jforse TJ build - Page 3 - JeepForum.com
post #31 of 646 Old 09-27-2009, 07:33 PM Thread Starter
jforse
I know some are not of my Jeep. We had a good day today. No major breaks. My front driveshaf had to be removed before I left the park. The slip joint is REALLY loose. I also got a dent in my oil pan.
jforse is offline
post #32 of 646 Old 09-28-2009, 01:37 PM Thread Starter
jforse
Well I need to find a new front driveshaft. If you have one you want to get rid of let me know! 2000 TJ with 4.0l and NV3550.
Thanks,
-J
jforse is offline
post #33 of 646 Old 12-03-2009, 09:20 AM Thread Starter
jforse
Well it has been awhile since an update. I got the front driveshaft rebuilt. The check valve that was installed inline caused to much pressure and blew the pressure damper on the fuel rail. So its time to just drop the tank and replace the fuel pressure regulator. The front springs are starting to sag pretty bad. Sent a PM off to Jeff from RC to see if anything can be done. I have also ditched the rear tire carrier. It liked to make alot of noise and the latch mech. was horse ****. I plan on doing a Treks tire carrier.
jforse is offline
post #34 of 646 Old 12-03-2009, 09:25 AM Thread Starter
jforse
Treks carrier thats on its way.
I have $2500 left to spend on this damn thing and dont know what to do next. Well I do, but I have like 10 differnt things I would like to do. I'm open to suggestions!!!
jforse is offline
post #35 of 646 Old 12-03-2009, 09:31 AM
snakester14
Def. an 8.8 and lockers looks good though
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline
post #36 of 646 Old 12-03-2009, 03:22 PM Thread Starter
jforse
Thanks. I actually have a TJ D44 that needs some work that I will eventually toss in. Well Jeffery made good on the 2.5" springs and I should have them next week sometime.
jforse is offline
post #37 of 646 Old 12-12-2009, 01:10 PM Thread Starter
jforse
Placed an order today with Savvy for a Currie Antirock and steering!
jforse is offline
post #38 of 646 Old 12-12-2009, 01:35 PM
Imped
Imped's Avatar
jforse--if you don't mind, where did you get a new front DS from? I need one and can't find one anywhere for a decent price, ie under $100.
OlllllllO
IndyORV
Imped is offline
post #39 of 646 Old 12-12-2009, 07:21 PM Thread Starter
jforse
I couldnt find a good one for a decent price. I ended up bringing my stock one to a local driveshaft shop and they rebuilt it. Ended up costing about $50 They put a new centering ball in and cleaned up the splines. Installed a new boot, and balanced it out. Very happy with there work. I love your build by the way!
Just won a set of these on ebay!!!!
jforse is offline
post #40 of 646 Old 12-12-2009, 10:28 PM
MisterO
SWEEEET!!!!
MisterO is offline
post #41 of 646 Old 12-12-2009, 10:33 PM
INCA
Mother Of God.
INCA is offline
post #42 of 646 Old 12-13-2009, 08:59 AM
Imped
Imped's Avatar
^^^awesome.
OlllllllO
IndyORV
Imped is offline
post #43 of 646 Old 12-13-2009, 11:15 AM Thread Starter
jforse
^^^awesome.
I know. I'm pumped. Hey on your TJ what are you doing for bumpstops with the 35's?
jforse is offline
post #44 of 646 Old 12-13-2009, 11:30 AM
MisterO
you can go with the Hockey puck idea.
dont know if you've seen it but basically drill and tap a hole in the spring perch and then drill a hole in a hockey puck and mount it..
MisterO is offline
post #45 of 646 Old 12-13-2009, 11:40 AM Thread Starter
jforse
Yea I've seen and not really a fan. imped has the same suspension setup as me so I was curious how his did with the 35's and rubbing. It seems like I have a few more inches of up travel that is being limited by the bump on the RC 2.2 shocks.
jforse is offline
The Build! XJWren Jeep Builds 17 07-23-2014 10:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 09:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 01:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
