Just another YJ build... My version - Page 4 - JeepForum.com
post #46 of 890 Old 04-18-2012, 03:59 PM Thread Starter
'92 vegas YJ
bump
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #47 of 890 Old 04-19-2012, 01:03 AM
Climbit
Originally Posted by '92 vegas YJ View Post
bump
you are supposed to bump your own thread with UPDATES!!!!!!!!!!!!
Climbit is offline
post #48 of 890 Old 04-19-2012, 01:56 AM
Hard_oNe
Looks good. Keep the updates coming.
I just wonder where you get the cash to do all of this? I understand the Military subsidizes your housing but damn. My money goes to gas for three vehicles, mortgage, and beer then jeep.
1989 Jeep YJ - "go slow"
2007 Trailblazer SS (6.0 LS2) - "go fast"
Hard_oNe is offline
post #49 of 890 Old 04-19-2012, 05:04 AM Thread Starter
'92 vegas YJ
bump
Hahaha ok you want an update. I ordered some ball joints a couple days ago. Whenever those get here ill get started on replacing my current ones
post #50 of 890 Old 04-19-2012, 05:09 AM Thread Starter
'92 vegas YJ
Thanks, I will keep up on the updates too.
The money situation is weird. I'm a recently divorced E5 with a roomate. I don't necessarily make a lot of money just have more play money than I did when I was married living in San Diego.
In reality I'm just as broke as everyone else, I just have chitty priorities haha
post #51 of 890 Old 04-19-2012, 01:30 PM
Hard_oNe
I totally understand. Good for you, we all should enjoy our passions. Married, kids and bills, barely have enough for my beer fund even less for the jeep fund.
Hard_oNe is offline
post #52 of 890 Old 04-29-2012, 02:22 PM Thread Starter
'92 vegas YJ
been a real busy weekend working on the jeep.
i ordered some balljoints online and received them last thurs so i went ahead and tackled that project this weekend.
heres my old balljoints, as you can see i desperately needed new ones
i rented a balljoint press from Autozone and began tearing into it.
i tore the axle down to the C's
both my upper joints were so bad the the balljoint just pressed out of the outer sleeve.
i then used the press and a socket to get the rest of it out
and heres one bare C
i then pressed all my new joints in. i didnt get any pictures of this but i did
knock out a few other things and get some pics
while i had my steering off i decided to throw a fresh coat of paint on it.
BLINGING PLATINUM
while i had the axle apart i realized that my passenger side axle Ujoint is toast
im trying to get this thing ready to go out on the trail next weekend so this put me in a little bind. NO ONE locally sells Spicer joints and i dont really have the time to order some and wait for it to come in, then throw my axle back together for the weekend(work too much during the week)
that being said i went against my better judgement and snagged a Autozone Duralast Gold 297 ujoint. we'll see how long this thing lasts. at least maybe it can last long enough for me to order another joint.
heres the new joint
got the joint out and the shafts seperated
and the old vs new
and finally with the Duralast Gold ujoint installed
one other thing ive needed to do for a while was figure out my front brake lines. i run chevy 1500 brake lines which are 25.5" long and i still max them out. until i buy some longer lines i just moved my hard lines under the frame. this seems to have given me enough space that my shocks will limit before my brake lines.
on that note i have realized now that my shocks are my next limiting factor. i am going to snag some shocks from SSYJ94 when i get some spare cash. they are 13" BBCS. those should work well for me. until then though i figured i should run some limit straps.
as i was perusing through Tractor supply today i ran across the axle straps they sell. they are 2"x24" and rated at 10,000lbs. the ones from poly performance and everywhere else are 1.75" and rated at 7,000lbs. now i know that alot of those are double or quad wrapped but they do have single wrap ones and if those work i dont see why these wouldnt. if they fail i am out $10 a pop. no big deal in my book
i think these my do the trick
i disconnected my shocks and let them go full droop them hooked theses up about an inch before my shacks max.
and all buttoned up
and heres how she sits
well thats all for today folks. i have all my tires loaded up in the back of my truck and hopefully tomorrow will be able to get my new MTRs mounted
post #53 of 890 Old 05-01-2012, 05:50 PM Thread Starter
'92 vegas YJ
got my new(only a couple hundred miles) MTRs mounted today
heres my roomates son posing with them
and mounted
and did a little testing of my limit straps.
should hopefully be heading out to Uwharrie this weekend. i cant wait to get back on the trail again and finally put some of these new parts to the test
post #54 of 890 Old 05-01-2012, 08:20 PM
Climbit
looks good
you sure those leaf spring bolts are long enough?
Climbit is offline
post #55 of 890 Old 05-02-2012, 06:18 AM Thread Starter
'92 vegas YJ
Originally Posted by Climbit View Post
looks good
yea i tend to over estimate on bolt sizes. better to be too long than too short.
post #56 of 890 Old 05-07-2012, 06:07 AM
rulppa
Wow, seems like you have been busy! Good job, keep it going! Waiting to get my genright fenders too, too bad i had to get the ones with 6" flare.. :/
Build in progress at
rulppa is offline
post #57 of 890 Old 05-07-2012, 06:45 AM Thread Starter
'92 vegas YJ
thanks man. cant wait to see your fenders and see when you start you waggy spring swap. youre going SOA right?
i went out to Uwharrie this last weekend. had a blast.
had some minor carnage. i broke my frame mounted traction bar mount(it actually broke the trans skid that i mounted it too). i also broke a front shock mount and after flat towing home im getting a loud weird clunking sound in my steering column. im going to check the steering linkages and go from there.
ill get some pics up from this weekend when i get the pics from everyone that went
post #58 of 890 Old 05-09-2012, 05:13 AM Thread Starter
'92 vegas YJ
well i had some unfortunate luck yesterday. the passenger wheel bearing went out on my truck so i had to get it towed home from work so i could fix it. easy job though. only took like an hr. i replaced both sides for peace of mind.
this is a sad sight
all tore down
here are some pics i was able to scrounge up from Uwharrie this last weekend
also found a good use for OBA. heres Kevin airing up his air mattress
post #59 of 890 Old 05-10-2012, 06:13 AM
ldso
all tore down
Man we have been working on the same stuff. My 02 Avalanche just ate a wheel bearing. I need to get a puller, mine had a pressed-in unit hub that I had to beat on for like an hour. I haven't done the other side yet, mine was the passenger side too.
And yeah I had the same deal with the D30, everything was worn out. Since I have a 4-banger I decided to stay with the 30 for now and gear and rebuild it.
Looks like a great wheeling trip man, and I really like your corner armor with the round lights. Might make that a new goal for mine.
I'm going to Coal Creek/Windrock TN in a week, can't wait! Glad everything held up at UWharrie.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #60 of 890 Old 05-10-2012, 07:12 AM Thread Starter
'92 vegas YJ
that sucks about your wheel bearing as well. fortunately mine wasnt hard to replace. the bearing are already pressed into the rotors. so it was pretty much just a job of replacing both rotors
im still undecided about the D30. i dont want to put money into it, thats money that could go to something else.
i do have a trussed D30 geared to 4.56 i might throw in and regear my 8.8, then just run it til they explode or i feel like upgrading
thanks for the comments on the corner armor. im pretty happy with how they came out.
have fun on your wheeling trip and be sure to get lots of pics
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 05:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 07:08 PM
