Just another YJ build... My version - JeepForum.com
post #1 of 890 Old 03-11-2012, 06:17 PM Thread Starter
'92 vegas YJ
Heres my shot at a build thread. i never took a lot of pics through the yrs but i will try to get everyone up to date. most of this build thread is from my build over on Wranglerboard.com
I bought my YJ when i was 16 yrs old. almost 9 yrs ago. she already had a 4" procomp lift and some 33" bfg mud terrains. that and the sweet 2" round bumpers were the only mods on it.
i ran that setup all through high school and thought i was on top of the world. my jeep could do anything. i added some lights and some bushwackers flares
when i was 19 i joined the military and moved to Virginia. with multiple deployments to Iraq and non-stop training my 3 yrs there i only wheeled ONCE on the east coast.
right before my only run out there i went out and bought a smittybilt tire carrier so i can have a spare for the trail ride. a couple months afterwards i bought a matching pro comp front bumper and got rid of my tube bumpers.
here i am in Gore, Va
and the new front bumper i bought
rear tire carrier
after 3 yrs on the east coast i begged and pleaded and got stationed in San Diego. once getting out here everthing pretty much went down hill.
within my first month here i bought a welder and started fabbing some stuff up.
my first project was my rock sliders
i wheeled a little around SD and back home in vegas some more then came another deployment. while on deployment i ordered a couple parts and went right to work installing them when i returned Dec 2010.
installed a Warn m8000 winch
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
post #2 of 890 Old 03-11-2012, 06:28 PM Thread Starter
'92 vegas YJ
a SOLID d30 diff cover
and a SPARTAN locker. this was a great upgrade
first wheeling trip after deployment and some new parts was to Corral Canyon. trail was pretty fun. this was the most rock crawling i had done to date
Next trip was about 2 weeks later on New years day 2011 to Johnson Valley.
my next big project i wanted to do was some tube fenders.
i went out and bought all of the material locally and started tearing into me Heep.
i was pretty content with the way they came out. i ended up finishing them the day before i headed out to JV for King Of The Hammers.
i stayed in Joe Dillards camper with him and we spent the night hanging out and drinking with some of his friends.
you might have heard of them before.... Larry and Wendy Nickel? John Herrick?
i also met some really great guys in the business. i met Brad Barnes from Barnes4wd and showed him my jeep. he commented how he really liked my fenders and i had some skill.
post #3 of 890 Old 03-11-2012, 06:41 PM Thread Starter
'92 vegas YJ
i had an AA SYE sitting in my garage and figured it was time to install. i dont have any pics of the install but i do have some of the DS we made.
it is a shorted XJ shaft sleeved with .250"wall Chromolly
i installed some front Bilsteins i got off a local friend
then I headed out to vegas. i did a local trail out there and acquired some damage. i put a hole in my oil pan and bent the crap out of my Drag link.....
i went and pulled a cherokee oil pan from the junk yard and swapped it in.
old vs. new
so my next projects. OIL PAN SKID and beefier drag link
and the steering. This is 1 1/2" .250" DOM with weld in bungs with TRE's
stock vs. new
the next thing i can think of that i did was finally cut down my procomp bumper and make it a stubby
dont mind the booger welds, this was just a quick flux core job. welded inside and out so i didnt care how it looked. plus i ground them down
post #4 of 890 Old 03-11-2012, 06:58 PM Thread Starter
'92 vegas YJ
i did some little things along the way. i converted my A/C to OBA. great mod for sure. i think i have used my AC a total of 2 or 3 times ever and it barely worked...
i went out wheeling as often as i could. i would go out balls to the wall everytime and for some reason would never break axle parts(fine by me).....
that is until my first trip out with some used 35s i picked up off a JF member. i had an 8.8 waiting in my garage so i wasnt worried about my D35. if it broke i was ready. fortunately i could not get that thing to break.
i did end up breaking a d30 ujoint and the stubears off of the shaft
this
led to this
because of this....
at this time i replaced my broken shaft and decided to upgrade to TJ shafts. so out came the 2 piece shafts and small ujoints. (no pics)
by now i had pretty much everything i needed gathered up for my 8.8 swap so i put my jeep under the knife.
i re-used the factory 8.8 spring perches and went SOA. i used stock YJ rear springs and some 1/2" boomerang shackles. i used barnes4wd traction bar mounts and made my own traction bar. i am also running 10" doetsch tech rear shocks
d35 out(sold for $150)
8.8 ready to go in
8.8 rear SOA stock springs 1/2" shackles rear with 4" procomp SUA 7/8" shackles front
traction bar made of 1 1/2" .250 DOM. i used ruff stuff poly bushings on the axle end and a 3/4" hiem on the frame end with some shackles i made
installed
and testing out the new SOA rear flex
i drove it SOA rear SUA front for about a month then decided to tackle the front.
i am using sniper fab offset perches for the front SOA. i also bought Joe Dillards old M.O.R.E. hi-steer setup because he went D60.
