Just another LJ build - Page 71 - JeepForum.com
 3Likes
post #1051 of 4138 Old 05-11-2013, 10:02 PM Thread Starter
G Beasley
Originally Posted by Moabrubi View Post
Looks good, I need to sleeve mine as well. Looks like the synergy sleeves are the way to go.
Thanks, though the welds look awful.
The Synergy sleeves offer a lot of additional strength for the money and they slid right in.
G Beasley is offline
post #1052 of 4138 Old 05-11-2013, 10:11 PM
clintrivera
Is the upper BJ the one that's tapered a little? I put a washer between the adapter to straighten out the taper to get it pressed straight. It took a little fiddling, but it was a free fix and worked fine. There's a youtube video that shows how it works.
clintrivera is offline
post #1053 of 4138 Old 05-11-2013, 10:40 PM
AndyE
Is the OTC 7894 the adapter kit you have?
Yes.
My old HF press died , so I need to replace that too . Is your OTC press American made?
Sadly the only markings I can find that say where it's made are on the plastic case it comes in. And that says Made in China. That being said I've(Kate and redrelyt12 as well) beat on it pretty good and haven't managed to break or bend it, yet.
Theres always some HREW and DOM floating around the shop.
Sounds like I need to get some fab tools so I too can have random DOM hanging around.
Build Thread
AndyE is offline
post #1054 of 4138 Old 05-12-2013, 12:09 AM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
You got some momentum going today Beasley, that's cool. To bad that ball joint held you up. Those must fit a little tighter than the Spicers, Mine wanted to start no problem with my HF press. I hope that Plate is for ME!
gst95dsm is offline
post #1055 of 4138 Old 05-12-2013, 09:14 AM Thread Starter
G Beasley
It doesnt look tapered , but the fins could be throwing off my perspective . I will try and find the youtube video to see the trick . I have done ball joints before , but none of the adapters I have seem to fit just right .
Originally Posted by AndyE View Post
Yes.
Mine is bent , and it lost the first three threads . Good old HF ...
Having fab tools is fun , but you end up with friends you didnt know you had .
The diameter of my adapters just wont sit square on the joint . With what I have read it seems the kit Andy has is the way to go .
Its an oldie but a goodie and bound for Utah .
I took apart one of the stock ball joints and it does have a plastic liner.Not sure if all of them do , but mine were original and had the dreaded plastic . I will post pictures of the ball joint internals when I get back home. My lower ball joint was completely shot , I could wiggle it with one finger so as much of a pain in the butt this has been it was needed work .
The good news is that I am almost half way done on the drivers side . The bad news is that I am leaving for PA in 15 minutes and I still have the whole passenger side left . Momentum is on my side and with the OTC kit I think the passenger side will go much better .
post #1056 of 4138 Old 05-12-2013, 10:46 AM
Jankoid
I dont think either ball joints are tapered. I used a HF press for my lower ball joints, and a combination of a HF adaptor and BFH to get the uppers in.
Jankoid is offline
post #1057 of 4138 Old 05-12-2013, 12:51 PM
Holaday
Dang you are making some serious progress. On the BJ press, I just used a piece of scrap to level it out instead of buying the kit.
Holaday is offline
post #1058 of 4138 Old 05-12-2013, 07:08 PM
clintrivera
It's not the ball joint that's tapered, it's the inner C where the ball joint goes into. The bottom of it is tapered and doesn't let the lower cup sit correctly.
post #1059 of 4138 Old 05-12-2013, 08:45 PM Thread Starter
G Beasley
I havent had to use a hammer to ever put a ball joint in , I hope to continue that streak .
I tried a little bit of everything with no luck . The OTC press and Dodge kit are on the way to the house . With any luck I will press in all the joints next Saturday night .
Now that you mention it , I think I did see that the metal was rusty at the bottom where the ball joint wasnt making contact .
So as mentioned above the OTC kit is on the way to the house and I am freezing here in PA . Thankfully this is a short job and I will head home Friday night . On the way here I passed by the exit for Rausch Creek , and there were a bunch of nice rigs loaded up and heading out ... I need to get up here and wheel one day .
post #1060 of 4138 Old 05-12-2013, 08:58 PM
gst95dsm
gst95dsm's Avatar
Beasley, I've decided what I think you do for a living. You travel all around.... kind of not knowing where you'll be, not really knowing how long it will take. Seems like you just get a call and your off...... I think you might be a HITMAN.
gst95dsm is offline
post #1061 of 4138 Old 05-12-2013, 09:15 PM Thread Starter
G Beasley
Thats funny that you say that as you arent the first one to come up with that theory Would this be a bad time to mention that I am a wicked accurate marksman ?
I thought for sure I had mentioned what I did on here ? Ahhh the intrigue
post #1062 of 4138 Old 05-12-2013, 09:52 PM
gst95dsm
gst95dsm's Avatar
Haha, na let's just go with Hitman.
gst95dsm is offline
post #1063 of 4138 Old 05-13-2013, 08:58 PM Thread Starter
G Beasley
Its off to Fort Bragg next , then NYC . Of course I have Moab in between .
The OTC press and adapters will be at the house tomorrow , and all of the control arms came in today . I think the rub rails came in too , but I havent gotten any pics from my wife yet . I cant wait to get back home and finish the front end up .
post #1064 of 4138 Old 05-13-2013, 10:02 PM
gst95dsm
gst95dsm's Avatar
Just say the word and I'll take care of the HIT in Fort Bragg..... less than a day's drive for me. I'll keep it clean.
gst95dsm is offline
post #1065 of 4138 Old 05-13-2013, 10:05 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Sounds like torture.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
