Just another LJ build - Page 55 - JeepForum.com
 1Likes
post #811 of 4130 Old 03-24-2013, 09:00 PM
AngryTJ
I plan to get a stick with a magnet at the end, pull the shafts, drill the holes, clean, insert sleeves then weld. I would end up drilling right through the sleeves if I tried what your planning.
AngryTJ is offline
post #812 of 4130 Old 03-24-2013, 09:10 PM Thread Starter
G Beasley
I plan on using a stop collar/depth gauge to stop the drill at the right depth. They are pretty cheap , and come in quite handy . My fear of the magnet technique is missing flakes , but after some thinking I believe those fears may be unwarranted .
G Beasley is offline
post #813 of 4130 Old 03-25-2013, 09:04 AM
Sundowner
I'd pull everything apart and set the housing up on the bench to do the drilling, and then I'd swab out the flakes and chips and dust before installing and welding the sleeves...almost like running a brush and cleaning patches through a barrel.
Sundowner is offline
post #814 of 4130 Old 03-25-2013, 10:11 AM Thread Starter
G Beasley
How many welds would you add? I am planning on four plug welds per side. I thought that would be sufficient?
post #815 of 4130 Old 03-25-2013, 10:20 AM
clintrivera
According the the instructions they want you to drill a total of 16 holes.
clintrivera is offline
post #816 of 4130 Old 03-25-2013, 10:28 AM
Jankoid
16 plug welds is total overkill. When I sleeved my hp30 (made the sleeves myself though) I did 3 plug welds on the long side and only 1 plug weld on the short side. Combined with being welded at the end of the tube that sleeve will never move. The plug welds are only there to hold it in place, not to add any strength to the sleeve.
Jankoid is offline
post #817 of 4130 Old 03-25-2013, 10:29 AM
Sundowner
I would not add any. Mark would add quite a few.
I was somewhere in the 16-ish neighborhood with my rough count...but that doesn't include the tube-to-center welds. I really need to get my hands on a baby TIG setup...
post #818 of 4130 Old 03-25-2013, 12:29 PM
AngryTJ
I was planning to do 6 on the long side and 2 or 4 on the shorter end.
AngryTJ is offline
post #819 of 4130 Old 03-25-2013, 08:09 PM
Moabrubi
Do you know the page # of the under armor installation/installed pictures? I searched through the thread but couldn't find it.
Moabrubi is offline
post #820 of 4130 Old 03-25-2013, 08:49 PM Thread Starter
G Beasley
I didnt get directions , just two big pieces of tubing . Thanks for the link , though I think that is overkill as Jankoid states below.
I agree thats a lot of holes , 6 and 4 is what I think I am going to do .
Next time your over we are firing up the welder .
I like the 6 and 4 count , I think thats the route I am going .
http://www.jeepforum.com/forum/f22/j...l#post12808885
This should take you to the start . If not the install starts at post # 54 .
post #821 of 4130 Old 03-25-2013, 08:52 PM Thread Starter
G Beasley
The view from the cabin here in Minnesota ... you betcha !
post #822 of 4130 Old 03-25-2013, 09:21 PM
Sundowner
Nice. Except for the snow. I hate some snow.
I'll photograph you welding all day long, but unless you want Mark to be grinding out welds in addition to applying them, you'd better keep me away from it.
post #823 of 4130 Old 03-25-2013, 09:34 PM Thread Starter
G Beasley
Hmm , you hate snow . And you hate Monkeys ... so then you must really love the Snow Monkeys !
Next time over you are welding , you cant get better at it unless you practice.
post #824 of 4130 Old 03-25-2013, 09:52 PM
Sundowner
Repeat: The only good monkey is a pre-killed monkey.
post #825 of 4130 Old 03-25-2013, 10:39 PM Thread Starter
G Beasley
All of my pre killed snow monkeys come from ballistic , so it may be a while before they come in ...
Back on topic , the Superior axle shafts came in today . This leaves me waiting on the Synergy ball joints . Once I finish up this job I should have three or four weeks to get everything ready for Moab .
If the red truck sells before I head west , I may order new shocks and control arms . I am half way convinced my knocking noise is coming from one of the JKS arms . When I get back I am going to try and get it on a lift to isolate the noise . If that is the culprit , then I have to figure out what arms to get ...
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 11:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
