Just another LJ build - Page 101 - JeepForum.com
 3Likes
post #1501 of 4138 Old 07-16-2013, 01:01 PM
yellow_snocone
Some intense Machinery your getting your hands on there. Also the trailer is looking sweet so far.
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #1502 of 4138 Old 07-16-2013, 09:14 PM Thread Starter
G Beasley
Originally Posted by dayriesw View Post
Cool. I am sure you will put it to use.
Threaded inserts are what I want to learn to make first .
Originally Posted by gspup View Post
Are you sure you know how to use that thing ?
just enough to stand to the side so it throws the tooling at the wall and not me
I am stoked to get it , and it comes with a lot of tooling .
G Beasley is offline
post #1503 of 4138 Old 07-16-2013, 09:48 PM Thread Starter
G Beasley
Todays progress .
This is what 5 minutes of Kleen Strip aircraft stripper did . The yellow is all gone , tomorrow it will get cleaned then painted .
The front panel is tacked in place . Initially it was going to be removeable , but once it is LineX'd its not coming out so I went ahead and welded it in. Between seam sealing the front edge and LineX'ing the backside the front panel should be pretty weather resistant .
The tub is clean and ready for seam sealer . It took a lot of scrubbing to get all of the grinding dust out .
Lastly I started cutting out the trim for the old wheelwells . The plan is to cut and roll the angle around the radius to clean up the edges .
In addition to working on the trailer today I had both J trucks apart and I worked on them as the trailer was drying . It was hot as heck , but Kimbo kept the ice water rolling out to me .
J truck goodness ...
post #1504 of 4138 Old 07-16-2013, 10:00 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Nice work Beasley.... man the little details sure do add up on that trailer. You're doing it right though, I'm sure the end result is going to be impressive.
gst95dsm is offline
post #1505 of 4138 Old 07-16-2013, 10:17 PM Thread Starter
G Beasley
Your not kidding , when I welded the two halves together I thought I was almost done !
post #1506 of 4138 Old 07-17-2013, 06:54 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Yep. Learning a lot. Keep up the good work.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1507 of 4138 Old 07-17-2013, 07:18 PM Thread Starter
G Beasley
The lathe is going to take some getting used to , but I am ok with the mill . With some practice there should be some cool ideas coming to life this fall .
I was busy with work today so I didnt make much progress , but I plan on being out in the garage early tomorrow so that the trailer will be ready for inspection on Friday morning . The good news is I that I have everything I need ready to go in the garage for tomorrow .
post #1508 of 4138 Old 07-17-2013, 07:24 PM
JJeeper09
What page is you pics of the inner sleeves
JJeeper09 is offline
post #1509 of 4138 Old 07-17-2013, 07:58 PM Thread Starter
G Beasley
Here ya go , reply number 1100 is where the pictures start .
http://www.jeepforum.com/forum/f22/j...3/index28.html
post #1510 of 4138 Old 07-18-2013, 06:14 AM
Sundowner
Uh oh...we can has goodies, now?
Sundowner is offline
post #1511 of 4138 Old 07-18-2013, 06:55 AM Thread Starter
G Beasley
At a bare minimum we should be able to make threaded inserts , spacers and blocks . I am excited to start making stuff with the combo , it really opens up what I am able to make in the shop .
post #1512 of 4138 Old 07-18-2013, 07:24 AM
Sundowner
Three words: Machined. Aluminum. Legos.
post #1513 of 4138 Old 07-18-2013, 03:18 PM Thread Starter
G Beasley
Billy would love those , but I think aluminum legos would be even worse to step on than the plastic ones ...
Todays jeeping so far ...
The Gladiator grille is installed and the hood latch is figured out .
The trailer is seam sealed inside , and on the front filler panel .
The final trim is cut , unfortunately I ran out of angle .
I feel like the trailer is complete enough to go get it inspected tomorrow morning ... wish me luck
post #1514 of 4138 Old 07-18-2013, 03:40 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Good luck. Is the angle going around the perimeter for a rubicon-type slider?
16 Taco
dayriesw is offline
post #1515 of 4138 Old 07-18-2013, 03:59 PM Thread Starter
G Beasley
No the angle is being used to clean up the edge of the wheelwells. Basically it is just a piece of trim . I do have my old Rubi sliders , but I hate to cut them up as I think they will be rare one day .
Before I add armor I want to take it out and use it to see what all is needed . The one piece of armor I do have for it is a set of rear corners . I would like to install them before I take it out on the trail because they are going to be pretty exposed and I am terrible at backing trailers
crappy paint , jana k4 , jeep-owner.com , needs to go wheeling , old man emu , rubicon unlimited , savvy offroad
my build up 98 TJ frumpy Jeep Builds 34 10-05-2011 10:17 PM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
