Jeep Enthusiast Forums banner
559K views 4K replies 176 participants last post by  G Beasley
#1 ·
Retro Rubicon LJ build
I havent had a 4wd that could be driven on the highway in a long time and I was getting tired of trailering everywhere so I started looking for a LJ Rubicon last Thanksgiving . Within a week I found this with 60k miles for a great deal and it was semi local .
This is the first picture I took of it once I unloaded it from the trailer . The next day I took it out back to have a little fun .
I immediatley liked the softer ride than I had in my samurai , but it was lacking some in capability . I knew with some time and research it would be much more capable , but for the time being I contented myself with cleaning it , getting a new top and some Line X .
I removed everything from the LJ and added a custom milk crate seat . I trailered it over to Line X and then when I got it home I put it all back together just in time to drive up to Lake Erie for work . (Seeing a trailer habit yet )
This was the 1st time in 7 years I hadnt driven a dually CTD Dodge on a trip and I really enjoyed the TJ . So I went full bore into researching here on JF and ROF and I ordered up an Old Man Emu super ultimate setup from DPG offroad .
I came home from six weeks on the road and this is what I had waiting for the Rubicon .
The thread has gotten a little long heres a spoiler pic of what the LJ looks like as of August 2013 .
See less See more
7
#2 ·
I went ahead and put the 33x12.5 Destination MTs on with no lift just to see how bad it was going to be ...
Before during and after .
It wasnt driveable but I sure liked how it looked a lot better .
The lift I went with is med OME coils and JKS adjustable short arms . I want to keep my rig low and stable as I want my wife and kids to enjoy being on the trail . I have also gotten older and dont feel the need to make the hard line every time anymore , heck I am just happy to get in the woods away from society on a rocky road .
1st up was the coils so that I could get them in pretty quick and still drive the jeep if I wanted to .
I removed the swaybar links and then moved on to the shock .
Drivers side shock came out nicely , but the passenger side had to have the shaft cut with a cut off wheel .
Then the spring came out .
Heres the OME next to the stock Rubicon spring .
Next up was to install the bump stop , I think the spring pad is made from depleted uranium as it is thick and took a while to drill . A little cutting oil helped a lot and I used the self drilling screw to cut in the threads .
Once it was all test fit I removed the bumpstop and put it inside the coil spring . Then I pushed it into place with the help of a spring compressor . Once it was in place I reached through the coil with a 1/4" ratchet and ran the screw in .
And heres the first corner completed .
#4 ·
I decided to yank the trac bar and drill out the mount .
Impact chisel with a pickle fork adapter is your friend .
Wrestled the drill into place and drilled the hole out .
The other side came out easy and it went back in fine .
#5 ·
Rear spring and shock swapped out . I got lucky and all of the bolts came out pretty easy .
Heres the links cut down and with the threads cleaned up .
I had to cut the new links down so it gave me an excuse to use the bandsaw and grinder .
#7 ·
Went ahead and put the JKS arms in on the rear .
It went well once I ignored the directions . The directions said to remove one arm at a time and , but I found it much easier to swap them in pairs .
The rear trac bar went in at the same time and it was perfect the first try . I was very happy to say the least .
I swapped the front arms out in pairs and it went pretty nice too .
This is what it looked like with the suspension and body lift finished . And this is where it stands for now . I have a Savvy gas tank skid ready to go in and I am going to bend up a cage next . I will post more pics when I make some more progress .
The only thing left to buy is the Savvy under armor . I am making my bumpers and sliders and then its finished ... hahahahahaha .
#9 ·
I have been driving the LJ more and more and last night I took my family out in it for the 1st time to go see the fireworks . On the way home a deer leaped in front of us and went into the grill .
I think I may try to put the inner section of a CJ grill out and weld it into the now bent TJ grill . The fenders are going to get cut flat and I have a new bumper ready to weld up . I have been on hold build wise as my wife had me do this .
Now that the deer has attacked , I am free to work on the rubicon again .
#10 ·
I got the antirock on last month , no complaints with it at all . Pretty easy to install and I dont notice it on the road . Best of all no more disco'ing when I get to the trail .
Started out by measuring ten times and drilling the holes for the JK signals .
I used a 3 and a 1/4" holesaw and it was the perfect size for the housings I got from Rock Auto .
Fished the wires back through the newly drilled and painted signal hole . I was able to use an existing hole for the wires .
I used a sawzall blade with light pressure to cut notches in the light flanges so I could index the lights to tighten them and not use silicone to hold the housings in .
Here you can see the notch . I offset the slots in the grill so these go in then twist an 1/8th of a turn . They are very tight but fit great .
