Just another YJ build... My version - Page 17 - JeepForum.com
post #241 of 890 Old 10-27-2012, 08:13 PM
USMCBuckWild
Looks great! You do lay a nice bead.......
Water is approaching quickly, guess we will see how we stand in the mornin
USMCBuckWild is offline
post #242 of 890 Old 10-27-2012, 08:24 PM Thread Starter
'92 vegas YJ
Thanks.
If Lynn doesn't have any springs i might end up buying some brand new waggys. I don't really want to but not sure what else to do.
If the water gets too rough you have a place to stay at my house. Always welcome
'92 vegas YJ is offline
post #243 of 890 Old 10-27-2012, 10:02 PM
USMCBuckWild
I appreciate the inland safety offer. The water is up to the back deck, so we will see where we stand in the morning!
post #244 of 890 Old 11-10-2012, 12:22 PM Thread Starter
'92 vegas YJ
Worked on my rig a little last night and this morning. Ive been super busy with work and other stuff lately.
I was able to take the bare D30 housing and get it all put together and installed. First thing i did was install some ball joints. After that i got it mocked up and cut out a top plate for the passenger side ubolt delete. Finished that up and swapped everything else over from my old 30. Didnt take any pics but i did get a pic all bolted up.
new trussed d30 all bolted up
I also had to roll the jeep out of the garage so i could clean my huge mess. Not too bad considering i have no brakes
side shot. This is at 98" WB. 3" front and 1" rear stretch.
As mentioned before my driver rear sits 3/4" lower than passenger. Nothing is welded yet on the rear. Still trying to figure out what im going to do. Open to suggestions
And my messy garage. Dont worry its all clean now
post #245 of 890 Old 11-10-2012, 05:15 PM
Louie4
That D30 is reminiscent of Mr. Dillard's.
Very nice.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #246 of 890 Old 11-10-2012, 05:53 PM Thread Starter
'92 vegas YJ
Very nice.
That's because it is Mr. Dillards :-)
Except mine isnt as polished as Joe's. He was running chromo shafts and Warn lockout hubs w/ an ARB. Im just running TJ shafts and a spartan LL.
post #247 of 890 Old 11-11-2012, 05:58 AM
USMCBuckWild
Looks good Chris.
Happy Veteran's Day
post #248 of 890 Old 11-11-2012, 08:16 AM
Louie4
Lucky guess. One day I'll polish mine up like that. Maybe when I get big boy tires.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #249 of 890 Old 11-11-2012, 05:30 PM
navman
I got some ideas when your ready to polish them up
I just noticed the blue f150 fx4 in one of those pics, yours?
95 YJ 5.0 linked etc
navman is offline
post #250 of 890 Old 11-11-2012, 07:28 PM Thread Starter
'92 vegas YJ
You definitely have the most polished D30 I've ever seen lol
And yea the F150 is my other toy
post #251 of 890 Old 11-11-2012, 07:52 PM
navman
Very nice, mine still looks basically stock, but I used towing the trailer as an excuse for a little more power
navman is offline
post #252 of 890 Old 11-12-2012, 05:31 AM
Louie4
No doubt. About the only that will be left of the D30 are the C's and unit hub bearings...which I'm OK with.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #253 of 890 Old 11-23-2012, 05:45 PM Thread Starter
'92 vegas YJ
Well it's been about 2 weeks since I've update this, so I figure I'll bring you guys up to date.
First thing I did since Last time I updated was burn in my perches and shock mounts. Because I'm running the Teraflex upper shock bar I had to change out my lower shock mounts. I bought some Ruffstuff mounts a couple months ago and finally welded them up.
straight out of the box
Tac'd together
Then I burned my perches and shock mounts on the 8.8
Driver perch
painted
After all that I made a new rear driveshaft. I cut up a XJ shaft and internally sleeved it. I think the internal sleeve should last. It's 1.5x.25 sleeved with 1.75x.120 and then the shaft which is 2x.120.
Heres the inside of the shaft
Welded up and installed
And most everything bolted up in the rear
I was able to get my axles filled with fluid, bleed brakes and back her out of the garage again. It was dark so i wasnt really able to take any pics. Ill get some tomorrow.
I still have some things I need to do. I still need to bleed my brakes again, double check the tightness of EVERYTHING, set my toe, build my traction bar...ect. I also want to remove a leaf from my front waggy pack to lower it a little. I've been sitting high in the front for a while now. Just havent played with the springs in a while.
Also today I took advantage of some of the black friday sales going on. I ordered some Bilstein 5125 14" shocks for the front of my rig. I need to cut off my stock upper mounts and weld in my hoops. But thats for a later date.
That's all for now gents...
post #254 of 890 Old 11-23-2012, 06:40 PM
soonermatt
Wish my spring perches looked that good. Due to the thick tube and my 130 welder I had to make some hot, ugly welds.
You'll like those 5125s up front. I'm running them too.doing full hoops is probably smart. I made my own shock tower top and cut off the factory. So far I've had to reweld each side once. They're hard to weld up against the inner fender.
The shocks are definitely nice. Nice looking work!
soonermatt is offline
post #255 of 890 Old 11-23-2012, 06:48 PM Thread Starter
'92 vegas YJ
Thanks man. All of my welding is done with only a HH140. Ive never had a weld break. ~knock on wood~
I've read your thread a couple times and saw that you're running the 5125s as well. You're running 12" right?
I snagged the hoops a couple months ago from WFO. They're pure beef. Im currently running 5100s right now and like the ride so I figured the 5125s would fit the bill for the right amount of money right now. I got both front ones for only $170. I thought that was a pretty good deal
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 06:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 08:08 PM