i decided to build a new drag link so once again i pulled out some 1 1/2" .250 DOM. i am also using 5/8" ruffstuff hiems.
new drag link
for the tie rod i decided to still use the MORE one but sleeve it to make it almost 1/2" wall thickness. also running 5/8" ruffstuff hiems.
you can see the sleeve here with all the steering installed.
i used stock leafs again for the front with 1/2" boomerang shackles.
here it is on my shakedown drive right after i aligned it in my driveway(white paint on tires)
it sat high in the front so i started making a bastard pack. then ended up going front/ rear bastard. its stock YJ springs with 2nd leaf removed and replaced procomp 4" 2nd leaf. this has helped to keep the springs from sagging and inverting.
steering angles.
loaded up for a trip to big bear in Oct 2011 for a wounded warrior run
no trail pics
post #5 of 890 Old 03-11-2012, 07:15 PM Thread Starter
'92 vegas YJ
around Nov 2011 time i heard that i might be moving to North Carolina(was currently stationed in san diego). little did i know that i would get the for sure word until December 2011. 1 week before they wanted me to leave.
i did once last trip to Corral canyon before i knew i was moving yet
didnt get many pics at all. suspension did good but seemed really "tippy" at times.
i think my flex is great though
NEXT PHASE:
this all started with a craigslist ad for a FREE rollcage. the guy bought the jeep and it had a ghetto home made cage in it so he pulled it and had a new one built by a shop.
he tried selling it on CL and said everytime someone came to look at it they just laughed and said "nevermind, i dont want it".
i then saw the ad for it listed as "FREE, just come get it out of my yard."
i figured id go take a look so i made the drive to Escondido.
to say this cage had bed welding would be an understatement. i dont even think they did any notching. just pieced some tube together and filled the giant gaps with weld. but for free you cant go wrong. worst case i have some free scrap tube now.
here it is when i picked it up
one of the "good" welds
after assessing it for a while i realized the only part i want is the bars that run from the B pillar across to the A and down. this was 1.75x.120 Tube
AGAIN you have to remember this was free. i am at no loss. i know i can have someone bend me that piece that follows the windshield line a little better but i would have to buy the tube then get it bent.
i decided that i will use the previously mentioned pieces and get some new 1.75x.120 DOM and make a trail cage from there. so thats what i did. i spent less than $100 on the rest of the DOM.
here is the down bars tacked in as well as a winshield spreader bar and a dash bar that i cut and notched
you san see by the B pillar where i cut the tube. i just cut it off the old B pillar about 10" back from the weld. next i took some of the DOM i bought and nothced it correctly and internally sleeved them with .250 wall and welded it all around and did 8 rosette/plug welds per side. i dont know if im gonna get flack for this but i feel it is plenty strong.
next i measured and cut and notch some spreader bars. because i dont have a bender if i ran them to the corners for triangulation it would touch my head with me just sitting in the drivers seat. so for now i just went straight across like the blue torch kit. i will figure out some triangulation later.
notched with a 1 3/4" hole saw and drill press.
ready for welding
one of the welds. im not the best in the world but i think i do ok. it was really hard to get a good pic of one of my welds. this was one of the best i could get but its not one of the best welds on the cage
and then added some paint
and thats it for that day.
not bad for less than $100. i added more at a later date. i had to really hurry up with this project as about halfway though i found out id be moving in less than 2 weeks.
post #6 of 890 Old 03-11-2012, 07:32 PM Thread Starter
'92 vegas YJ
about a week after i finished up that portion of the cage i moved. the navy came and packed up my house and moved it all out to North carolina.
i had about a month until i had to be in NC so i chose to drive home for the holidays along my cross country trip.
first thing i did when i got home to Las vegas for the holidays is add a little more to my 'cage. i did some windshield bars and did the rear half. still gonna add more gussets and tube but thats another day.
then i went out and did some Las Vegas wheeling. I wheeled in Logandale, Nv which is red slickrock, kind of like Moab.
i didnt get a lot of pictures as i was too busy wheeling. most of the ones i got are of me just stopped. pretty lame. i layed it against a rock once and 2 and 1 wheeled it NUMEROUS times. most of the day my friends saw my belly as i was high in the air with the front.
i also accrued a little more body damage. some smashes on my driver and pass. corner.
little idea of what Logandale is like
driver body damage
good cage shot
a random shot
and another
after the holidays i hit the road, bound for NC. i flat towed the jeep the entire way
once i got to North Carolina i was on the hunt for a house. it had to have some ample parking and i decent size garage. because im only renting it took a couple weeks to find a place.
then i stumbled on the perfect pad for me.
the new house
and the jeep in its new home before i moved in all my tools.
the first thing i had to do to the jeep once i got settled was change out my front springs. while out in vegas i accidentally jumped my jeep and bent the crap out of the front springs.
