Jesse's Jeep * TJ build - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jesse's Jeep * TJ build
Unread 04-20-2013, 06:37 PM   #31
reichard117
2014 JK Wrangler
Got my 1" coil spacers today. which measure 1.25" but I'm not complaining for $27 shipped off amazon.
I'd like to put them in tonight, I'm looking and it seems like all I have to do is let the axle droop and take out spring retaining ring, cone shaped "bump stop", stick these in, and reverse the operation.
I can't wait to see this thing sit level and not rub CONSTANTLY!
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Follow me on Instagram - @thereich
reichard117 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 01:45 AM   #32
reichard117
2014 JK Wrangler
well it's 2:43 AM and I got my spacers on
I'll take some good pictures tomorrow morning when I go out.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 04-21-2013, 09:09 PM   #33
reichard117
2014 JK Wrangler
nobody has opinions? maybe someone can give me other forums to get peoples ideas. I want this thread to feed off of peoples thoughts on what I should be looking to do next.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 04-22-2013, 03:21 PM   #34
KC0GFG
Don't get discouraged, build how you want to build and show it off!
KC0GFG is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 03:24 PM   #35
KC0GFG
4" ruff country no2 lift 33" tires
Unread 04-22-2013, 04:21 PM   #36
KC0GFG
Lol never mind that front wheel, I just grabbed a pic from my phone. That was with a 35" tire rolled up next to it.
Ps more pics of the hood? Did you use gloss or flat? I've been contemplating doing the same to mine.
Unread 04-22-2013, 08:47 PM   #37
reichard117
2014 JK Wrangler
Now that I like ^^ I wanna get a bowless soft top and matching half doors really bad. The S*ittybuilt top I have now is garbage. A few zippers broken, ripped here and there, doesn't seal up, and its nearly brand new I'm guessing.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 04-23-2013, 10:41 AM   #38
KC0GFG
i was running the best top trex top nx as seen here: http://www.bestop.com/component/prod...=product&id=12
i liked it and am considering it for my 2nd jeep, the one pictured was totaled
Unread 04-30-2013, 07:01 AM   #39
reichard117
2014 JK Wrangler
Had a little spare time in school so I took an old piston that I had laying around from a bike I toasted.
turned down a piece of aluminum and drilled/tapped it for the shifter
and violà! shift knob that pivots like it's actually on a connecting rod! Too bad I had to drive it home and park it because of my frame issue. It makes a great hand rest for changing stations or turning the volume up on the stereo!
For my birthday I got some cash and will be getting a tuffy center console in preparation for living in FL. Also have HS graduation money coming soon so I'm pumped! hopefully $500-$600 to play with! Now what should I do with it? As bad as I want goodies.. I feel like I should go with spark plugs, fr/rear diff fluid, tranny flush, header.. and anything else for maintenance.
ORRR I could get tires
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 05-01-2013, 01:42 AM   #40
KC0GFG
Secure the back too. I had some delinquents take all my recovery gear and spread it out don't the street. If your planning on running topples it might be a good idea to pull the carpet and line the tub. Perhaps invest in some seat covers as well. But knock out the routine maintenance first
Unread 05-01-2013, 09:06 AM   #41
reichard117
2014 JK Wrangler
I'll have to build or look for some type of trunk because I will have my sub back there and don't need it getting jacked either. I'm planning on getting the carpets out the first weekend I get some time to at least sit down.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 05-07-2013, 07:04 AM   #42
newjeepguy1969
Classic- LOL....Keep this going. Looks like you are doing a good job.
newjeepguy1969 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 10:03 AM   #43
reichard117
2014 JK Wrangler
Here's one that kind of shows the hood, sorry I didn't see your request. I'll have to get some better pictures..
hey thank you!! It's hard working 20 hrs a week while in high school an trying to feed this gas tank, let alone build it/maintain it.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 05-07-2013, 10:09 AM   #44
reichard117
2014 JK Wrangler
These are pretty much all in reverse order, and there is one of the CA mount where we will be fixing next.
I used chassis saver which was $15 for a small 8oz or so can but it goes a long way.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Unread 05-07-2013, 11:34 AM   #45
KC0GFG
What bumper are you running up front? It looks like the smitty built src classic.
