Just another YJ build... My version - Page 13 - JeepForum.com
post #181 of 890 Old 09-24-2012, 05:31 PM Thread Starter
'92 vegas YJ
Got back from Uwharrie last night. I had a great time.
I will get some pics up as soon as i get them from Zack. A couple things annoyed me over the weekend. Its the SAME things that annoy me everytime i wheel but for some reason i never fix it.
The first thing is I NEED to re-gear. Ive been running 3.55 gears on 35's . I already called a shop today and got a quote for a re-gear. The second thing is I need a rear locker. I can climb obstacles no problem with my locker in the front but as soon as my rear hits i start bouncing and cant get any traction.
Both of those things will be addressed before the next time I go out.
I did have some carnage over the weekend. I snapped the yoke on my AA SYE. afterwards I just pulled the rear driveshaft and limped back to the trailer.
I made a call today to AdvanceAdapters and they are making it right. Randy at AA said that there is no reason I should have had a failure. They are sending me a new yoke for free. Ive been running this SYE for 2 yrs and they are still going to warranty it. GREAT CUSTOMER SERVICE
On a side note today I decided to tackle the Sway-A-Way coilovers on my truck.
The truck looks level in this pic but its not. I need to crank the coilovers for about 1-2" more lift in the front.
Well Thats all I have for now.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
post #182 of 890 Old 09-24-2012, 05:48 PM
PA_YJ19
Hey man u r using a cut down xj shaft right? My mechanic noticed when he regeared mine a few weeks ago that the ears at the top of the DS didn't fit in between the yoke at full droop...They touched causing it to bind and possible break. You might want to droop test urs n see if they hit the yoke like mine did, I had to grind quite a bit off of the outside ears around the ujoints to make sure mine cleared without touching the yoke. Not saying that was ur issue here cuz I have no idea what u were doin when it happened but u might wanna check to make sure just in case. I figure mine can't be the only one out there that doesn't fit since so many people have used an xj shaft but I've never heard of ne1 else having the same problem as me until possibly now mayb haha
PA_YJ19 is offline
post #183 of 890 Old 09-24-2012, 05:57 PM Thread Starter
'92 vegas YJ
Hmmm... I never thought of that. When i get the new yoke installed i will do i droop test like you mentioned.
Thanks for the heads up
post #184 of 890 Old 09-24-2012, 06:12 PM
ssyj94
x2 what PA_YJ19 said..
Also make sure the bolts holding the driveshaft to the yoke arent too long and bottoming out on the cv when its drooped. I'd slap a detroit in the back while its getting regeared
My build:
ssyj94 is offline
post #185 of 890 Old 09-24-2012, 06:25 PM Thread Starter
'92 vegas YJ
I know the bolts aren't too long. I will be doing a lot of droop tests when i get the new yoke on. I dont want it to happen again.
AS for a rear locker. I was thinking about just throwing a spartan in the rear. I have one in the front and love it. Never had problems with it
post #186 of 890 Old 09-24-2012, 06:34 PM
USMCBuckWild
I called Lynn, left a message. Once I hear back I will let you know
USMCBuckWild is offline
post #187 of 890 Old 09-24-2012, 06:53 PM Thread Starter
'92 vegas YJ
thank you.
I have some thoughts running through my head. Im thinking that I'll pull the axle to get regeared.....
Then it all goes down hill....
I want to stretch my rear a little bit. So im thinking some waggy springs. that'll put me at about 100". in order to stretch though I'll have to re-set my pinion angle. so I'm thinking while im already re-setting my pinion angle I'll get my trans as high as i can. By "as high as I can" i mean cutting the tunnel to get a flat skid. in order to do that i'll get a 1" MML. In order to stretch the rear 2-3" I'll have to dimple my gas tank. Then build a new traction bar.
So my build list that Im contemplating doing is
-Regear 8.8
-lock 8.8
-regear and install Joe Dillards old Trussed Vac delete D30
-stretch rear 2-3"
-dimple gas tank
-cut all brackets off 8.8 and re-set pinion, shocks, traction bar ect
-build new traction bar
-Flat skid
-Cut into trans tunnel and weld in new sheet metal
-1" brown dog MML
-install new trans output yoke
-hope my rear driveshaft will fit with the stretch
Does this all seem too much? am i just never satisfied?
What do you all think?
post #188 of 890 Old 09-24-2012, 09:26 PM
squishy
I'm thinkin I'm in the wrong line of work lol. But you do have a pretty well equipped shop. Welders cutting bending etc. etc. .... So all you're paying for is parts and the regear ? Sounds like lots of fun. Keep us updated. !!!
squishy is offline
post #189 of 890 Old 09-25-2012, 08:03 AM Thread Starter
'92 vegas YJ
Im just working out of a 2 car garage. I feel the investment in tools pays off way more than paying someone to do the job for you once.
and yes all i would be paying for is parts and regear. i could do the re-gear myself just dont feel like it. i really dont think i have the patience to do a re-gear. everything else i will do myself though
post #190 of 890 Old 09-25-2012, 10:12 AM
RogueFab
I couldn't agree more!
Rogue Fabrication - Portland OR -
Air/Hydraulic tube benders- $595 w/180 degree die sets
Universal Drill Press Reduction Kits- $119 shipped
RogueFab is offline
post #191 of 890 Old 09-25-2012, 11:29 AM
USMCBuckWild
Damn, you are finally gonna do it! Like i said, I will happily trade you for the 3.55 running gear......
Anything else you need from me; gimme a call!
post #192 of 890 Old 09-25-2012, 01:18 PM
Climbit
you shouldve taken it over to border parts before you left... I can't believe you survived on 3.55s for this long....
although you do like the skinny pedal so its probably helped you
Climbit is offline
post #193 of 890 Old 09-25-2012, 03:54 PM Thread Starter
'92 vegas YJ
Before i left SD i was more concerned about getting everything i own safely across the country.
And the skinny pedal is the only thing that helps me. also hinders me sometimes too oh well
post #194 of 890 Old 09-26-2012, 06:34 PM Thread Starter
'92 vegas YJ
Well i did some boring but important work on the jeep today.
I figured while Im waiting on some parts in the mail I would reorganize my tool box that sits in the back of my jeep.
I acquired a Pelican case from work that I plan on replacing my old box with.
Here's my old setup. Its just a box that I bought over in Iraq to send all my gear home in.
and removed from the jeep
You can see I need a little more organization
Heres most everything removed. Its missing a couple things I need to replace from my last couple trips.
I also bought a few new things. A pneumatic cutoff wheel, mini hack saw, some more zip ties and a couple more adjustable wrenches.
And here is the new box. Its a lot deeper and just overall bigger.
Plenty of room. I can also break it up into sections for more organization.
It even has storage on the inside of the lid for little things. This will really come in handy
Heres everything installed. I have so much more room now. Its not even half full yet.
Now I need to go out and buy more stuff. Mainly some more important fluid.
post #195 of 890 Old 09-27-2012, 12:27 PM Thread Starter
'92 vegas YJ
today i decided to add a hand/thumb throttle. 3 footing it while wheeling gets a little old. haha
I went to local bike shop and got a gear shifter and cable for $8. I tore to shifter apart so that it no longer clicks, I want as soon as i release it for it to spring back to idle.
Heres a pic of it mounted. No write up as this has been done numerous times
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 05:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 07:08 PM
