jforse-TJ part 2 - Page 34 - JeepForum.com
post #496 of 1073 Old 11-08-2013, 10:13 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Don't leave us hangin'!!
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is online now
post #497 of 1073 Old 11-08-2013, 10:24 AM Thread Starter
jforse
Originally Posted by MO2500 View Post
Oh yea?
yea
Originally Posted by JJeeper09 View Post
Tell
i just did
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #498 of 1073 Old 11-08-2013, 10:25 AM Thread Starter
jforse
Originally Posted by nashvilletj View Post
don't leave us hangin'!!
5.3
jforse is offline
post #499 of 1073 Old 11-08-2013, 10:40 AM
MO2500
Originally Posted by jforse View Post
5.3
Instagram: @omsmike
MO2500 is offline
post #500 of 1073 Old 11-08-2013, 11:16 AM Thread Starter
jforse
Going to run it with the NSG 6speed
jforse is offline
post #501 of 1073 Old 11-09-2013, 09:33 AM
kheihn
I was going to say do the 5.3 over the 5.9 on NSW but forgot to hit send!
kheihn is offline
post #502 of 1073 Old 11-09-2013, 10:10 AM Thread Starter
jforse
Its going to cost more to do, but it is a much better choice.
jforse is offline
post #503 of 1073 Old 11-09-2013, 01:49 PM
platinum5.9
2003 WJ
Huh ;-)
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #504 of 1073 Old 11-09-2013, 04:03 PM Thread Starter
jforse
Anyone have input on fuel pump/fuel system advice for the swap?
jforse is offline
post #505 of 1073 Old 11-09-2013, 04:14 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Pretty sure I read the TJ pump was plenty for the LS motors.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #506 of 1073 Old 11-09-2013, 04:15 PM Thread Starter
jforse
I thought that was the 2005-up pumps which had higher fuel pressure? I thought the earlier pumps didn't have enough psi.
jforse is offline
post #507 of 1073 Old 11-09-2013, 04:26 PM
MO2500
Correct.
Instagram: @omsmike
MO2500 is offline
post #508 of 1073 Old 11-09-2013, 04:56 PM Thread Starter
jforse
Correct.
So. Since I have the early pump in my fuel cell. Should I buy a later TJ pump or do a different aftermarket pump?
jforse is offline
post #509 of 1073 Old 11-10-2013, 06:35 AM
Ryanw10
I run the stock 97 fuel pump with my 5.3 and no issues.
Ryanw10 is offline
post #510 of 1073 Old 11-10-2013, 07:10 AM
MO2500
I've heard of people running both with a 5.3 and it working fine. I forget the numbers off the top of my head and I'm on my phone or I would search but iirc the early pump is rated roughly 5psi below the later model pump. It's on the low side of the recommended pressure for LS engines. I've also heard of some having minor issues of fuel starvation with old, tired pumps.
Since you have the RCI with rings for the factory pumps it would probably be easiest to run the late model factory pump rather than modify the cell for another top plate. If you were to switch I would consider assembling a in-tank system with center pickup with either a Walbro or Bosch pump very similar to what Wayne at Alltech builds and an external reg and filter. His drop in dual pump setups for Ultra4s are a bit pricey but I'm going to piece together my own system and try to save a little. I'll do a write up in my thread when I get to working on that.
Instagram: @omsmike
MO2500 is offline
