Just another LJ build - Page 130 - JeepForum.com
 3Likes
post #1936 of 4134 Old 10-06-2013, 09:07 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Ok after these photos and reading what you guys are saying and really looking at it.... I'm out! No way that would be worth the effort unless you were also looking at stretching the front in some way. More power to ya though Beasley!
gst95dsm is offline
post #1937 of 4134 Old 10-06-2013, 10:26 PM
kyle_craig
Have you seen anyone cut the cross tube and plate it ? I basically want to make a D shape out of it.
This is something that has been in my mind for a while...with 1.5" cut out of the frame, the axle pushed forward a hair, and a slightly larger tire, it might just be worthwhile. Just a lot of work for a little gain. It would be a neat mod though. My main concern is packaging a winch.
kyle_craig is offline
post #1938 of 4134 Old 10-07-2013, 10:08 PM Thread Starter
G Beasley
Originally Posted by Hendrix View Post
It's actually 1.75 tubing but it's also a thinner wall. They sell the bushings and the precut tube.
I have plenty of 1.75 DOM at the house , and I think I can turn down the frame bushings .
Originally Posted by aw12345 View Post
Anyway if you look at this pic and where the front of the steering box mount and or steering box ends will be your most forward point of what you can lob of the frame
[/URL]
Looks like somewhere between 1.5" and 2" can be gained .
Man I really thought the front frame stuck out further beyond that cross tube. Their really isn't much to be gained without getting rid of it. I think running a bumper no wider than the frame rails is also a viable way to increase approach.... were not always hitting obstacles square.
I am not looking for a ton of room , but every little bit helps . It looks like this can be as easy or difficult as you want it to be depending on how much room you try to gain .
I guessed somewhere around 2", with the steering box mount being the rearmost extent of easy cutting, and that's assuming I found a way to move the Antirock mounts rearwards; the tube is a good solution. What's the easiest way to handle the grill's body mount tab if one is keeping it in place?
I think I will make two tabs on the side to locate the grille as I think the frame chopping will require the winch to be sunk in and the center mount would be in the way .
Agreed, you can only go back to the slope of the steering skid before you run into a big problem, but it's about 1.5 " from the front edge of the bumper.
1.5" off the front and another 1/2" of wheelbase from turning out the arms would be a nice gain .
After chopping the rear of your frame this is easy Nate !
Other than sinking the winch into the grille , I don't think this will be a difficult mod . After the outboard takes place , I think I will give it a try .
G Beasley is offline
post #1939 of 4134 Old 10-07-2013, 10:16 PM
gst95dsm
gst95dsm's Avatar
You lead the way on this one buddy.
gst95dsm is offline
post #1940 of 4134 Old 10-08-2013, 10:31 AM
bobthetj03
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #1941 of 4134 Old 10-08-2013, 01:14 PM
gspup
My thoughts...
I like the bumper protruding just a bit, as little as possible though. I built a bumper from my winch plate the is flush with the frame. My bumper usually takes the heaviest hits, just before the steering box skid. It's alot of work to basically put the steering box closer to the rocks all while keeping it in harms way. It would be a different story if you were gonna relocate it altogether. I have one trail with a skid on my box and most the paint is already gone.
But I'd like to see the result for sure...bet it will look great and honestly you probably wont have any breakage with a beefy skid on there.
gspup is offline
post #1942 of 4134 Old 10-08-2013, 04:01 PM Thread Starter
G Beasley
What ? Nate get to work mister , I like instructions
Originally Posted by bobthetj03 View Post
Yes I can be a little nuts sometimes ...
Originally Posted by gspup View Post
My thoughts...
The steering gear box will get a skid , that will most likely have a piece of my newly acquired sheet of UMHW on it . Though I havent really considered the steering box's newly found exposure as much as I should have ... valid point for sure .
post #1943 of 4134 Old 10-08-2013, 08:41 PM
aw12345
Tis is about as beefy as you can make a steering box skit, it has been thoroughly bashed and beaten has survived 5 feet drops straight on a rock.
aw12345 is offline
post #1944 of 4134 Old 10-14-2013, 05:49 PM Thread Starter
G Beasley
Can I get a discount to UPS my rig out to you for some fabbing / wheeling ?
Lu's latest video from our summer trip .
One last thing ... I am picking up some soft doors on the way home . I wont be selling this set as they are new !
post #1945 of 4134 Old 10-14-2013, 08:47 PM
locrwln
Go to Grimjeeper's page and plug in your numbers (he has all of the driveline and tire choices available) and you will amazed at what you can run for gearing and it be a minor change in your highway RPM's. I would recommend 5.13's for 35's towing your trailer.
http://www.grimmjeeper.com/gears.html
There is a 109 RPM difference at 65 mph between 4.88's and 5.13's (2132 vs. 2241) with 35's.
Jack
2006 LJ Rubicon
locrwln is offline
post #1946 of 4134 Old 10-14-2013, 09:52 PM
aw12345
Greg your pretty Jeep would change shape quickly when it hangs around these parts for awhile
aw12345 is offline
post #1947 of 4134 Old 10-15-2013, 06:49 PM Thread Starter
G Beasley
Jack
I had used his site before , but never realized that you could do two at once...Doh ! Thanks for point that out . Heck for the 109 rpms I could just run a little slower . When your driving 2500 miles in a Jeep your certainly not in a hurry and I think the deeper gearing is going to make the Rockies a lot more pleasant
Its about to get prettier , maybe I will keep it away from you for a while
post #1948 of 4134 Old 10-17-2013, 07:19 PM Thread Starter
G Beasley
Soft doors acquired ...
post #1949 of 4134 Old 10-17-2013, 09:07 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
They are the best.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1950 of 4134 Old 10-17-2013, 10:33 PM
gst95dsm
gst95dsm's Avatar
Ok I'll be the first to ask I guess....... WHY are you repainting your entire Jeep???? I've seen it, looked clean to me! Building a show rig??? Or is Hendrix's work that magical that you just can't resist? It does look damn good in the photos.
gst95dsm is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
