5.13's, lock rite, cross-over steering, warn hubs, Ten Factory Chromoly shafts, ect for the front, and yesterday I purchased a matching 79' F-250 rear Dana 60 set up with 5.13's, Full spool, Disks, and Yukon Chromoly shafts. This will all be going in this winter. hopefully. (no pics of the front yet)
jeepster1407 is offline   Reply With Quote Quick reply to this message
Unread 08-10-2011, 05:00 PM   #2
jeepster1407
Will post pics of the front tomorrow
_________
My Thread - http://www.jeepforum.com/forum/f22/p...arrel-3291513/
Unread 08-10-2011, 05:22 PM   #3
DCJodon
37's are looking sweet.
DCJodon is offline   Reply With Quote Quick reply to this message
Unread 08-10-2011, 08:39 PM   #4
jeepster1407
Front 44 and rear 60 truss
_________
Unread 10-12-2011, 08:22 AM   #5
jeepster1407
Its been a while since I've updated. I have since made my front Tie rod, purchased a rear simple swap kit, and bought my new tires! Still need new wheels and a couple other small things before the tear down begins.
For the steering I went with ruff stuff 7/8" heim setup, I also purchased there simple swap kit. As for the tires I purchased 37" military version Goodyear Wranglers. I purchased 2 sets of front Waggy springs, but i really don't want any lift just stretch so I think i'm just going to run stock YJ springs and shackles since I have some of those as well, at least until i can get a fuel cell behind the seat.
Unread 10-12-2011, 09:59 AM   #6
95riograndeman
2015 JK Wrangler
Geez how does that 2.5 run with them 37's and that geering?
2015 Jeep Wrangler Sport
SOLD: 1995 Jeep Wrangler
95riograndeman is offline   Reply With Quote Quick reply to this message
Unread 10-12-2011, 10:28 AM   #7
jeepster1407
It pulls it, I can run 65 and keep up w/ traffic on the interstate. Should do better with the 5.13's I use 5th gear on flat interstate. I should be able to use it more when i switch to 5.13's. Its no Racecar but it does alright.
_________
Unread 10-12-2011, 11:35 AM   #8
Prryan45
Looking awesome.
Prryan45 is offline   Reply With Quote Quick reply to this message
Unread 10-12-2011, 12:11 PM   #9
jeepster1407
Originally Posted by Prryan45 View Post
Looking awesome.
Thanks!
_________
Unread 10-12-2011, 12:15 PM   #10
Renegade88
Hey man where were those wheeling pics took? I live in woodstock during the winter months and are looking for some places to wheel. Jeep loooks great by the way!
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline   Reply With Quote Quick reply to this message
Unread 10-12-2011, 12:18 PM   #11
jeepster1407
The top ones are at Tellico (R.I.P.) The bottom two are from Durhamtown.
_________
Unread 11-11-2011, 07:50 AM   #12
Louie4
Powah Injanir
Louie4's Avatar
Nice build. I miss Telllico and wasn't too impressed with Durhamtown. Hopefully that new 4x4 section is decent.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 11-11-2011, 09:29 AM   #13
jeepster1407
Thanks man, as do I!
_________
Unread 11-14-2011, 06:45 AM   #14
jeepster1407
Alright well I installed my new axles this weekend. What a relief! I took it for a spin and looks like I'll have to fab up some swaybar links on the front so I can install some disconnects. It's also very bouncy with no rear shocks, I'm gonna have to measure and find out what size to get. I'm also going to replace the fronts because there shot! I've also got some trimming to do!
_________
Unread 11-15-2011, 02:03 PM   #15
jeepster1407
i cut some brackets out at work for a sway bar on the front axle and i'm going to make some sway bar disconects using some heim joints and threaded rod.
_________
