Just another LJ build - Page 150 - JeepForum.com
 3Likes
post #2236 of 4138 Old 01-01-2014, 08:37 PM
OkLaHoMaTJ
I'm waiting on you to get the Jana kits installed. Then I'll order mine and my JK 5.13's.
With the Jana kits…do you need master install kits? Doesn't look like you do since the Jana kit comes with all the necessary bearings and shims.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #2237 of 4138 Old 01-01-2014, 08:59 PM Thread Starter
G Beasley
I cant say a lot until I get everything installed and see how it works out as the JK swap is new to me . Once I get home I will post up pictures and the parts list . One change of plan is that I did not go with the Jana kit to run JK 44s in my TJ 44s.
G Beasley is offline
post #2238 of 4138 Old 01-02-2014, 09:34 AM Thread Starter
G Beasley
Needs to go wheeling ... thanks Jake . And nice touch that it links to Sundowners thread
post #2239 of 4138 Old 01-02-2014, 10:52 AM
OkLaHoMaTJ
Sounds good. I'll be waiting on that parts list.
post #2240 of 4138 Old 01-02-2014, 10:59 AM
AngryTJ
and Im still waiting on your savvy rear bumper
AngryTJ is offline
post #2241 of 4138 Old 01-02-2014, 11:02 AM
OkLaHoMaTJ
Soon. After the Under Armor and Novak are installed, I'll pull the Savvy rear bumper and Exogate and do what this guy has done...
http://www.jeepforum.com/forum/f22/n...l#post19034489
Noob Build here on th forums. He made a Genright tire carrier work with Savvy Rub Rails. The main reason I didn't get the Genright carrier in the first place.
post #2242 of 4138 Old 01-02-2014, 01:29 PM
AngryTJ
Soon. After the Under Armor and Novak are installed, I'll pull the Savvy rear bumper and Exogate.
AngryTJ is offline
post #2243 of 4138 Old 01-02-2014, 05:24 PM Thread Starter
G Beasley
I should be able to post up a parts list Sunday night once we get home .
I have been bugging him about his Exo Gate for six months
post #2244 of 4138 Old 01-03-2014, 10:09 AM
OkLaHoMaTJ
Don't give up on me just yet.
post #2245 of 4138 Old 01-03-2014, 11:22 AM Thread Starter
G Beasley
All in due time ?
post #2246 of 4138 Old 01-03-2014, 06:13 PM
Jankoid
It wasn't me, I swear!
I did tag that on Sundowner's though, perhaps he is the culprit.
Jankoid is offline
post #2247 of 4138 Old 01-03-2014, 09:43 PM
redrelyt12
Loving the build so far. Long overdue to start reading this. I'm on page 107 as of now, but I'm exhausted. After this, I look to start reading AngryTJ's build. I need some local people to follow for once!
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #2248 of 4138 Old 01-05-2014, 02:55 PM Thread Starter
G Beasley
A likely culprit .
Lu's build is pretty awesome and a good read plus he is in the frozen North like you
This weekends Jeeping ?
JK gear install ! I dont set gears , so this is the first time I have left my Jeep with anyone to work on it . It was an odd feeling driving off and leaving it with Jody at Carolina Axle and 4x4 but he is one of the few people I trust to leave it with .
Here you can see the size difference between the JK 5.13s and my LJ's 4.10s . This is a mostly bolt in application but does require some extra shims , different ring gear bolts and a very small amount of grinding on the housing to help clear the ring gear .
And heres my LJ stripped and ready for the JK gears . This is how it sits until Jody gets a new pinion bearing shipped in on Tuesday . This is the first JK swap being done locally and we are the guinea pig for new JK swap kit that is going to be available soon . So this is where the LJ sits until later this week .
In addition to the JK gears Jody is installing new inner seals , lube lockers and ... chromoly rear shafts .
post #2249 of 4138 Old 01-05-2014, 03:08 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Gonna be a sweet set up!
gst95dsm is offline
post #2250 of 4138 Old 01-05-2014, 03:25 PM
StrokedWJ
StrokedWJ's Avatar
Nice job finding Jody for the gears. Guy really knows his stuff. I've had gears done by a several local people in WNC and can tell you Jody is head and shoulders above the rest! We had a small issue when regearing my CHP9 due to a 3rd party company (not Currie) sending some wrong parts for the install kit. Jody tracked everything down that was missing and setup the gears perfect. He's the only person that'll touch gears in my jeep!
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
