JKChris' build thread - Page 11 - JeepForum.com
post #151 of 158 Old 09-16-2013, 07:41 AM Thread Starter
JKChris
2015 JK Wrangler
With the help of some fellow Jeepers, I got some electrical work done finally...
JKChris is offline
post #152 of 158 Old 01-03-2015, 10:13 AM Thread Starter
JKChris
2015 JK Wrangler
I haven't posted here in a while, this is a great way to keep track of when I made my upgrades.
JKChris is offline
post #153 of 158 Old 01-06-2015, 04:18 PM
gshappell
2014 JK Wrangler
Originally Posted by JKChris View Post
I haven't posted here in a while, but I have found that I occasionally look back at this thread to see when I make certain upgrades...
That being said, I haven't made many changes lately. Some are on the horizon though out of necessity. I have recently fallen victim to the infamous "death wobble" I hear so many jeepers talking about. So, time for some research and some eventual component upgrades.
Good luck...had it on my first jeep and fixed it somehow through tightening random stuff and rebalancing wheels. Not sure what it was exactly.
gshappell is offline
post #154 of 158 Old 01-06-2015, 06:47 PM
LowAndMean
Did the rims fit no problem or did you have to trim?
LowAndMean is offline
post #155 of 158 Old 01-12-2015, 03:48 PM
gshappell
2014 JK Wrangler
They fit, they were stock 18 saharas. Think the tires were bigger than stock but i replaced the tires with new duratracs and had them rebalanced.
post #156 of 158 Old 01-20-2015, 07:53 PM Thread Starter
JKChris
2015 JK Wrangler
If you meant my rims, they did fit. You have to be careful with 15" rims and clearance over the brake calipers. Mine fit as long as the balancing weights inside the rim are not double staked.
JKChris is offline
post #157 of 158 Old 01-21-2015, 03:29 AM
Butterbuddha
2010 JK Wrangler
Just to add to this, you also have to check when you rotate your tires. I heard an odd knocking sound once after a service, come to find out that wheel with no previous problems was shaving down a wheel weight with each rotation in its new place. Was no big deal once we realized what was happening, the shop replaced the weights in a different configuration and no issues since. I was surprised the weight was literally being shaved instead of getting knocked off completely!
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #158 of 158 Old 01-21-2015, 04:32 AM
shashi58411
good job so far! The bedliner came out very well and thumbs up on the Tuffy stuff they make some nice products. If you haven't ordered your tires yet, consider running a 16" or 17" rim, with a 15" you'll have to grind the calipers down in the front for the rim to clear the brakes. Also, you'll find out many tire manufacturers aren't making too many 35" tires for a 15" rim any more.
http://questionpaper.org
shashi58411 is offline
DJ-eep Build Thread zrides YJ Wrangler Technical Forum 65 08-18-2015 10:52 AM
Bob's Build Thread cubewhiz YJ Wrangler Technical Forum 67 08-11-2012 09:25 PM
MY D44 Build thread bill8bud YJ Wrangler Technical Forum 60 01-06-2012 10:50 PM
My new JK Build Thread CFIGuy JK Wrangler Technical Forum 5 01-30-2011 09:38 PM
My build thread.:) ImportEater YJ Wrangler Technical Forum 49 03-18-2009 05:38 PM
