JKL's '05 Wrangler Unlimited - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > JKL's '05 Wrangler Unlimited
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 02-07-2011, 10:21 PM   #61
JeepNE
Originally Posted by jkl View Post
Went wheelin on Sat and popped the RF tire and dented up the RR corner
Hows the mag mount cb antenna working for you on the bumper? Good range?
JeepNE is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 12:27 PM   #62
jkl
Not that great, it will only talk a few jeeps away and hear just a little farther
'13 10th Anniversary Unlimited Rubi
'05 LJ on 35s
1 Ton XJ on 40s...went up in flames :(
1 Ton Scrambler Build Thread:"Project Taildragger"
...now parting out
jkl is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 12:30 PM   #63
jkl
Originally Posted by DaFuzz View Post
Sorry for hijacking your thread, but I figured the Jeep must've caught your eye since you posted pics of it and you might want some more reference pics.
Your not hijacking and thanks for the pics. I did some research on it, but could you confirm the specs? HP D44 front, 8.8 rear, 2.5" susp lift, 1" BL, hi lined and 37s.
*edit: I think the front end is out of a full size Ford, do you know if it's been narrowed?
'05 LJ on 35s
...now parting out
Unread 02-08-2011, 03:55 PM   #64
Sgt.Fuzz
Tera low 4 to 1, AA SYE
Front axle: Custom HP Dana 44 thicker tubed, Alloy shafts and Yukon Super joints, Warn locking hubs, 5.13’s, Detroit, BTF cover.
Rear Axle: Ford 8.8, TNT truss/brackets, Super88 kit, 5.13’s, Detroit, BTF cover
Suspension: OME 2” HD coils, RE HD trac-bar, Currie Anti-Rock, short arm Rokmen custom built upper and lower control arms with Johnny Joints on all.
Steering: PSC Saginaw steering box, pump, cooler, and res. Plumbed for assist but ram is not installed. 1.5” DOM steering links with Chevy 1 ton ends.
Tires/Wheels: 37”x12.5”x17” Goodyear “New Tread” MTR Kevlars on 17”x9” Polished Walker Evans Beadlocks. 5 on 5.5.
MISC:
Savvy front aluminum bumper
Superwinch Epi9
Viking 3/8 syth line
In-cab winch control
Hand throttle
Rokmen fairlead
Rokmen high line tube fenders
Rokmen Sliders with tube and internal re-inforcements
Savvy aluminum corners with stainless rub rails
Savvy rear aluminum receiver bumper
Rokmen Belly up
Rokmen engine skid
Rokmen Steering box skid
Savvy Gas tank skid
Tom Woods Drive-shafts F&R
Motor Mount lift
CJ flip down tailgate
VisonX LED Rock lights
VisionX 12" LED Xmitter
PSC trail cage/custom additions
Big-bore throttle body
K&N filter charger intake
Heavy duty LUK PRO GOLD clutch
LED taillights
CB
Ultimate Air 10lb CO2 setup
Hope that helps.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 04:16 PM   #65
jkl
Thanks
'05 LJ on 35s
...now parting out
Unread 02-12-2011, 04:33 PM   #66
jkl
Went down to my pasture to work on my little obsticle course I'm building and quickly realized I need a tummy tuck. Tried from both directions and got hung up either way.
Then when I got back home pulled two of the 39.5 Iroks off the scrambler for a test fit. This is about where it would ride with just the 4.5" lift. 23 3/8" to the bottom of the frame compared to 21" with the 35s. As much as I like it, im kinda thinking JK Dana 44s and 37s.
'05 LJ on 35s
...now parting out
Unread 02-12-2011, 05:27 PM   #67
flopp00
dooooooooooooooooooo IIIIIIIIIIIIIIIIIIIIIIIITTTTTTTTTTTTTTTTTTTT that looks so great now but with 39s it looks amazing I love the color and the work you do keep it up
2015 jku hydro blue daily
2013 chrysler 200 fiances
1994 f150 beater
flopp00 is offline   Reply With Quote Quick reply to this message
Unread 02-12-2011, 06:56 PM   #68
22remud
hey thanks for the leading that weekend sorry for all the carnage....you should definitley get those tires on your lj lol
1998 TJ 4.0L NP231, 4inch skyjacker kit
1992 XJ 4.0L NP231, 6inch Gonzo Lift, Cherry Bombed Exhaust,Custom Cowl Snorkel,33x12.50 BFG km m/t's
22remud is offline   Reply With Quote Quick reply to this message
Unread 02-13-2011, 02:08 PM   #69
jkl
Thanks
Your welcome and it's nothing some body armor won't hide.
'05 LJ on 35s
...now parting out
Unread 02-23-2011, 12:11 PM   #70
Boundless
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
http://www.canddautocenter.com/
Boundless is offline   Reply With Quote Quick reply to this message
Unread 02-23-2011, 11:35 PM   #71
Polecat
You shoulda bought my Rubi rocker guards when you had the chance.
Polecat is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 12:40 AM   #72
jeepthing250r
Great build man! I'm kinda thinking about getting a LJ for myself.. Do all LJ's come with dana 44's in the rear?
jeepthing250r is offline   Reply With Quote Quick reply to this message
Unread 02-28-2011, 09:06 PM   #73
jkl
But they wouldn't of helped the rear corner damage
Thanks, all LJ's have a rear D44
'05 LJ on 35s
...now parting out
Unread 04-14-2011, 05:23 PM   #74
jkl
Took the Jeep to the stealership on Tuesday for the OPDA making noise. My buddy that works there said the motor missed the recall by 2 weeks but I'm getting a new OPDA and rear main seal covered under the powertrain warranty Parts had to be ordered so hopefully I'll have it back by the end of next week.
'05 LJ on 35s
...now parting out
Unread 04-26-2011, 08:36 PM   #75
jkl
Got the Jeep back yesterday evening, new OPDA, rear main seal and an oil change for $107 Can't beat that!
'05 LJ on 35s
...now parting out
