jforse-TJ part 2 - Page 27 - JeepForum.com
post #391 of 1073 Old 10-07-2013, 09:04 PM Thread Starter
jforse
Originally Posted by jeepwrangler97 View Post
Damn, hope you feel better
Sent by a messenger bird
Thank you. Finally starting to feel a little better.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #392 of 1073 Old 10-08-2013, 08:48 PM Thread Starter
jforse
Center caps modified to match the rest of the vinyl on the Jeep.
jforse is offline
post #393 of 1073 Old 10-08-2013, 09:18 PM
kyle_craig
Neat.
kyle_craig is offline
post #394 of 1073 Old 10-08-2013, 10:10 PM
MountainMan864
Have you tried Demerol? OxyContin? I know they are a heavy narcotic though. MMJ? Surgery?
MountainMan864 is offline
post #395 of 1073 Old 10-08-2013, 10:36 PM Thread Starter
jforse
I have a follow up with my pain management Doctor on Monday. Have to see what my options are this time.
jforse is offline
post #396 of 1073 Old 10-12-2013, 03:59 PM Thread Starter
jforse
New Lares TJ box ready to get drilled and tapped. Anything special I need for lines for the hydro assist? Looks like PSC has a generic kit that you assemble. Never done it.
jforse is offline
post #397 of 1073 Old 10-12-2013, 04:03 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Just buy there hose kit, comes with,a 45 and 3 90 degree fittings.
K.C.C.O.
Carpe Diem
Hendrix is online now
post #398 of 1073 Old 10-12-2013, 07:16 PM Thread Starter
jforse
Do I need to crimp them on? Do they work like an -an fitting? Are they already assembled?
jforse is offline
post #399 of 1073 Old 10-12-2013, 07:42 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
No, they are pretty self explanatory. You have to assemble them with a vice to hold the nut while you screw the fitting into the hose. Similar to an AN fitting just way more heavy duty. It requires a heavy duty hose to do what a cylinder does. I tried a 300 psi and the cylinder will see pressures over 1000 psi, you can imagine what happened the first time I went lock to lock.
Edit : I have some good pictures in the flops build, I will see if I can find them.
K.C.C.O.
Carpe Diem
post #400 of 1073 Old 10-12-2013, 09:09 PM Thread Starter
jforse
Thanks. I appreciate the advice and assistance.
jforse is offline
post #401 of 1073 Old 10-13-2013, 12:29 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Direct link to the pictures in the Flop build thread. Hope this helps. A few pages back will show the Parker fittings I tried first, all they did is blow out as the steering topped out.
PSC Hose kit install
K.C.C.O.
Carpe Diem
post #402 of 1073 Old 10-13-2013, 03:14 PM
MO2500
I went with the PSC hose kit as well. Very easy to assemble, just follow there directions.
Instagram: @omsmike
MO2500 is offline
post #403 of 1073 Old 10-13-2013, 04:49 PM Thread Starter
jforse
Direct link to the pictures in the Flop build thread. Hope this helps. A few pages back will show the Parker fittings I tried first, all they did is blow out as the steering topped out. PSC Hose kit install
Sounds good. Ordered and on its way.
jforse is offline
post #404 of 1073 Old 10-13-2013, 04:50 PM Thread Starter
jforse
Rgr
jforse is offline
post #405 of 1073 Old 10-13-2013, 05:03 PM Thread Starter
jforse
Pictures for today. I should have help to get the fenders on tomorrow. My back is too bad to do it myself and I'm afraid of messing up the paint.
jforse is offline
