Just another LJ build - Page 110 - JeepForum.com
 1Likes
post #1636 of 4130 Old 08-24-2013, 07:49 PM Thread Starter
G Beasley
Heres the trim piece welded up and ready to cover the rough edge of the old wheel well .
Trim piece in place .
Hard to see , but both trim pieces are in place .
This is where it gets tricky , this is a picture of the hinge mount . In this position I think its going to catch water and hold it .
I think that I am going to reverse it and have it face forward . This way with a little seam sealer it should seal up well and allow for a solid mounting point for the tonneau hinge .
Basically I will mount the angle opposite of this . More work tomorrow afternoon , its going to be close getting it ready for the trip .
G Beasley is offline
post #1637 of 4130 Old 08-24-2013, 10:31 PM
jforse
That trailer is looking great!
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #1638 of 4130 Old 08-25-2013, 06:52 AM Thread Starter
G Beasley
Thanks , its starting to wind down now . Its rough getting time in the garage when I am home for just the weekend but its nice to see it so close to being finished.
post #1639 of 4130 Old 08-25-2013, 08:15 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
If you need me to finish up something just point me in the right direction when you get it here.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1640 of 4130 Old 08-25-2013, 04:46 PM Thread Starter
G Beasley
Everything is figured out except the front hinge mount . I am hooking it up to my wifes Grand Cherokee for the trip out tomorrow and I am going to see what you think will work for the front mount .
post #1641 of 4130 Old 08-25-2013, 07:21 PM Thread Starter
G Beasley
The tailgate latches are complete , all thats left is the aforementioned hinge mount for the tonneau . After some thinking and measuring I came up with what I think is a pretty simple solution for the latches .
A piece of barstock happened to be laying on the counter and it was the perfect size for the latch to close onto .
Heres the barstock in place .
A few bends in the vice made for a good stop / catch for the latch .
And nice out of focus picture of the tailgate latched .
The trailer is hitched up and ready to go West tomorrow morning .
post #1642 of 4130 Old 08-26-2013, 04:13 AM Thread Starter
G Beasley
Trailer is back at the house and I am on my way to Tennessee... Not sure what or exactly how it happened but the trailer has death wobble over sixty miles per hour.
post #1643 of 4130 Old 08-26-2013, 04:16 AM
supertaco
could be a tire. either broken belt or out of balance or to much fix a flat in it.
supertaco is offline
post #1644 of 4130 Old 08-26-2013, 06:57 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
So it isn't going to Hendrix now? Or right now?
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1645 of 4130 Old 08-26-2013, 08:14 AM
yellow_snocone
Its not trailer DW its just skipping for joy since its going to get detailed up
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #1646 of 4130 Old 08-26-2013, 09:02 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
That sucks, probably just a tire.
Sent from my iPod touch from Top of the World!
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1647 of 4130 Old 08-26-2013, 05:58 PM Thread Starter
G Beasley
The tires are old , but were ok behind my LJ up to 50 mph .
Next trip West , thankfully I have to come back out here again in two weeks .
Do you blame it ? The paint job I put on it looks like it has mange .
After a long ride to Franklin TN I have four things I think it may be .
1: Tire or tires ... They are old and have been sitting a long time . The odd thing is that the vibes start at 55 and dont go away until you come to a full stop . If you keep it at 50 mph there are no vibes .
2: Soft springs . I think I may have the leaves set up too soft and a body in motion tends to stay in motion . The problem seems to get worse when I hit a bump at speed , so maybe a pair of shocks would help dampen the movement ?
3: Toe In . Or maybe the lack there of ? My axle is set up with toe in , and theres a weld spot that shows which side is the front . When I went from a spring over to a spring under theres a chance I got the toe in backwards which would lead to odd tracking .
4: Porpoising . Ie; low tongue weight . The trailer is setup to have weight on the tongue in the form of a cooler or a tongue box and that currently isnt there . Theres maybe 20 lbs of tongue weight , and with a weight of 700lbs or so that could lead to the trailer jumping around ?
Thats all I could come up with as I thought things through on the drive out . I am open to all ideas , and will chase them down when I get back home in ten days or so .
post #1648 of 4130 Old 08-28-2013, 08:00 AM
bty34
I vote tongue weight. I added a bike carrier to the back of my m416 and it was fine when accelerating, but when there was no load on the hitch it starting swaying violently enough to move the jeep. I had probably 25 lbs on the tongue, but it wasn't enough. Pulled the rack back off and it was back to normal. Probably had a 60-70 lbs on the tongue after.
bty34 is offline
post #1649 of 4130 Old 08-28-2013, 08:30 PM Thread Starter
G Beasley
The majority of people I have spoken to all have said the same thing . When I get home I will load some weight on the tongue and see what kind of difference it makes . I plan on sitting in the back of the Grand Cherokee while my wife drives around with the trailer behind us ... that should be a lot of fun
post #1650 of 4130 Old 08-29-2013, 06:10 AM
Sundowner
I demand pictures of this.
Sundowner is offline
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
