Just another YJ build... My version - Page 41 - JeepForum.com
post #601 of 890 Old 07-08-2013, 06:33 PM Thread Starter
'92 vegas YJ
Originally Posted by trailrider787 View Post
This is looking nice man! I really like the fast back style!
Thanks
On that note I have a question for you guys. Originally i was going to add a small rear hoop with bracing, but im kind of liking how it looks right now. Should I add the hoop or not?
Here is what i was originally aiming for. This is from project Acrophobia from Pirate.
the rear of the cage would look more like this
'92 vegas YJ is offline
post #602 of 890 Old 07-08-2013, 06:43 PM
trailrider787
I personally say no, but it would provide a small amount of lateral bracing, however lateral support can be done in other better ways.
So no for me.
trailrider787 is offline
post #603 of 890 Old 07-08-2013, 06:55 PM Thread Starter
'92 vegas YJ
Thats what I was thinking. I think it just looks pretty cool the way it is.
Lets hear some more opinions....
post #604 of 890 Old 07-08-2013, 07:37 PM
donny90yj
Originally Posted by '92 vegas YJ
Yea but with everything I've done in the last couple weeks I cant afford to go wheeling on the 26th. I saw about that wounded veteran ride in Sept though. I'd like to hit that up. I always try to support wounded veterans.
But it's Papa Dean's birthday....lol. Understood, but you still gonna go on Labor Day too?
donny90yj is offline
post #605 of 890 Old 07-08-2013, 07:41 PM Thread Starter
'92 vegas YJ
I cant go labor day cause I should be in the field. My course will graduate on sept 20 i think. So that run at the end of sept should work out.
trust me I wish I could go more often
post #606 of 890 Old 07-08-2013, 07:56 PM
soonermatt
I like the internally mounted spares but that's not an option for me. The spare out back has yet to drag which is very surprising. I think both are cool.
soonermatt is offline
post #607 of 890 Old 07-08-2013, 08:10 PM Thread Starter
'92 vegas YJ
Im talking mainly just the cage. Ignore the spare tire in all the pics.
I don't plan on mounting the spare inside.
post #608 of 890 Old 07-08-2013, 09:41 PM
rambo3489
Digging the cage! Can't wait to see the HO72 under there. Are you going to need a wider front axle?
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #609 of 890 Old 07-08-2013, 09:43 PM
rambo3489
... You should.
SEEEXXXY!!!
<a href="
THE YJ MY WAY</a>
post #610 of 890 Old 07-09-2013, 03:39 AM
USMCBuckWild
Originally Posted by rambo3489 View Post
... You should.
SEEEXXXY!!!
This is what I would do. I think it gives you more even weight ditribution than having it hanging off the back. Cage looks to be level, maybe its just the jeep! Hahaha
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #611 of 890 Old 07-09-2013, 06:27 AM Thread Starter
'92 vegas YJ
Yea when I do the HO72 I'll be running a D60 front hopefully. Thats gonna be further down the road. I just picked it up because they're hard to find and I snagged it for a great price.
... You should.
SEEEXXXY!!!
I cant do this. As long as I'm a recreational wheeler I carry I big box with tools and spare parts. I wouldnt be able to get into the box with a big fat tire in the way.
post #612 of 890 Old 07-09-2013, 11:11 AM
rambo3489
Yes you can. You have a YJ make it work. Without a rear seat theres enough room back there. Might be tight but doable.
<a href="
THE YJ MY WAY</a>
post #613 of 890 Old 07-09-2013, 04:30 PM
HKusp
So I have spent the last few days reading this entire build thread. Great reading and very educational. I am an old wheeler, new to the Jeep world (having just bought my soon to be 16 year old daughter a 1993 YJ) but not new to modding, having a '90 mustang 5.0 notch and a very mildly modded 7.3 Superduty. I am looking forward to what comes next. Keep up the good work and thank you for your service.
HKusp is offline
post #614 of 890 Old 07-09-2013, 06:46 PM Thread Starter
'92 vegas YJ
Spent a little more time in the garage today.
First thing I did was get the passenger seat frame all cut and tac'd in place
Then I figured before I start mocking up the passenger seat I'll finish up with the driver seat.
So after lots of measuring and getting in and out of the seat to find the perfect height and position, I trimmed up the mounting tabs I have and tac'd them in place. After tac'ing them I marked the spot for the bolt on my seat frame and pulled it back out to drill them out.
tabs tac'd in and the seat bolted in, driver side of the seat looks the same
Then I slung a set of harnesses on the seat to look into getting the mounts tac'd in.
for the hip harness I have 2 mounting tabs to choose from.
The first set are double sheer purpose built harness tabs. The only thing i dont like about them is how big and bulky there are. I will obviously notch and trim them up so they fit tight around the tube for a good strong weld.
The other option is these little seat tabs I have. They are 3/16" thick so they are tough enough for the task. The pro's would just be how small and low profile they are. They bad part is I'm not sure how much i can trim them down to fit snug on the tube just because how small they already are. Also with them being so small that means less weld area.
I'll probably end up using the bigger ones.
post #615 of 890 Old 07-09-2013, 07:33 PM
flashy
I know this has nothing to do with what you are working on right now, but I have followed this thread since I bought my jeep and copied a ton of ideas so I thought I would ask your opinion. I am redoing my tranny crossmember again and I basically have the same thing as you. A bushing at each end. Since those bushings allow play, have you ever thought of getting rid of the tranny mount in the middle. That way you could tuck the crossmember up higher? The only thing holding me back is the risk of cracking the tranny.
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 05:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 07:08 PM
