Just another LJ build - Page 226 - JeepForum.com
 3Likes
post #3376 of 4131 Old 05-05-2014, 04:46 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
For the record.... Who said 4.88s were already to deep for a 6 speed and 35s?
Remove the inners or the hood. I bet on of those will work.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #3377 of 4131 Old 05-05-2014, 06:27 PM Thread Starter
G Beasley
There were three or four of you ... Y'all were right I was wrong unless you figure in the towing and then it feels just right . The louvers and inner fender scoops should get rid of a lot of the heat retention .
I am having a raw aluminum finish HyLine louvered hood panel shipped to Hendrix for some Mercedes black , and I will be building the inner scoops from sheet metal .
Also looking for a stock LJ cage if anyone has one they want to get rid of .
G Beasley is offline
post #3378 of 4131 Old 05-05-2014, 06:31 PM
sjones26573
Did you check with Jake? He might have one.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3379 of 4131 Old 05-05-2014, 07:04 PM Thread Starter
G Beasley
I forgot to check with QuadraJake ... what doesnt he have ?
post #3380 of 4131 Old 05-05-2014, 07:21 PM
Jankoid
1. That's ****ing hilarious.
2. I do have one.
Jankoid is offline
post #3381 of 4131 Old 05-06-2014, 04:15 PM Thread Starter
G Beasley
2. I do have one.
Hilarious and true ...
Todays Jeeping : I am stuck in a hotel in Northern Jersey hoping for good weather this weekend as I am headed home . Not much Jeeping right? Well in the midst of this sitting I am buying parts and planning a trip to Cape Lookout N.C.
post #3382 of 4131 Old 05-06-2014, 07:04 PM
Treadway
http://www.weather.com/weather/weekend/USNC0423
The odds are becoming more in our favor my friend!
Treadway is offline
post #3383 of 4131 Old 05-06-2014, 07:06 PM
awinski
2. I do have one.
just too funny
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #3384 of 4131 Old 05-06-2014, 07:07 PM Thread Starter
G Beasley
I am currently flying out Friday morning and driving up that night . Hopefully the weather forecast continues to clear up .
post #3385 of 4131 Old 05-06-2014, 09:30 PM
clintrivera
How hot is it getting? Your Jeep shouldn't be overheating even if it was turning 5K RPM's. I would look at your cooling system.
clintrivera is offline
post #3386 of 4131 Old 05-07-2014, 03:52 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
What is the stock cage for?
16 Taco
dayriesw is offline
post #3387 of 4131 Old 05-07-2014, 05:39 PM Thread Starter
G Beasley
The Jeep doesn't overheat , but the grille and hood are considerably hotter than it used to be . I do think I will go for a new water pump, high flow thermostat housing and new radiator if I end up driving to Utah for work next month .
I want to build a new cage , and it would be nice to have a stock cage to pull numbers from out of the tub . The latest revision I have come up with does away with all of the factory tube , so I might not need the cage after all.
post #3388 of 4131 Old 05-08-2014, 08:10 AM
gspup
My words of wisdom are build off the stock cage. It will be cheaper and much less of a headache in the long run. Go enjoy that LJ you just rebuilt. You don't have any racing specs to meet in your future...do you
gspup is offline
post #3389 of 4131 Old 05-08-2014, 08:57 AM
Jankoid
What's wrong with your current cage and do you want to donate it to a good cause?
Jankoid is offline
post #3390 of 4131 Old 05-08-2014, 11:11 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
The stock cage is not made from the same quality metal that G would use to build a whole new one such as dom. And Racing specs? How about driving the family across country pulling a trailer specs? Using the stock cage as a base is nice for a trailered crawler slow speed only crawler maybe.
What does sunny say? If it is worth doing, it is worth overdoing.
16 Taco
dayriesw is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
