Just another LJ build - Page 236 - JeepForum.com
 1Likes
post #3526 of 4130 Old 06-09-2014, 08:51 PM Thread Starter
G Beasley
Originally Posted by ravenworks View Post
Well I would ultimately like to have the skid bolt to the frame and extend to the oil pan in two pieces with the bolts flush to the pan.
Also going to do remote transmission/engine oil filters.
I've been reading up and I am liking the thought of using aluminum.
As for the weight loss I came home from the Marine Corps in 81 and started to pick up weight.
By 91 I gained 150 lbs.
By 2001 I couldn't take it anymore so I started watching what I ate and in two years I went from 325 to 200.
I am now at 219 but only consider myself to be about 10 lbs over weight.
I think eating good is the key and I am guilty of not doing that.
Do you plan on going with Savvy or UFC or making your own armor ?
As to the weight its easy to pick up , but difficult to lose . I am however hovering just above the 40lbs lost mark ... that will be a happy day when I hit that number ! I did look at the pictures today from day 1 until now and I was surprised at how much difference there is .
No Jeeping today . Lots of yard work , and I rebuilt the teeter totter for the bikes .
Also chopped out a stump crossing with recessed 2"x6"s It looks worse than it is , but the dive bombing momma bird will keep us off it for a while .
My daughter Hannah is excited for new stuff to ride her bike on .
G Beasley is offline
post #3527 of 4130 Old 06-10-2014, 08:44 PM Thread Starter
G Beasley
I drove the Jeep 5 hours today at 65 mph and I am happy to say that it was a nice ride . I think I am getting used to the higher rpm's and the underhood heat wasnt unbearable .
post #3528 of 4130 Old 06-10-2014, 09:09 PM
OkLaHoMaTJ
I really like the higher RPM's way up here. Cruising through the passes is much more manageable…not excellent…but MUCH better than what it was.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #3529 of 4130 Old 06-11-2014, 03:56 AM
91AzXJ
40 lbs is an amazing feat! You should be proud that you had the decipline to stick with it.
2000 XJ 4.0L/ Auto
04 TJ 4.0L- RIP 06 KJ Ltd
11 KK 70th Anniversary
91AzXJ is offline
post #3530 of 4130 Old 06-11-2014, 08:50 AM Thread Starter
G Beasley
The Western passes are one of the biggest reasons I re geared . It was awful dropping down to third and feeling like a trucker . I didnt clock my mileage yesterday , but I went 250 miles before the light came on .
Thanks , but I am not done yet . I have another 40lbs to go before I am to a good healthy weight . I suspect I will be there by the end of the year with the rate of loss I am maintaining . Once I get my weight where I want it will just be a matter of maintaining it .
post #3531 of 4130 Old 06-11-2014, 09:48 AM
Moabrubi
What the hell man, at 180 mine is dinging at me :laugh.
Moabrubi is offline
post #3532 of 4130 Old 06-11-2014, 09:50 AM
Moabrubi
I havent recalibrated the speedo and all my driving includes wheeling so maybe that explains it.
Moabrubi is offline
post #3533 of 4130 Old 06-12-2014, 06:09 AM Thread Starter
G Beasley
I spent the whole trip at 64 mph on relatively flat roads , but we achieved similar numbers last summer out West .
Actual work took place on the Jeep yesterday ! Jonathon came over and between the two of us we figured out how to fix the radio release assembly . So now the radio is in and sounds awesome .
After the radio was in we pulled a rear spring and installed a Rokmen bumpstop . The hardest part of the install is pulling the spring ! I will say that a right angle or 45 degree drill make this job much easier as it is a tight space . After drilling and tapping the hole I reinstalled the spring and then slid the puck in through the coils . Its pretty easy to get a socket on the bolt and snug it down . Now my tire wont eat the flare anymore !
post #3534 of 4130 Old 06-12-2014, 08:36 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Wait, you still have a jeep????
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #3535 of 4130 Old 06-12-2014, 02:38 PM Thread Starter
G Beasley
Crazy isnt it ?
post #3536 of 4130 Old 06-13-2014, 10:05 PM Thread Starter
G Beasley
I got the garage cleaned up and Ol Blue back onto the concrete today . Blue is getting the fuel tank drained , new fuel filter , and new fuel line when I get back from Disney . I also think the 1bbl carb is coming off and getting rebuilt , thanks Ethanol !
post #3537 of 4130 Old 06-14-2014, 08:13 PM
Cuder
Greg, What model is Ol Blue? Have you seen this truck build?
http://www.jeepforum.com/forum/f57/6...build-1267426/
My Build Thread:
Cuder is offline
post #3538 of 4130 Old 06-15-2014, 05:06 PM
bbusch
I'm lucky to get to 180 before the light turns on, usually around 150. Way back in the day 220 was the norm., not sure what happened. I seek out non ethanol fuel when I can and that helps but Chevron is the only station I'll fill her up, finding stations out west that are zero ethanol is now nearly impossible.
Greg, are those JKS bumpstop spacers? When I do my Pro Rock 60 and front PR 44 I'm going to do the JKS Pro Adjustable spacers but thinking I may be able to get away with just one set of lower bumpstops and split them up between the front and the back. Looks like you used just the one (comes with three for each side).
edit.. eh, doesn't look like my idea will work, the top two spacers don't screw down (base spacer is needed). Looks like you went with Rokmen, gonna check those out.
03 Black Rubicon
My Rig
bbusch is offline
post #3539 of 4130 Old 06-15-2014, 08:10 PM Thread Starter
G Beasley
Mine is a 76 all stock . And yes I have read that thread , really amazing work .
I do my best to only run ethanol free fuel and we have quite a few places to get it around home . I also have the Macs clean/cold air intake and I saw a little bump in the mpgs over the last 5000 miles from it .
I have JKS spacers up front , but they are being replaced by a slightly higher Rokmen .
You are correct sir ! I do have the Rokmen bump stops . They are simple and work well . Best of all once the hole is drilled and tapped you can change the heights without pulling the spring . So if you dont get it set just right the first time its no big deal to change .
Also ran across the family truckster today ...
post #3540 of 4130 Old 06-15-2014, 08:46 PM
bbusch
Looks like you came across the Griswalds. I thought they totaled that rig with granny on top.
03 Black Rubicon
My Rig
bbusch is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 11:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
