Just another LJ build - Page 91 - JeepForum.com
 1Likes
post #1351 of 4130 Old 06-25-2013, 11:06 PM
clintrivera
In this global economy most things are made overseas. If it matters, my MTR's say made in the USA.
clintrivera is offline
post #1352 of 4130 Old 06-25-2013, 11:13 PM Thread Starter
G Beasley
If I can I buy American , my thought is that it keeps someone here in a job. I like the new MTRs , but I LOVED the old style makes it hard for me to like the new ones .
G Beasley is offline
post #1353 of 4130 Old 06-25-2013, 11:20 PM
clintrivera
The old one's were pretty noisy on the road. The new ones were designed with a supercomputer so that has to mean they are good right?
If you look at the DOT code it will tell you where it is made.
DOT Code Company
BE B.F. Goodrich (Michelin) Tuscaloosa, AL
BF B.F Goodrich (Michelin) Woodburn, IN
AN B.F. Goodrich (Michelin) Opelika, AL
VE/YE/YU/8B Bridgestone/Firestone (Bridgestone) Des Moines, IA
2M/3M Bridgestone/Firestone (Bridgestone) Bloomington, IL
D2/E3/W1/Y7 Bridgestone/Firestone (Bridgestone) Lavergne, TE
2C/4D//5D Bridgestone/Firestone (Bridgestone) Morrison, TE
UP Cooper Finlay, OH
UT Cooper Texarkana, AR
DY Denman, (Penslar Capital) Warren, OH
DA Dunlop (Goodyear) Buffalo N.Y.
(my home town that is always hurting for work!)
JJ/MD/PU Goodyear Gadsden, AL
JN/MJ/PY Goodyear Topeka, KS
JE/MC/PT Goodyear Dansville, VA
JT/MK/TA Goodyear Union City, TN
JP/MP/PL Kelly-Springfield (Goodyear) Tyler, TX
JF/MM/PJ Kelly-Springfield (Goodyear) Fayetteville, NC
CC Yokohama Tire Salem, VA (Good tire) nickname: "Chokeyourmama"
post #1354 of 4130 Old 06-25-2013, 11:33 PM
Jankoid
Your Pitbulls are made in the USA , too bad they would shake my teeth out on the trip to the trail The MTZ is a nice looking tire , but they are expensive ! Of course none of the other tires are cheap .Sadly the cheapest is the Grabber and it doesnt have the best reviews .
Yeah, Pitbulls arent the most street friendly tire out there.
MTZs are awesome, but not worth the $60+ they cost above the other MTs on the market. I found mine new for $170 each a couple years back and jumped on them. Definitely would not buy them for retail though.
Jankoid is offline
post #1355 of 4130 Old 06-26-2013, 10:25 AM Thread Starter
G Beasley
I saw you trying to buy spare MTZs over on NC 4x4 , are they for the TJ ? Still searching for tires , should find something out this afternoon when I get the LJ inspected .
post #1356 of 4130 Old 06-26-2013, 10:45 AM
jeepbro's
A little off topic, but I just noticed your in Eden. I recently started working nearby out of the DOT office Riedsville and am usually working day to day in Madison on site for a bridge replacement. If you see any new plain white f150 with a yellow light on the roof checking out your jeep as you drive by its probably me... or one of the other 8-9 guys that work out of the same office
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #1357 of 4130 Old 06-26-2013, 10:45 AM
Jankoid
Negative. If I buy them they will be for the LJ. Would be good tires for cruising around town and hitting the local trails; save the Pitbulls for big trips like Harlan and Windrock. My current MTZs are going on the TJ since they have 80-90% tread. Main reason though is that I could put off buying beadlocks for the Pitbulls directly after the axle swap. Mount the low tread MTZs on some cheapo steelies and deal with them until I can afford some nice beadlocks.
Jankoid is offline
post #1358 of 4130 Old 06-26-2013, 12:01 PM Thread Starter
G Beasley
Are you driving back and forth from Raleigh ? I am headed over to Reidsville today to get the Jeep inspected , feel free to holler at me if you see me and we can talk Jeep .
Gotcha , good beadlocks are a sound investment . With the luck you have had double beadlocks may be in order .
post #1359 of 4130 Old 06-26-2013, 12:10 PM
Jankoid
Do you mean that in a good way or a bad way?
Jankoid is offline
post #1360 of 4130 Old 06-26-2013, 12:12 PM
jeepbro's
Chapel hill, each day but the company truck came with a gas card so I don't have to buy fuel at least. And ya I'll def flag you down if I see you sometime.
know anywhere cheap to live around the area. I either want super cheap that's at least not gross and is livable just to stay in Mondays - Thursday andjust go home over the weekend or somewhere decent for a bit more
post #1361 of 4130 Old 06-26-2013, 10:29 PM Thread Starter
G Beasley
Theres a nice little single wide close to me for rent , at least it looks nice from the outside . Its in the country off the major roads , but only two miles from 14 . I can get the number for you if you are interested ?
post #1362 of 4130 Old 06-28-2013, 04:56 PM Thread Starter
G Beasley
Todays Jeeping
Washed the Jeep and got the top and doors removed early .
The more exciting news is that Jonathon came over and popped a Rubicon locker bypass in for me . Now I can run the lockers in 2wd , and high range . He made it look easy , but I am pretty sure I would have made a mess of it . For the record 12v is teh debil !
And trailer fabbing is back underway with a goal of getting it titled by the end of next week .
post #1363 of 4130 Old 06-28-2013, 05:00 PM
Sundowner
Schweet.
Sundowner is offline
post #1364 of 4130 Old 06-28-2013, 07:39 PM
jforse
Todays Jeeping
Nonsense 12volt is easy.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #1365 of 4130 Old 06-29-2013, 07:04 AM Thread Starter
G Beasley
Schweet.
Shocker isnt it ? The paperwork with the DMV is submitted , just need to get it road ready and to the State Highway Patrol for the final inspection .
Its easy for you , and I thought it was easy to until I roasted my old VW cabriolet years ago .
Todays Jeeping
Off on a parts run to pick up and drop off stuff along the way . And we are going to go through Seagrove to check out the clay pots along the way .
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 11:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
