Just another YJ build... My version - Page 16 - JeepForum.com
post #226 of 890 Old 10-26-2012, 06:14 PM Thread Starter
'92 vegas YJ
Today I drove out to Wilmington and picked up my axles. Fresh 4.56 gears. I also ended up having them weld up the 8.8 spiders. I never really run my jeep on the street.
Not sure how much I'm going to be able to get done this weekend, We're under a tropical hurrican warning. Even if a hurricane doesnt hit us its supposed to pour rain and winds up for 50-60MPH this weekend. Pretty crummy weather to be grinding and welding.
new 4.56 Ring and pinion
Welded spiders
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #227 of 890 Old 10-26-2012, 06:29 PM
squishy
Originally Posted by '92 vegas YJ
Welded spiders eaking
Thanx for the pic of the spiders always wondered what to weld and how beef they should be. Ahhhh you can't wait to drive it!!!!!
squishy is offline
post #228 of 890 Old 10-26-2012, 07:46 PM
USMCBuckWild
Glad you got your axles picked up! wish I could have gone with ya, too much work. I hope those welds hold up, the gears should make a HUGE difference in power. if i lose my temper again, you might have my 350 sooner than you think! I got the roll bar out and the windshield folded and pushed the Heep into the garage. Need to get a couple stitches in the back of my head too. Hahahaha, i was tryin to lower the roll bar out of the jeep, slipped, bounced off the tire and ended up a bleeding mess in the driveway. Hahahaha, I wish I could have seen it myself!
USMCBuckWild is offline
post #229 of 890 Old 10-26-2012, 07:59 PM Thread Starter
'92 vegas YJ
I hope the welds hold too.
Is your guy gonna come help you wire it up?? If you pull that 350 it'll sit in my garage while I rebuild it.... and collect parts. Just what i need. another project haha
No bueno on the stitches. You should've just called me to help you. You know I work right down the street from you.
post #230 of 890 Old 10-26-2012, 08:00 PM Thread Starter
'92 vegas YJ
Yea i cant wait to drive it. Mainly wheel with the new gears and a locked rear.
post #231 of 890 Old 10-26-2012, 08:03 PM
USMCBuckWild
Meh, hopefully it knocked some sense into me! Hahaha, I do have a helluva headache and my neck is killin me. Bled all over one of my shirts too. Oh well, no brain; no pain!
On a serious note, those welds don't look sufficient. Hopefully its just the pictures; but last time I welded spiders, we used almost 2 lbs of rod. Not bashing the job you got done, just stating it doesn't look solid from that pic. I have seen how you drive and heard enough stories of your off road escapades to know that YOU need to over-engineer EVERYTHING you do! Hahahaha
post #232 of 890 Old 10-26-2012, 08:20 PM Thread Starter
'92 vegas YJ
Yea that's kinda what I thought when I first popped the cover. It has a weld between the spiders on all four corners on both sides and the spiders are welded to the carrier on 3 sides on both sides as well. I researched some pics and I see both. Some FILL it with filler and some just do it like its done on mine and say ther've been running it for years. Im not sure.
post #233 of 890 Old 10-26-2012, 08:25 PM
USMCBuckWild
Well, only 1 way to find out if it holds up....... Beat the snot out of Her!!!
If the welds have good penetration and are thick and heavy, they should hold. Just be prepared.
post #234 of 890 Old 10-26-2012, 08:31 PM Thread Starter
'92 vegas YJ
I just dont know if I should try to burn some more in there with my HH140 or let it be..... decisions decisions
post #235 of 890 Old 10-26-2012, 08:45 PM
USMCBuckWild
Well, did he offer any sort of warranty? If he did, don't touch it! If he didn't..... I would run it with 220 stick.
post #236 of 890 Old 10-27-2012, 05:05 PM Thread Starter
'92 vegas YJ
Today I decided to spend a little time on my rear axle. Started at about 9AM.
First thing I did was cut off all the old brackets and grind everything smooth
After that I decided to try my hand at welding the tubes. This was my first time I tried welding tubes. Turned out pretty good. I did the welds in small 1-2" beads. Alternating sides. I pre-heated with a propane torch, burned with my HH140 using flux core, post-heated then wrapped a welding blanket around the weld to let it cool at an even temp. I left the blanket on until the weld was 100% cool then moved to my next weld. Took me about 4 hrs total.
some pics of the welds.
Then i slung the axle under the hoopty.
now comes my predicament. I originally wanted to stretch 3" using waggy springs but I havent been able to find any locally. I've been looking for a couple months. So then I figured I'll just stretch it 1" using the new Ruffstuff perches I bought. because of the 1" stretch and the belly up I did I will need a new driveshaft. I just don't know if its worth a new driveshaft for only a 1" stretch.... Plus with the trans/tcase up so high now I think my double cardon will start binding. Also when I lowed the jeep onto the new axle it appears I sit about 1" lower on my driver side. My springs dont look bent but for some reason its sitting crooked......
What should I do?
Heres how the jeep is sitting at the end of today. (It sitting high because its on jackstands)
post #237 of 890 Old 10-27-2012, 05:33 PM
squishy
Those sir are some nice lookin welds!!! Nice work! Wanna zip up to jersey and weld my perches? Lol.
squishy is offline
post #238 of 890 Old 10-27-2012, 05:36 PM Thread Starter
'92 vegas YJ
Thanks. Lemme load up the Hobart and hit the rd. Might take a while to get to Jersey
post #239 of 890 Old 10-27-2012, 05:46 PM
squishy
Lol. Gee thanx be careful it's gunna rain. !!
squishy is offline
post #240 of 890 Old 10-27-2012, 05:49 PM Thread Starter
'92 vegas YJ
Its gonna rain? Its been pouring here all day. We're supposed to get hit hard tomorrow
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 05:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 07:08 PM
