just another 1 ton tj - Page 2 - JeepForum.com
post #16 of 169 Old 10-16-2012, 08:09 PM Thread Starter
babyhulk
Steering couldnt have turned out better, everything is parallel and everything appears it's going to clear. Got the antirock rock installed another piece to fit around the steering and trac bar. Brake lines come in from crown (didnt take a pic), this is the one thing i couldnt find checking previous swaps. In my opion crown is the way to go all u need to know is the od of the banjo bolt and the length and they can build u anything,mine ended up being $250 shipped.
2012-04-13_18-22-09_220.jpg   2012-08-23_21-13-52_702.jpg   2012-04-13_18-22-30_201.jpg
babyhulk is offline
post #17 of 169 Old 10-16-2012, 08:22 PM Thread Starter
babyhulk
I took it down the road and couldn't believe how much better it drove in every way it was better. Josh at http://www.universalautomotiveconcordnc.com/ finished my drive shafts and he modified the yoke on the 14 bolt to be able to accept a u bolt style instead of a strap. If you have ever read the 14 bolt bible the strap is its biggest weakness along with it being so low (again need to take pics)....
babyhulk is offline
post #18 of 169 Old 10-16-2012, 08:27 PM
evolution
i been watching it on nc4x4.. looks good man..i was goin to post a build on there but i cant keep up with this one on here that much..lol
97 TJ, custom long arm, custom tri link rear, 44 front-9in rear, Detroit and Yukon lockers, 4:88s, 37" bfg's ,tube fenders and crusher corners, process never ends...
evolution is offline
post #19 of 169 Old 10-16-2012, 08:27 PM Thread Starter
babyhulk
Got some small stuff done, figured id post it up. Added a savy tail gate skin, ordered psc tramp stamp and big hit bumper from swag to finish up the rear. It came time to change trans fluid so i figured it was a good time for some upgrades. The 42rle is definitely the weak point in my tj, it runs hot really hot so I started with a deral trans cooler to help with the temptures. While I had the pan pulled to channge the filter I went ahead and installed a drain plug, also added a autometer transmission gauge to keep an eye on the temptures. To help with the stress that's on the single sheer pitman I had a duel sheer pitman arm made turned out really good.
2012-08-13_19-23-00_851.jpg   2012-08-29_16-08-31_296.jpg   2012-08-10_16-55-06_848.jpg   2012-04-27_16-39-34_760.jpg
babyhulk is offline
post #20 of 169 Old 10-16-2012, 08:33 PM Thread Starter
babyhulk
I went ahead and double sheared the PS high steer arm just waiting on my gusset too finish it up. pics of it actually in the woods if u can believe that...
babyhulk is offline
post #21 of 169 Old 10-16-2012, 08:52 PM Thread Starter
babyhulk
I installed a durango 160 amp alternator today, direct bolt in other than upgrading the charging wire coming from the alternator. It's truely is a great upgrade, i tried pulling down the battery with the winch and the battery indicator never moved.
The one on the left is stock one on the right is the durango.
babyhulk is offline
post #22 of 169 Old 10-16-2012, 09:03 PM Thread Starter
babyhulk
Thanks. Just gives me something to do to pass the time.
babyhulk is offline
post #23 of 169 Old 10-17-2012, 01:29 PM Thread Starter
babyhulk
Took it down some local trails and found out it rubes about 3/4 full stuff in the rear. No rocks but some deep ruts and some nice hill climbs, gave me a chance to test the brakes offroad and like on road had no problem.
babyhulk is offline
post #24 of 169 Old 10-17-2012, 01:34 PM Thread Starter
babyhulk
I have been wanting to do this since i put the flares on and finally got around to it today. Makes the 37 fit perfect at full stuff. Also getting really close to my next 3 big mods coil overs, posion spyder full cage and psc hydro assist.
before
after
babyhulk is offline
post #25 of 169 Old 01-10-2013, 02:57 PM Thread Starter
babyhulk
Started installing my christmas present today.. The poison spyder hood loovers were pretty easy to install minus cutting a perfectly good tj hood. It definitely help get the heat out of the engine bay. Also got my swag rear bumper on...
2013-01-10_16-43-01_837.jpg   2013-01-10_16-43-29_415.jpg   2013-01-10_15-43-57_843.jpg
babyhulk is offline
post #26 of 169 Old 01-10-2013, 10:37 PM
STRATTON
thats one serious rig man !
totally impressed and jealous.
stratton.
STRATTON is offline
post #27 of 169 Old 01-11-2013, 06:51 AM
Holaday
Awesome find on the axles!
What did you use for the savvy tailgate skin? Looks cool
Holaday is offline
post #28 of 169 Old 01-11-2013, 09:32 AM
Steamfab
Wow! this is a monster. Great job!
_________________________
www.sawblade.com
Steamfab is offline
post #29 of 169 Old 01-11-2013, 10:04 AM
NHL_bullitt
Excellent build sir! If your jeep had a budget boost on 33s I'm sure this would be 89 pages long of people praising it.
98 XJ: has been tweaked a bit
NHL_bullitt is offline
post #30 of 169 Old 01-11-2013, 01:12 PM Thread Starter
babyhulk
stratton.
thanks it's never ending
Yeah I couldn't believe it ether. long story short I found out there is a wilmington
In Boston as well as in North Carolina . It a 3m carbon fiber Vinyl.
What is the deal with that if I had ever part out of the quadretec catalogue on my jeep I'd have a lot more hits..... Thanks
babyhulk is offline
