Just another LJ build - Page 133 - JeepForum.com
 1Likes
post #1981 of 4130 Old 10-28-2013, 09:40 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I see no tub on that frame yet.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1982 of 4130 Old 10-28-2013, 09:49 PM Thread Starter
G Beasley
Its going on this week ,as soon as the rear shackle mounts are moved . It is much easier to adjust the height with the tub off the frame . I haven't taken the weight of the tub into consideration until just now , so maybe the 1/2" of extra height will be compressed by the tub's weight ?
G Beasley is offline
post #1983 of 4130 Old 10-28-2013, 09:52 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Yes, very much so.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1984 of 4130 Old 10-28-2013, 10:01 PM Thread Starter
G Beasley
Yes, very much so.
Maybe the tub will get mounted tomorrow ...
post #1985 of 4130 Old 10-28-2013, 10:05 PM
kyle_craig
Your Jeep is so retro. I really dig the look.
kyle_craig is offline
post #1986 of 4130 Old 10-28-2013, 10:07 PM
OkLaHoMaTJ
I'm sure you've answered all of this before but here goes...
It appears you have the MAC intake? Do you recommend it?
Also, how do you like the bead lock wheels? I'm considering going to some when the 37's get here.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #1987 of 4130 Old 10-28-2013, 10:37 PM Thread Starter
G Beasley
Lot of change over three years .
Thanks , I love the old Jeeps just not all the maintenance that comes with them .
I bought it to try and help out some of my son's breathing problems and I am happy to report that it does indeed work well as a cabin air filter . I was a bit skeptical buying it , but it works well even if the directions are a bit fuzzy . As an added bonus , my mileage has gone up since I installed it . With all that said , I think a windstar intake would work well if you dont need the cabin air filtered .
No issues at all with the Champion beadlocks . I check them twice a year and theres usually a couple that are loose , but nothing to bad even with all the miles I put on them .
post #1988 of 4130 Old 10-29-2013, 12:17 PM Thread Starter
G Beasley
Its funny how a simple old dirt road can bring a smile to my face
post #1989 of 4130 Old 10-29-2013, 12:21 PM
janesy86
Rig is looking really nice with the 35's, definitely better proportioned.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is online now
post #1990 of 4130 Old 10-29-2013, 04:27 PM Thread Starter
G Beasley
Thanks , I was concerned going to 35s because of potential driveability issues but they have proven to be unfounded .
Had to run to the steel shop to grab some tubing for the trailer and an upgraded tire carrier for the 35's . Thought the jeep looked neat in front of the old brick building .
A little chrome shine for Nate
And some more leaves in the background .
Off to the shop to finish up the trailer . All I really need is someone to help lower the tub to the frame , but everyones tied up . I am going to see if I can make a sling and use the engine crane to move it .
post #1991 of 4130 Old 10-29-2013, 04:32 PM
84jeepcj7rock
Spring under with one 35 and one 235/75
Spring under with both 35s installed . At this point I was 3" low from sitting even with the LJ .
Torn down and ready for the axle flip . I had the axle built with no crown for this very reason .
Spring over with the 35s left me a 1/2 " to high with the shackles in the shortest position .
The plan is to make new shackle mounts and weld them to the top of the frame . This will allow for longer shackles and a better angle . The other bonus is that it will allow for more height adjustment and this will allow the trailer to be dead level with the LJ . There ya have it the little trailer has grown up to be the Angry trailer on 35s .
Weight of the tub and some gear should level it out?
84jeepcj7rock is offline
post #1992 of 4130 Old 10-29-2013, 04:32 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Jeep looks good but it needs a trailer behind it.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1993 of 4130 Old 10-29-2013, 04:43 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
^^^^ This
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1994 of 4130 Old 10-29-2013, 08:49 PM Thread Starter
G Beasley
Hopefully so , just in case I moved the shackle mounts which will allow for longer more adjustable shackles .
I am trying , it should be mounted tomorrow afternoon . I was delayed because I dont have any material here to make new shackles out of.
^^^^ This
The magic 8 ball says tomorrow looks promising .
As I said above I moved the shackle mount to the top of the frame . I went from having 3/4" of clearance between the spring eye and the shackle mount to over 2" . This will allow for final tuning depending on weight by just adding or subtracting some length from the shackles . Mike aka gspup said the hardest part of building a trailer was getting it lined up with the Jeep and he wasnt kidding .
New shackle mount material .
Cut to length and cleaned up .
Squared up and tacked in place .
Welded up and ready for the bushings to go in once it cools down . Tomorrow morning I am off to get shackle material and then the tub will get mounted for hopefully the last time .
post #1995 of 4130 Old 10-30-2013, 12:07 AM
gspup
Keep up the good work. It is such a pain to get the height right !!!
gspup is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 11:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
