Just another YJ build... My version - Page 40 - JeepForum.com
post #586 of 890 Old 07-07-2013, 04:53 PM
Climbit
Thanks.
Climbit is offline
post #587 of 890 Old 07-07-2013, 06:50 PM Thread Starter
'92 vegas YJ
Worked on my seat mounts for a little bit today.
I wanted to be have a slider with my seats that way different sized drivers can still fit. My GF is about 5'4" and has to slide the seat all the way up when she drives. I though about making some trick sliders or going the polyperformance route. Then I remembered that my Mastercraft seats are compatible with the stock risers and sliders. So I ended up just bolting the stock sliders to the Mastercraft frame. I am then using some angle iron bolted to that to mount to my cage. I will have tabs that come off of my cage seats mounts that bolt through the angle iron. I saw this done on Pirate and it seems like a simple effective way to retain the stock sliders.
Here is the angle iron all bolted up to the sliders/seats
after I got that done I headed out to the garage and looked at my blank slate
before I got started I threw the seats in just to see what they're gonna look like. I like it
Then I started notching some tube and laying out the plan
And I capped off that dead tube
I wanted the seats to sit as low as possible. I've read up on the subject and it seems to be the minimum space that you want under a set of suspension seats its around 2.5"-3". I've got around 3" the way im going to set it up. This should leave plenty of head room as well.
With around 1"-1.5" below the tube, then 1.75" tube, then the 1.5" angle iron and sliders on top of that I'd be a little too high. So I notched the angle to sit lower on the tube frame.
This is how I cut out the angle iron. I used a 4 1/2" grinder and made a bunch of slits
And then chopped the little pieces off
Hit up up with a flapper and threw them up to check clearances
This is as far as I got today. Next I need to start working on the passenger frame then get the mounting tabs tac'd on and the seat angle drilled out.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #588 of 890 Old 07-07-2013, 06:53 PM
soonermatt
You updated as I was catching up. It's looking good for sure.
soonermatt is offline
post #589 of 890 Old 07-07-2013, 06:54 PM
USMCBuckWild
Good job man! Why not use the notcher to cut the angle? Or put the notching bit into your drillpress.
When are you gonna get started on mine? Hahaha
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #590 of 890 Old 07-07-2013, 07:07 PM Thread Starter
'92 vegas YJ
Well thanks for checking it out. I always follow your thread as well.
Because I wanted to notch it with the seats still attached. It wouldve taken about 30 mins in disassemble and reassemble. The notch doesnt have to be a tight fit. Its not getting welded, just clearing the tube.
And I'll start on yours once you come over and help me finish mine. Still have a lot of work to do.
post #591 of 890 Old 07-07-2013, 07:43 PM
Gage56
Man i wish some of you guys lived closer
Nice Work
1992 YJ
Gage56 is offline
post #592 of 890 Old 07-07-2013, 07:48 PM Thread Starter
'92 vegas YJ
Thanks. You do a lot of nice work too.
post #593 of 890 Old 07-07-2013, 08:39 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Looking good, Chris. Cage is sexy.
Joe Dillard is offline
post #594 of 890 Old 07-07-2013, 08:44 PM
Joe Dillard
Oh, BTW, as a tip, you can trace out the 1/2 circle then draw a V in it & use the cuttoff wheel to cut the V. Then use a squared hard disc to grind the rest of the material away. I have found this technique to work pretty well with a few basic discs.
post #595 of 890 Old 07-08-2013, 07:28 AM Thread Starter
'92 vegas YJ
Thanks Joe. When does yours go under the knife for the 4 link?
I might have to try your "V" technique sometime.
post #596 of 890 Old 07-08-2013, 05:28 PM
flashy
x2
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #597 of 890 Old 07-08-2013, 05:34 PM Thread Starter
'92 vegas YJ
cleaned up the garage today. It was looking HORRIBLE with grinder shavings and metal notches all over the place.
I backed the jeep out and figured it'd be a good idea some snag some pics of the progress so far. I was also able to step back further away and make sure everything looked level/square. It all seems to be level and square with my crooked sitting jeep
here some pics
post #598 of 890 Old 07-08-2013, 05:40 PM
donny90yj
See you're almost done, plenty of time to finish by the 26th.
donny90yj is offline
post #599 of 890 Old 07-08-2013, 05:46 PM Thread Starter
'92 vegas YJ
Yea but with everything I've done in the last couple weeks I cant afford to go wheeling on the 26th. I saw about that wounded veteran ride in Sept though. I'd like to hit that up. I always try to support wounded veterans.
post #600 of 890 Old 07-08-2013, 06:03 PM
trailrider787
This is looking nice man! I really like the fast back style!
trailrider787 is offline
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 05:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 07:08 PM