i figured now was a great time to get a little stretch and try out some waggy springs.
i hit up the junk yard and was able to get a front pair of springs from a '89 grand wagoneer.
the waggys give you approx. 2" of stretch, i used my offet perches to gain another inch. im now at 97"WB.
before anyone asks, NO MY DRIVESHAFT DID NOT REACH. i still need to order a new front shaft.
heres a couple before pics
and after the 3" front stretch
post #7 of 890 Old 03-11-2012, 07:34 PM
awinski
deffinately a great build thread
awinski is offline
post #8 of 890 Old 03-11-2012, 07:44 PM Thread Starter
'92 vegas YJ
and that brings me to today.
a couple weeks ago i ordered some PoisonSpyder aluminum YJ corner armor but once i received them i realized they got damaged in shipping and i had to send them back. its taken a couple weeks to get the issue resolved with PSC and UPS but will hopefully have my new corners in the mail in a couple days.
once i get my corners i plan on painting them black, installing some rockers i got off the REDBULL TJ and redoing my front fenders.
i figured while im waiting, in the little bit of off time i have from work, i could do a little work on my fenders. i just barely got them finished the day before KOH 2011. i was in a rush and the body work was pretty ugly. its been bugging me the whole time but i never did anything about it.
well i figured since id be repainting them i should finish them correctly.
also a few months ago i scored some fender louvers from GenRight from there CLOSEOUT section. normally theyre $50 but i was able to get them shipped for aroud $20. i figured it was a good deal. all i have to do was cut a giant hole in the side of my fenders i made. no big deal
heres a sneak peak at the fenders
also another dilema most people face with a custom cage is where to mount a rearview mirrow. i was going to weld a tab and then just use my factory mirror but i came up with another solution. i was browsing through amazon.com and i stumbled across a mirror for UTVs. its a round clamp that fits 1.75" tube. i got it to my door for once again about $20. its also easilly removable for the trail if i want, i think this mirror is PERFECT.
heres some pics
and finally just a random picture of my jeep all naked(with my other baby). just waiting for my corners to get everything painted and installed.
post #9 of 890 Old 03-11-2012, 07:46 PM Thread Starter
'92 vegas YJ
thanks.
i figured im long overdue for a build thread on JF
post #10 of 890 Old 03-13-2012, 05:46 AM
rulppa
About your rear traction bar, did you make new crossmember and mounted it there or welded bracket on your skidplate? Any problems/axle wrap with waggy leafs (front SOA) without bar?
Looks good, subscribed.
Build in progress at
rulppa is offline
post #11 of 890 Old 03-13-2012, 06:42 AM Thread Starter
'92 vegas YJ
For the rear traction bar I just welded a bracket onto my skid plate.
I also don't have any axlewrap in the front that I notice. I still haven't been out on the trail with the springs yet because I have to order a new driveshaft still. I will let you know if I have any adverse efffects. I don't think I will though
post #12 of 890 Old 03-15-2012, 10:51 AM
jeepyj13
love the build thread
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #13 of 890 Old 03-16-2012, 01:17 PM Thread Starter
'92 vegas YJ
Thanks man.
I'm out of town right now but should have some parts waiting for me when I get home next week....
Still waiting to receive my corners from PSC, have some rock lights on the way and new fancy rocker switches for my rock lights and my OBA.
post #14 of 890 Old 03-21-2012, 05:13 PM Thread Starter
'92 vegas YJ
back with a small update.
i had to go out of town for a week for work and when i returned i had some things waiting for me on the dining table.
before i left i ordered some Daystar rocker switches and some switch covers. i ordered 3 switches from amazon with free shipping for $30. after i ordered them i thought about how i wanted some labeled ones. i found this https://otrattw.com/products.php?cat=5 website and ordered 2 labeled ones. i havent ordered a 3rd because i dont have anything else i need to run yet.
1 still in the box
and my 2 with the replacement switch covers
thats it for now. still waiting on some more stuff to come in the mail. i need to get out in the garage this weekend and try to finish up my front fenders
post #15 of 890 Old 03-26-2012, 01:37 PM Thread Starter
'92 vegas YJ
just got off the phone with Curtis Tatton, ordered my new front drivesahft.
also called up PoisonSpyder and STILL waiting to find out about my corners. im really starting to get irked about it. I received the corners in less than a week from the original order but then had to send them back because they were damaged. now ive been waiting for over a month for them to even ship out my new corners. so far im very dissatified with PoisonSpyder. unless they do something to improve my experience with them i will never shop with them again and recommend others not to as well.
besides that ive been spending all day trying to finish up my fenders and get my new rockers installed. will hopefully be done with that today.
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
smitty built rear bumper, the non tire carrier version bandit455 Jeep Picture Requests 11 11-19-2009 05:05 PM
Tomb Raider Rubicon Gallery (film version)? Mead Jeep Picture Requests 0 11-08-2006 07:08 PM
