Just another YJ build... My version - Page 2 - JeepForum.com
post #16 of 890 Old 03-26-2012, 10:02 PM Thread Starter
'92 vegas YJ
well i was able to get my front fenders finished today as well as get my new-to-me rockers on.
i also finally heard back from PSC about my aluminum crusher corners. they were sent out today so i should see them by the end of the week
once i get those in i will get them painted and installed, along with some 4 1/2" flush mount LED tails.
my driveshaft should ship out next week and i still have some rock lights in the mail from my friend back in vegas.....
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #17 of 890 Old 03-27-2012, 11:52 AM Thread Starter
'92 vegas YJ
just a couple poser pics today
post #18 of 890 Old 03-27-2012, 05:15 PM
connor0770
looks good! I like how its turning out!
Corral Canyon looks like one hell of a trail! I would love to head down to San Diego for a week and do some exploring.
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #19 of 890 Old 03-27-2012, 05:43 PM Thread Starter
'92 vegas YJ
thanks man.
yea corral canyon is pretty fun. they have everything from fire roads to hardcore trails. theres also tons of other spots to wheel in San diego that are a blast
post #20 of 890 Old 03-31-2012, 08:45 AM Thread Starter
'92 vegas YJ
finally got my long awaited package yesterday. i spent 1 1/2 months dealing with PoisonSpyder trying to get my rear crusher corners.
ran some errands yesterday after work and came home to find this on my doorstep.
i will give them credit on how this one was packaged. they made sure it wasnt going to get damaged. in my opinion though i think it shouldve been packaged this well the first time.
couldnt wait to start mocking it up
my rear panels and corners are beat to hell so it was not fun trying to get everything lined up and flush. on the driver side i will have to do some body work to fill in some of the huge dents.
heres the passenger side hanging
i marked everywhere that i need to cut then removed the corners.
thats as far as i got last night. i will be doing more today.
let me know what you guys think
post #21 of 890 Old 03-31-2012, 07:29 PM Thread Starter
'92 vegas YJ
DAY TWO of crusher corner install
i was able to get lot more accomplished on my corner install today.
the first thing i started with is getting my wiring for my LED tail lights. i copied what pretty much everyone does. i cut the wires from the OEM tail light side so i could still use the disconnect harness. i took the LED wire and soldered them to the oem harness. i also picked up the EL12 flasher relay so they work correctly
heres the giant OEM tail light
and i snipped the harness off
new LED tail
here is how the wiring goes
~copied from Sebastian22 LED writeup~
LIGHTS----JEEP-------FUNCTION
Red----Black/Green---Brake / Blinker
Black------White-------Tail Light
White------Black*-------Ground
N/A-----White/Black-----Back-up
got them soldered up and put some heat shrink over it
i also ordered some countersink stainless bolts that match the PoisonSpyder hardware for my rockers. i figured i could go ahead and get those installed as well.
here is what i originally mounted them with. just some standard Grade 8 hex heads
and the new stainless bolts
next i had to knock out a little bit of body work for the rear of my tub. i HATE body work. im just not good at it at all.
here is the damage that i am repairing
heres some progress after a couple coats of body filler
and heres my final coat. its not too perfect but its ok, i just wanted to close up the gap i little bit between the body armor and the tub.
i installed the armor again to check for fitment after the body armor and test the LEDs.
also test fit my stock TJ flares that i run. everntually i will upgrade to some Tubes for the rear. i just could justify the cost at this time
next i drilled the mounting holes for the flare
here the corner is bare
and a pic after i drilled the mounting holes
after i drilled the holes i cleaned up the corners with laquer thinner to prep for paint
and i hung them and started a coat of aluminum self etching primer
after a couple coats of primer i started to lay some gloss black paint
in between coats of paint i starting playing around with a way to mount my license plate. i wont be mounting it in the stock location.
what i came up with is something like what Genright sells
here is GenRights version
http://www.genright.com/ProductInfo.aspx?productid=LPM4005
what i started with was some 1/8" plate
i traced the license plate and cut it out
next i found some scrap steel i had laying around.
i grabbed some 1.5x.250 Dom and some 1.75x.120 HREW.
the 1.5 fits right inside the 1.75
i welded the 1.5 DOM to the center of my tire carrier and the 1.75 HREW to the plate that the license plate mounts to
before i welded them up i drilled some holes in the tube to lock it in place. i used a standard hitch pin i had laying around to lock it in place but also make it removable to remove my spare tire.
and now its ready for a test fit. fits like a glove
i pulled the corners and layed em down for the night. ill add a couple more coats tomorrow and if i have time get everything installed.
and thats it for the night guys.
post #22 of 890 Old 04-01-2012, 11:53 AM
castorriver
Sweet, sweet build. Nice pics and great work.
Was there anything wrong with the stock rollbar or did u just want something different?
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #23 of 890 Old 04-01-2012, 12:39 PM Thread Starter
'92 vegas YJ
Thanks man.
Nothing wrong with stock rollbar, just wanted some more protection and security in case of a flop
post #24 of 890 Old 04-01-2012, 01:57 PM Thread Starter
'92 vegas YJ
got more knocked out today. finished paingting the corners and get them installed. the only thing left to do with the corners is get my flares mounted up. maybe tomorrow
i also got my tire carrier back on with my new license plate relocator.
i also got a little license plate light/bracket from autozone. just mounts using your existing holes. i sprayed it black so it doesnt stand out as much.
i hooked it up to test it out and it works just fine. i spliced it into my tail harness.
most likely tomorrow i will figure out my wiring layout for it and finalize my connections. i will be using a disconnect by the plate.
post #25 of 890 Old 04-03-2012, 09:45 AM Thread Starter
'92 vegas YJ
Bump!!!
post #26 of 890 Old 04-03-2012, 07:18 PM
ssyj94
It looks sweet the fenders look alot better black and with the grills in em
What did you use to paint the AL corners?
My build:
ssyj94 is online now
post #27 of 890 Old 04-03-2012, 07:37 PM Thread Starter
'92 vegas YJ
thanks man. i agree, the fenders do look better black w/ the louvers
i painted the corners with Aluminum self etching primer then some rustoleum high gloss enamel. all spray can
post #28 of 890 Old 04-04-2012, 07:22 PM Thread Starter
'92 vegas YJ
i finally had the time to get my corners and LED install completed all the way.
im still waiting for my TAtton front DS to come in. should be sometime this week. i think he shipped it out on monday. after that i need to go out and tear it up. trying to plan a trip out to Uwharrie
sorry for the crappy cell pics. i really need a camera.
post #29 of 890 Old 04-05-2012, 08:10 PM Thread Starter
'92 vegas YJ
got my license plate light at wired up today.
i wanted to make it a quick disconnect with a pigtail of some sort so when i take my plate off to get to the tire it just comes with it. i searched around locally and couldnt find anything i liked. i then hopped on the web and found just what i was looking for from JEGS. this thing is sweeet.
http://www.jegs.com/i/JEGS-Performan...ductId=1591864
anyways on with the pics
all lit up
pigtail
and the best thing about moving the license plate, look ma no hands
post #30 of 890 Old 04-06-2012, 08:21 PM Thread Starter
'92 vegas YJ
Got my new switches installed today. The middle green one isn't hooked up to anything yet. When I find something to run ill get a labeled switch like the other ones
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 06:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 08:08 PM
