Just another LJ build - Page 152 - JeepForum.com
 1Likes
post #2266 of 4130 Old 01-06-2014, 10:48 PM
green50gt
green50gt's Avatar
Originally Posted by aw12345 View Post
2003 to 2006 Rubicon factory real locker is a limited slip if not locked, what happens is that the worm gears for the limited slip part like to dis integrate. Thereby destroying the locker. Fairly common malady when used hard and often
Huh. I also did not know this. Good to know thanks a lot, I was about to ask the question myself.
green50gt is offline
post #2267 of 4130 Old 01-07-2014, 10:14 AM
gspup
Everyone I know usually keeps their rear locked on anything with decent sized rocks. g-rocc is your rear locker usually on ?
Only rubi locker I've seen boom happened when my bud karl experienced his rear UCA axle side mounts ripping off, destroyed the DS u-joints and breaking a rear cromo on the Patriot exit. But I think the stock welds were at fault for the whole shebang.
gspup is offline
post #2268 of 4130 Old 01-07-2014, 12:05 PM
g-rocc
Originally Posted by gspup
Everyone I know usually keeps their rear locked on anything with decent sized rocks. g-rocc is your rear locker usually on ? Only rubi locker I've seen boom happened when my bud karl experienced his rear UCA axle side mounts ripping off, destroyed the DS u-joints and breaking a rear cromo on the Patriot exit. But I think the stock welds were at fault for the whole shebang.
Only when needed. That being said, I'm locked front and rear the entire time on some trails (patriot, carnage). On trails like chinaman I only lock up at the big obstacles.
g-rocc is offline
post #2269 of 4130 Old 01-07-2014, 07:13 PM
locrwln
Jody is going to detail the process , have your gear guy take a look at it once its complete ... which should be by the end of this week. Other than a little grinding and a very thick pinion shim it seems pretty straightforward .
The kit is from a yet to be named vendor in NC , and depending on how all this works out I think they may offer a JK gear swap kit .
Looking forward to this.
Jack
2006 LJ Rubicon
locrwln is offline
post #2270 of 4130 Old 01-07-2014, 08:16 PM
Treadway
OkLaHoMaTJ- I tried to reply to your PM, but your box is full.
I received most of my remaining parts needed to complete Greg's axle upgrades today. Tomorrow I should be emailing him some pattern pix if all goes to plan.
Treadway is offline
post #2271 of 4130 Old 01-07-2014, 08:43 PM Thread Starter
G Beasley
From all I have read keeping the rear locked will help it live a lot longer , and it also sounds like I need to stay off of Patriot .
In the past I would unlock after major obstacles , but the rear will stay locked offroad as cheap insurance from now on .
Jack
Same here !
Is it tomorrow yet
G Beasley is offline
post #2272 of 4130 Old 01-08-2014, 04:22 PM
gspup
That's my plan.
gspup is offline
post #2273 of 4130 Old 01-08-2014, 05:54 PM Thread Starter
G Beasley
Giggity
post #2274 of 4130 Old 01-08-2014, 06:46 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by G Beasley
Giggity
I got a pair of those too.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2275 of 4130 Old 01-08-2014, 06:49 PM Thread Starter
G Beasley
And some 5.13s too didnt you ? I cant wait to drive it again with the new gears .
post #2276 of 4130 Old 01-08-2014, 07:19 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Yes, unfortunately I have no time to install.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2277 of 4130 Old 01-08-2014, 07:57 PM Thread Starter
G Beasley
But you have plenty of work , its quite the quandary isnt it ?
post #2278 of 4130 Old 01-08-2014, 08:32 PM
Treadway
After a 13 hour day today (about 3 on Greg's LJ) I'm just too pooped to upload my pics.
But...the front is done. I got the rest of what I was needing to properly set pinion depth and went to work. Stock pinion depth was 0.056" and the end depth with the JK gear swap was 0.291". I was able to shim 0.050" behind the pinion race and use 0.056" via a large slinger to keep the pinion bearing bathed in oil. The rest was OEM JK44 shims placed between the slinger and bearing. I was able to use some leftover OEM Rubi 44 carrier shims to set backlash. All in all, it looks like a factory install aside from the large stack at the pinion (which you can't see).
I'll knock out the rear tomorrow afternoon. I measured the stock rear pinion depth at 0.055" today, so I'm confident I'll be able to start at close to my final stack height from the front and be much more time efficient.
I'll do more of these in the future I'm sure. Typically I can regear a set of Jeep axles in about 4 hours. This swap has long surpassed that time allowance. But you don't learn new things until you step outside your comfort zone occasionally!
I hope to be driving it Friday to break in the gears if all goes to plan.
Treadway is offline
post #2279 of 4130 Old 01-09-2014, 09:29 PM Thread Starter
G Beasley
All that typing and this is the only picture I get ? I am sure you are taunting me on purpose now
post #2280 of 4130 Old 01-10-2014, 09:31 PM Thread Starter
G Beasley
Just got home from the three hour tour with 5.13s . First impression is that one of the noises that bugged me is gone ! The gears make a huge difference in driveability in town and up the hills . Once the trailer is loaded up I think that this is going to be about perfect for our trips . It may be a little too much gear for some of y'all , but it is turning 2750 rpms @ 65 mph and thats about as fast as we ever go . Jody is going to post up some install pictures this weekend , but until then heres some pictures from U Joint Off Roads shop ...
The owner calls this one V4.
Not sure of the name of this one other than awesome . http://ujointoffroad.com/
So thats it for the night , made it home with a big ol grin thanks to the gears .
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 11:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
