Just another LJ build - Page 65 - JeepForum.com
 1Likes
post #961 of 4130 Old 04-17-2013, 07:17 PM Thread Starter
G Beasley
Originally Posted by Holaday View Post
Figured, just couldn't help but give you a little **** or that comment.
Good group going to SMORR on the 23rd. I think you should make a road trip...
I leave for the Black Hills and then Moab on the 24th , though I plan on being in Missouri this Fall .
G Beasley is offline
post #962 of 4130 Old 04-17-2013, 07:55 PM
143DAD
We might make that date, I'm only an hour from SMORR.
Any color will do as long as its black.
143DAD is offline
post #963 of 4130 Old 04-17-2013, 08:08 PM
Holaday
When this fall? Jeepstock at SMORR is always a great time and normally late September. Lucky SOB on Moab
Lucky, it is a 4 hour haul for me. You should definitely come.
Holaday is offline
post #964 of 4130 Old 04-17-2013, 08:38 PM
143DAD
SMORR Rock the Ozark run is 26 th thru 29th of September and SMORR in the fall is October 17 thru 20th we have done both and will this year both are great events.
143DAD is offline
post #965 of 4130 Old 04-17-2013, 09:03 PM Thread Starter
G Beasley
Wish I lived out there , lots of wheeling going on .
More parts arrived today .
The tower section of the kit looks used to me ?
post #966 of 4130 Old 04-17-2013, 09:24 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
That's a little dirtier than mine was, but not much. That 1" plate must sit a while before it's cut. Mine was pretty filthy as well. It's actually not a very well designed piece. If it's only intended purpose is to live on a D30 or D44 TJ axle housing.... then it should be cut at an angle to account for the angle of the bracket. I know it's a proven part and that "special" cut might add cost.... but it's a little cheesy how poorly it actually fits the axle tube. I would have ground it down to sit flush (which would have been a sucky job) but I didn't want to possibly upset the length of my control arm since it lined right up without any grinding. In order to weld that portion to the tube...... I had to "fill" the area with weld.....because the gap was considerable and then I ground it down. FWIW, I do believe my bracket was bent and that may have added to the issue. Still feels GOOD to have a JJ in there and not clevite. I think my radius arms stress the crap out of that link mount.
gst95dsm is offline
post #967 of 4130 Old 04-17-2013, 10:17 PM
Moabrubi
Mine fit great on the axle tube, granted I didn't weld it to the axle tube like the instructions said. I just did a plug weld in the back instead.
Moabrubi is offline
post #968 of 4130 Old 04-17-2013, 10:56 PM
gst95dsm
gst95dsm's Avatar
Take a photo of the front of it if you would, I'd like to see how much different it was from mine. I also did the plug weld.
gst95dsm is offline
post #969 of 4130 Old 04-18-2013, 12:12 AM
Moabrubi
Here's the best pic I have at the moment. I thought it sat on there a little better then that.
It's not perfect as there's a little gap, but one pass would take care of it. I just didn't see a need to weld it to the tube. I have seen some where the bottom doesn't even touch the axle tube.
Moabrubi is offline
post #970 of 4130 Old 04-18-2013, 12:18 AM
gst95dsm
gst95dsm's Avatar
Yours fit better than mine. Your bracket must have been at less of an angle. Thanks for the pic.
gst95dsm is offline
post #971 of 4130 Old 04-18-2013, 02:10 PM Thread Starter
G Beasley
Kinda nice to have the how to pics posted in the thread before I have to install them
On another note I have begun the upper control arm switch out ...
post #972 of 4130 Old 04-18-2013, 02:22 PM
AngryTJ
of the people who have done that mod, do you have to remove the bushing before welding that piece onto the axle?
AngryTJ is offline
post #973 of 4130 Old 04-18-2013, 02:34 PM
gst95dsm
gst95dsm's Avatar
No you don't have to remove it, must be able to take the heat.... I think its a ***** reassemble a jj without the right tools.
gst95dsm is offline
post #974 of 4130 Old 04-18-2013, 02:39 PM
gst95dsm
gst95dsm's Avatar
So your home and working on it??? I didnt know new uppers were on the agenda!
gst95dsm is offline
post #975 of 4130 Old 04-18-2013, 02:44 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
When you get thru with this part, it will be the best LJ on 33s
16 Taco
87 MJ Chief in pieces
dayriesw is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