The first light is in and wired .
Deer damage getting ready to go away .
Detail of the wiring , there was plenty of length for the fog light connection . I used an existing hole on the bottom of the grill to drop the fog light wiring through . If I didnt have body lift this would have been a tight fit .
I painted all the exposed surfaces with Mopar touch up paint . It blends in pretty nicely .
Heres the drivers side wiring all snaked through . I did have to pull the coolant reservoir to gain access to the hole to snake the wiring through .
Passenger side completed .
Finito !
From the side .
Time to start the tube work on the front . I think it will look a lot like the Rokmen when its done . I could make something different ,but the Merc is perfection to me .
I also picked up a dana 44 for my wifes XJ . I think I am going to put an OX locker in it before it goes back in . Gotta keep my wife happy and I think I am pretty lucky that a Dana 44 made her happy .
#11 ·
I bent up the front hoop and got it all fitted to the bumper plate . The duct tape lets me stand back and look at the position of the tubing as I go along . Hopefully tomorrow I will get the two other tubes notched and tacked in place . Then I can pull the entire assembly off and finish welding it .
#13 ·
LJs seem to have a love hate fan base . When I got it I needed the space for the kids and my wifes stuff more than anything , but once I rode some distance in it I was in love . I do have a CJ 5 so I like the short wheelbase stuff too , but its for playing around out back or short trips ... it sucks to get old .
Thanks for the kind words , I have had a lot of fun building this one .
#17 ·
Thanks , hopefully I will get a little time to notch the tube up tonight .
Love the stance & color of your LJ. I'm puzzled on how people don't like LJ's... they look a lot better than TJ's in my book.
I like both the same . I had a CJ 6 and I loved it , and most people did not . Guess I like the odd ducks .
Thank you for documenting your build, it will help immensely when my parts arrive from DPG.
Dirk is a great guy to deal with . If you have any questions while your installing pm me and I can pull measurements or tell you what I did .
#20 ·
I bought the winch mount plate from Zach at A to Z . Its really well made and saved me a bunch of fabrication time .
what color is the jeep it looks very close to the charcoal that is on my fiances 2011 liberty
It is a dark metallic green . Not sure what the exact name of it is ? I would call it forrest gump green :p
#21 ·
Even with a tubing notcher these joints were a pain .
Fitted and tacked in place .
Mostly welded .
Should have started on the front so my ugly stop start would be on the back .
Cutting the D Ring hangers .
All welded up and ready for primer .
And the finished product . I still have to paint it as right now its just primered , but beyond that it is done . Now on to rollcage , but thats going to have to wait until I make it home again .
#24 ·
Thanks , it was a lot of work but it was worth it to me . The next one I make will be much cleaner . The notching on the tie ins between the two hoops was tough to get just right . The second time will be the charm !
You got that grill mounted yet? I'd like like to see a finished pic of that kickazz bumper too :thumbsup:
Funny you should ask , I finished it this weekend . I just didnt have time to post the pictures until I got back on the road .
#25 ·
I didnt take any pictures of me pulling the deer damage . I used a ratchet strap to pull against the bumper and I got it mostly pulled out . Thanks to Jakes unused chrome grill you cant tell a deer attacked the LJ anymore .
Lining up and cutting the turn signal homes was a challenge . I ended up scribing them with a 90 degree scratch awl . I then drilled a hold and used a set of good sheet metal snips to cut out the holes .
I picked up a stick of angle iron this weekend to start the new crossmember project . I am going to make a triangle shaped crossmember with a frenched in receiver and d ring hangers . Once thats done I am going to add some tubing to go around the corner of the tub . This should help a little with the departure angle and it gives me an excuse to use the plasma cutter .
#26 ·
The grill looks great man. :thumbsup: Glad to see its actually serving a purpose other than collecting dust in the corner of my room. :laugh:
Let me know when you are gonna hit URE and I'll try to make it up there if I don't have any conflicts with school. :cheers2:
#29 ·
#31 ·
The factory trac bar mount is tapered and has to be drilled out for the square bolt that goes through the JKS trac bar . Then the bump stop extensions have to be drilled too .
Even if you go with the standard OME lift that uses the trac bar brackets I think you still have to drill a few holes .
The two most difficult parts of putting on my lift were getting the time away from the kids and taking off the front shocks .
#32 ·
Not much tech , but I did get my new stickers done . I like the old Renegade script as I daily drove one when I was younger . So with the flat fenders and cj style turn signals I went with this . I also am making some of the old school Willys 4wd stickers too .
If I get lucky I might get my hood repainted this weekend ... but I am betting on having to knock out some honey dos .
Top
