JMoore's LJ slow build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > JMoore's LJ slow build
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-10-2014, 04:21 PM   #16
justntime911
Originally Posted by responder View Post
What are the plans for reverse lights, if any?
I'm thinking of recessing some reverse lights into the center swing out section of my rear bumper
justntime911 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2014, 09:04 PM   #17
G Beasley
Good looking LJ , but its tough to leave them alone isnt it ?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 02-10-2014, 10:30 PM   #18
justntime911
Thanks man! Yes it's very tough! I've drove it for about a year and a half with out doing anything major. But now it's time to get to work!
[COLOR="Silver"]JMoore's LJ slow build[/COLOR][URL="http://www.jeepforum.com/forum/f22/jmoores-lj-slow-build-2082809/"]http://www.jeepforum.com/forum/f22/jmoores-lj-slow-build-2082809/[/URL]
Unread 02-12-2014, 03:49 PM   #19
justntime911
Well I did it... I ordered the Clayton 4" pro series long arm w/ 3 link bridge, Currie antirock front swaybar, and Bilstein 5100's. It should all be here sometime next week!!
Unread 02-19-2014, 07:35 PM   #20
justntime911
Brown Santa visited me today. Looks like I've got some work to do!!
Unread 02-22-2014, 09:01 PM   #21
justntime911
Well I had a few minutes to spare this morning so I stopped by a local junkyard to see if they might have a HP D30 out of a 96-99 Cherokee. Sure enough they had got a 96 model in that had the HP D30 in it that I was looking for. They had already sold the hubs, knuckles, and axle shafts off of it which was fine with me because I only need the housing. So I got the housing and gears for $100. Can't beat that!!
Unread 03-09-2014, 03:00 PM   #22
justntime911
Started working on the HP 30 yesterday. Plan is to get it all cleaned up and remove any factory brackets that are no longer needed. Then get the Clayton truss w/ 3 link mount and HD LCA mounts welded on. I also ordered new Synergy ball joints on Friday. Once the front end is done I can start my lift.
new Clayton truss
Unread 03-15-2014, 10:25 PM   #23
justntime911
Finally got the Clayton truss w/ 3 link mount and HD lower control arm brackets welded on to the HP dana 30. Big thanks to my Dad for all the welding! Then cleaned on the rest of it a little more and got it under primer. It's ready for gears and an ARB locker!!
Unread 03-18-2014, 03:40 AM   #24
justntime911
I'm finally ready to order my gears and lockers. What gear ratio are you guys running with a 6 speed/ 35" tire combo? And what is the best air source for air lockers? I was thinking the ARB twin compressor? Anyone?
Unread 03-18-2014, 08:55 PM   #25
G Beasley
I just went to JK 5.13's with my 6 speed and while I lost top speed it is much more driveable now . If I wasnt going to be towing the trailer 4.88's would have been fine .
Unread 03-18-2014, 09:08 PM   #26
justntime911
Thanks Beasley. I will probably never be towing anything so I think 4:88's will do just fine.
Unread 03-24-2014, 07:33 PM   #27
justntime911
Well my gears arrived on Saturday and my compressor came today. Looks like I'll be starting on everything Friday!
Unread 07-20-2014, 11:37 PM   #28
justntime911
Wow I haven't updated in a while. Finally got a couple free weekends to work on the jeep and get it finished up! Everything turned out nice.
Here are some pics of the lift install...
Unread 07-22-2014, 06:56 AM   #29
justntime911
Got all my air lines routed and compressor installed. Lockers seem to be working fine! I'll have some pics of the install as soon as I can get them loaded up.
Unread 07-22-2014, 09:41 AM   #30
Tonellin
Great work on the axle! Looks real nice all painted up with the truss. Interested to see how much more you like it offroad with the new suspension
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline   Reply With Quote Quick reply to this message
