Just another LJ build - Page 112 - JeepForum.com
 3Likes
post #1666 of 4141 Old 08-29-2013, 11:10 PM
bobthetj03
I'm just enjoying the fact that you take your rig to the far reaches of what most of us don't. Do not lose site of that!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #1667 of 4141 Old 08-29-2013, 11:12 PM
Moabrubi
Yea.. I understand now. Breaking thousands of miles from home would suck.
For trips away from home I just need to figure out how to get it back to the trailer. So it's no biggie for me.
Moabrubi is offline
post #1668 of 4141 Old 08-30-2013, 05:32 AM
Jankoid
You know my opinion on this subject as we have beat it to death already.
If you had seen how hard I've been beating on my rubi 44s since putting the Detroit in the rear you wouldn't even consider upgrading the gear set. I see absolutely no reason to put a stronger rear axle in the rear if you are not going bigger.
Also, I wouldn't want a rear axle that is significantly stronger than the front. That's just a false sense of security you are creating for yourself.
If you just want peace of mind do the Jana kit. With a JK gear set, ARB locker, and 35 spline shafts, you will never break that rear axle on 35s, trust me.
Oh, and fab 9 > RJ60
Jankoid is offline
post #1669 of 4141 Old 08-30-2013, 06:10 AM
janesy86
Definitely a tough one if your going to throw all that coin into the D44 tho. Can make more $$ off the rubi axle in good shape that if its busted to offset the 60.
But I'd agree with Jankoid, even with just the stock Rubi D44 that I'm running. In the yea and a half that I've owned the rig, I've been out easily 25 times and each time I tend to puch my limits to what I try even more. I also follow a lot of juggy's around so that usually makes me try some stuff I wouldn't think of trying normally. I also drive to and from the trail, not 1000+ miles but still between 1-4 hrs or so. And the rear is holding up more than fine even without me totally babying it.
So while I think the rubi axle will hold up to you on 35's, I understand your logic as well.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #1670 of 4141 Old 08-30-2013, 06:54 AM
TrailJ
But if it is over built and wouldn't have failed anyway, it's wasted money. If probability of failure is so low no one thinks it will happen, is the extra insurance needed? Plus don't 35s not provide enough clearance for a 60?
TrailJ is offline
post #1671 of 4141 Old 08-30-2013, 08:31 AM
jermeyg
So many good points on here! Maybe i can ard another? While I think a RJ60 is awesome I think it's a good idea to consider the disadvantages of having one especially with your anticipated lift height. How much uptravel are you willing to work in there with a RJ60? Will you stay 5-linked or move to a 4-link? Will you be willing to switch beadlocks in the rear? Are you comfortable with wider rear end?
jermeyg is offline
post #1672 of 4141 Old 08-30-2013, 08:26 PM Thread Starter
G Beasley
I may end up back on a trailer once the kids get older and need more room , but for now its cross country in the LJ .
I know the Jana setup is stout , and its one of the options I still consider. And compared to most of y'all I wheel very conservatively . The one difference is driving it out West and back . Finances may dictate that I build the 44 , but I recently sold the blue truck ....
I have had the same conversations with myself ( I get really bored on the road) and others over the last six months . A 60 is way more than I need , unless I break and get stuck somewhere waiting on parts and trying to find a good shop .
The 60 will most likely drag a little more , I am going to try and find the clearance differences of the 44 and a Rock Jock . As to the probability of the 44 dieing ? Only if its in the worst location on a Sunday night at the top of a Mountain Pass during one of the hippy gatherings .
5 linked for now and the foreseeable future . I hadnt considered losing uptravel and thats a valid point . A little more bumpstop would be ok , but I dont want to end up in a downtravel only situation . Some of the 60s offer a dual pattern , but if need be I would swap out the front hubs and go to a larger pattern . I think the Champions would sell pretty easily , so that would partially offset the cost of the new wheels .
This is why I posted the question , before I spent the money . Still a lot of reading to do ...
G Beasley is offline
post #1673 of 4141 Old 08-30-2013, 09:02 PM
Jankoid
I think you are way overthinking it. You WILL NOT break a d44 with JK gears, ARB locker, and 35 spline chromos with mild wheeling on 35s. Simple as that. Even with hard wheeling on 37s that would be a very hard combo to break. With the Jana kit and upgraded shafts you are stronger than a Ford 8.8, and I know several people that beat the piss out of their 8.8s on 35s-37s, and they are still running stock 31 spline shafts. You do not need a d60. It's like those commercials where they show a guy ****ing up his tile floor with a sharpie so they can sell you some fancy highlighter to brighten your grout lines. Don't invent a problem just so you can waste money on the solution. I don't support the d60 idea at all, no matter how many times you try to convince yourself you need it.
I'm pretty sure a RJ60 actually has better clearance than a 44, similar to a d35.
Jankoid is offline
post #1674 of 4141 Old 08-30-2013, 09:47 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
What if you add it all up and the money is the same or within a couple hundred? Why NOT do it?
gst95dsm is offline
post #1675 of 4141 Old 08-30-2013, 10:07 PM
TrailJ
As long as clearance and travel are equal (?) why not?
TrailJ is offline
post #1676 of 4141 Old 08-30-2013, 10:37 PM
gspup
Within a couple hundred...? We all know what that means.
I say no 60 either. I have close personal friends that run extreme trails on rubi 44's w/ cromos and 37's with no breakage in back. not needed. **** Nate runs a D35 on 35's. End of discussion.
gspup is offline
post #1677 of 4141 Old 08-30-2013, 10:50 PM
gst95dsm
gst95dsm's Avatar
Haha, I don't know whether or not to feel proud... or embarrassed that my D35 lives for some reason. I'm not the ONLY m-fer running a D35 with 35's!
Beasley IS the only m-fer I know running two car seats, the wifey and the ambition to wheel 1000's of miles from home. I support the D44 build up also... my only thing is if the money is the same, why not?
gst95dsm is offline
post #1678 of 4141 Old 08-30-2013, 11:10 PM
TrailJ
Are they? Will a 60 be the same or worse than a d44 in any other area? PRice bEing equal what are clearance, travel etc?
TrailJ is offline
post #1679 of 4141 Old 08-30-2013, 11:19 PM
bobthetj03
We need some 60 owners to chime in on this!
Bob's boring build:
post #1680 of 4141 Old 08-31-2013, 05:23 AM
Jankoid
Did anyone catch this comment I made? It doesn't matter if he runs a Jana44, RJ60 or a rockwell in the rear, if he doesn't swap out that front axle he has done nothing to alleviate his weak point. He'll be breaking u joints and stub shafts long before he blows up a jana44. I have yet to see an exact price for a bolt in RJ60, but i'm sure it does cost more and it is an unnecessary upgrade.
Jankoid is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 11:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
